Revo Technik
Closed Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 40 of 84
    Senior Member Four Rings joeycuccaro's Avatar
    Feb 29 2008
    Northern NJ
    Audi B6 S4 DIY Serpentine Belt
    Here it is guys, a DIY to do the Serpentine belt yourself. I would recommend getting a friend to help you out with the job. It will make it go a lot faster and its easier to take off and remove the front bumper. This was complied by myself and littleredwagen
    Tools Required:
    Jack
    2 Floor Jack Stands
    1/4 Ratchet
    3/8 Ratchet
    3/8 6' Extension
    TORX20 Socket
    TORX25 Socket
    TORX30 Socket
    TORX45 Socket
    6mm Hex Socket
    Philips Screw Driver
    Flat Head Screw Driver (Stubby is preferable)
    10mm ratchet wrench
    10mm socket
    13mm socket (shallow)
    17mm socket
    18mm socket (shallow)
    Long Torque Wrench
    Breaker Bar
    Parts: Serpentine Belt
    Audi Part Number = 079-903-137-A
    NOTE: Order belt according to VIN number. There is a split date.
    Torque Specs:
    Tensioner Assembly- 22nm (If Replaced)
    Idler Roller- 20nm (If Replaced)
    Step 1: Jack the front end up
    First and foremost, jack the front end of the car up. This will make it easier to take off the bumper. It is not necessary, but you will see why we did it this way in a bit. Place 2 jack stands on the front pinch welds.
    Step 2: Remove Drivers side wheel
    Remove the drivers side wheel for now. Breaker bar and 17mm socket to remove lugs. We will come back to it in a bit.
    Step 3: Remove belly pan
    Crawl under the front of the car and remove the belly pan. There are several bolts holding it in. Grab your flat head and twist them out.
    Step 4: Remove Intake Snorkle
    Lets start with the passenger side and remove the intake snorkel. Grab your philips screw driver and remove the two screws holding the snorkel in place.
    Once the screws are out, disconnect it from the car.
    Step 5: Remoe Airbox adapter
    Now take the adapter out that is shown above. To do so simply pull upward away from the air box.
    Step 6: Remove Headlights
    Next step is to remove the headlight. There are four TORX30 bolts holding the headlight in. The top two need to be completely removed. The rear ones only need to be loosened in order to remove the headlight.
    To reach the rear two TORX30 bolts, grab your 3/8 rachet with a 6" extension.
    Once the top bolts are removed and the rear two are loose, pull the headlight assembly forward. Time to disconnect the headlight harness. It can be a pain, please follow the link below for a video on how to do it.
    Video to remove harness
    Once the harness is disconnected, remove the head light from the car. Follow the same procedure for the drivers side. Below is a picture where the hidden TORX30 bolt is.
    Once both headlights are removed you can pull the weather seal off the engine bay.
    Step 7: Remove Fender Liner Bolt
    Okay, move to the passenger side wheel well. To make things easier, cut the wheel to the left to make room. Grab your stubby flat head and remove this fender liner bolt.
    Once that is removed, pull the fender liner back to reveal this TORX25 bolt. Grab your 1/4 ratchet and TORX25 socket and remove it.
    Step 8: Free Lower Bumper from Fender
    Once that is removed, its time to pull the lower half of the bumper away from the fender. Review the image below. Slightly pull the lower portion of the bumper toward you. It will give away from the tabs.
    Step 9: Follow the same procedure for the drivers side.
    Step 10: Remove Inner Fender Bolts
    Okay your done on the bottom half for now. Back to the passenger side. Take a peak on the inner fender where the headlight was. You will see three 10mm nuts down the side of the fender. Grab a 10mm ratchet wrench and remove these three bolts as shown below.
    Okay lets go back to the driver side now. You can either follow our way or do it the other way. The problem with the drivers side is that the three 10mm bolts connecting the fender and bumper are difficult to get to. Its clearly not as easy as the passenger side. You can either work in the tight space to remove the bolts or follow the next instructions. If you remove the bolts here skip down to Step 12.
    Step 11: Remove the fender liner
    There are a bunch of TORX20 bolts holding the fender liner in. Once its loose, remove it from the car. You will now see something like this.
    Get a bucket handy as you will want have something to drain the washer fluid back into. Slide the left side reservoir out and disconnect it from the quick connect nozzle as shown below.
    You now have easy access to the three 10mm bolts. Its much easier this way. It is also much helpful doing it this way when reinstalling the bumper.
    Step 12: Remove Fog Light Surrounds
    Once your done, its time to remove the fog light surrounds. Grab a flat head screw driver. You will notice the screw is vertical. Twist the screw to the horizontal position as shown below and it will pop free. Remove it from the car.
    Step 13: Remove Bumper bolts
    The bumper is almost ready to come out. There are two HEX bolts holding the bumper on located where the fog light surrounds were. Grab your 3/8 ratchet and HEX6 socket. Loosen them but do not remove them. A picture is shown below where they are located.
    Step 14: Remove Bumper
    The bumper can now be removed from the front end of the car. There are two connectors on the drivers side that need to be disconnected in order to move the bumper away from the car.
    Step 15: Remove AUX Radiator Shrouds
    Once the bumper is placed to the side we can start working on the RAD support. There are two radiator shrouds that must come out on each side of the front end in front of the AUX radiators. Grab your 10mm socket and remove these bolts. Repeat on Drivers side.
    Step 16: Remove Upper Rad Support Bolts
    Okay now the upper rad support bolts can come out. Grab your TORX30 socket and remove both bolts. Repeat on the drivers side.
    Dont put your TORX30 down, there is another bolt down by where the AUX rad shrouds were. Remove it. Repeat on drivers side.
    Step 17: Remove Main Rad Support Bolts
    Grab your Torx45. Its time to take out the RAD support bolts. There are three on each side. You might need a breaker bar to get them loose. Repeat on drivers side.
    Step 18: Slide Radiator Forward
    Once the six RAD bolts are out, you can now slide the Radiator forward. You should make a gap around 3 or 4 inches as shown below. If needed, place a bucket under the RAD to support it.
    Step 19: Removing the Belt
    Okay. Here is where you will need two people. Grab your torque wrench and put a 18 mm socket on it. Also grab your 3/8 ratchet and put a 13mm socket on it. First, loosen the 13mm bolt on the bottom as shown, but do not remove it.
    Once it is loose, grab your torque wrench and put your socket on the adjustment bolt head shown below.
    IMPORTANT: In order to loosen the belt you need to go CLOCKWISE (Tighten) on this bolt head. Once you do that the belt will pop loose.
    Step 20: Install new belt.
    Pay attention to how the belt is run before you pull it off. Once its off, install the new belt in the same fashion. Audi rings should be facing the drivers side. He is a picture if you forget how it went.
    Step 21: Tighten New Belt
    Once the belt is run, have a friend get the 18mm socket back on the adjustment bolt head and go COUNTER-CLOCKWISE to 70nm. Once its tightened, take your 13mm socket and tighten the 13mm bolt to 20nm (hand tight).
    That's it, the belt is now installed! You now can follow this DIY in the reverse and reassemble the car. While your here this would be a good time to put an aftermarket snub mount on.
    I hope this helps everyone. Good luck! Please feel free to contact me if you have any questions.
    Senior Member Four Rings trexturk's Avatar
    Mar 20 2007
    04 Nogaro S4, 03 996 Targa
    Chicago Burbs
    Re: Audi B6 S4 DIY Serpentine Belt
    Great write up.
    Should have changed the snub while it was out
    04 Nogaro S4 W/ Some Mods
    Feb 29 2008
    Northern NJ
    Quote Originally Posted by trexturk View Post
    Great write up.
    Wasn't my car, i put in an APR when i did my my belt.
    Senior Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Good stuff but watch out, you didn't put tq specs so you might get flamed
    Thanks for taking the time out to post this.
    Senior Member Four Rings bsrpilot44's Avatar
    Feb 25 2007
    B7 S4
    So.Cal
    Quote Originally Posted by 40valve View Post
    bwahaha i was about to post a joke to this tune...well done buddy.
    -B
    2006 Audi
    STaSIS Motor Sport Suspension
    STaSIS CB/Labree Catless DP
    Brembo Mono 6 355 BBK
    VORSTEINER Double Sided CF Vented Hood w/Color CF V
    CF Front Splitter, CF Boot Lid Spoiler, CF Roof Spoiler
    Custom Revo Tuning, GsG Intake
    H-Sport RS4 Anti-Sway Kit
    Southern Ring FRRG Chapter President
    *SPONSORED BY VORSTEINER*
    Feb 29 2008
    Northern NJ
    Man your right. LoL B! Good times good times...
    Active Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    How many miles were on the car? My belt @ 55 looks very similar to his old one.
    Thanks for taking the time to document all that! Bums me out I just didn't do it when I did my snub a few weeks ago.
    05
    JHM SM/LW Flywheel + Stg3 clutch | JHM Piggy's | Milltek nonres | JHM Tune | JHM 4:1 Center Diff | Neuspeed 25mm Rear Sway | APR snub | Apikol Rear Diff | JHM SSTS | Vogtland GT's
    SomeGuyInAChair - "I'll be honest about why I signed up for a car forum without thorough knowledge of cars. I merely did a Google search with the following key words: "milf cougar forum advice help tips"
    Active Member Four Rings ngng's Avatar
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    i should do this when i pull off the lock carrier and front bumper :P
    ...everything but a LSD
    Active Member Three Rings s4buckeye's Avatar
    Dec 21 2008
    '11 PORSCHE CAYENNE S/VWNB/YUKONXL
    Kali
    Quote Originally Posted by joeycuccaro View Post
    As usual, good job JC!
    New Member Two Rings
    Dec 26 2008
    2005 Audi S4
    STL
    good write up man, it's definately a good contribution to the site.
    Active Member Two Rings Storm33's Avatar
    May 13 2008
    05 B6 S4 MT6
    Ann Arbor, MI
    Excellent write-up; rep added!
    2005 B6 S4 MT6
    Silver / Black
    Feb 29 2008
    Northern NJ
    Thanks for the compliments guys. Hope someone finds this useful.
    Active Member Three Rings Mr. Corey's Avatar
    Jan 14 2009
    B6 S4 / 5.9L Limited Jeep Grand Cherokee
    Syracuse, NY
    Great write up Joey. At what mileage should this be changed out?
    B6 Nogaro Alcantara 6MT/ GTC / Bilstein PSS9 / Stratmoshere Fullback Exhaust / HyperFlow Intake / Stratmoshere SS / HID fogs / LED Plate Lights / ECS Snub
    Feb 29 2008
    Northern NJ
    Quote Originally Posted by Mr. Corey View Post
    Dealer recommends at 75k, but id check it around 40-50k
    Senior Member Three Rings earhythmic's Avatar
    Sep 17 2006
    B6 Dolphin S4
    San Francisco/San Diego, Cali
    do you have a front shot or diagram of how the belt is run? Mine snapped yesterday and I'm thinking about doing this myself. Unless it can be covered by CPO. Car has 55k on the clock. I know the 75K service is to just check the belt, replace if needed, but..
    2005
    JHM Extra SS | Apikol Snub Mount | AWE Pedals | Xenon Interiors | VAG stuff
    coming soon - Custom Piggies | H&R Coilovers | AWE Exhaust
    Senior Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Quote Originally Posted by earhythmic View Post
    Belts ae like brake pads...not covered.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Senior Member Three Rings littleredwagen's Avatar
    Jan 08 2008
    2005 S4 Avant
    The belt goes around crank and altenator pulley goes over the idler roller and finally over the tensioner. I will try to find the diagram in a bit
    edit diagram added:
    -Matt
    2001.5 S4 Imola Yellow, 2005 S4 Avant 6spd Brilliant Red
    Past: 2007 VW GTI, 2004 Jetta GLI 1.8T
    Sep 17 2006
    B6 Dolphin S4
    ^^^ fantastic! That's exactly what I was looking for. This might be pushing it a tiny bit, but do you have the legend to cross reference the numbers too?
    2005
    Feb 29 2008
    Northern NJ
    Has anyone successfully used this DIY yet?
    Mar 24 2008
    khgkhg
    I forgot to do it yesterday when I was changing tranny fluid.
    I'll def reference it when I'm ready for the snub mount just to brush up on screw/bolt locations
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Sep 17 2006
    B6 Dolphin S4
    yup
    2005
    Senior Member Three Rings c4racer's Avatar
    Dec 23 2007
    2005 S4 Avant - 6MT
    San Jose, CA
    perfect timing. I just had a belt come off my wife's Mazda, so I finished dealing with that. I realized I forgot to tighten one bolt. Damn - I really prefer the spring loaded tensioner instead of manual tensioner. So glad to see the S4 has a spring loaded tensioner - they work so much better. Anyway - I was thinking I need to do that for the S4 now that I am over 70K mies, so I took a look at it just now and was thinking - wow - can't even see the belt, I bet a bunch of sh!t has to come off. I was right. And it is great to have this write up, I am sure it will save me some time in the R&R of all that crap just to get to the damn belt. I need to do the oil within the next few weeks anyway, so I will schedule some extra time to do the belt while I am at it.
    So what is the snub mount, and why should I change it?
    '05 S4 Avant - 6MT
    '03 BMW X5 4.6is
    '09 G37 Sedan
    Feb 29 2008
    Northern NJ
    Quote Originally Posted by c4racer View Post
    Snub is your forward most engine mount. An aftermarket one reduces the "jolts or jarred" motions you feel when shifting. Stock ones are rubber. Aftermarket is a thicker material which reduces the "play" and will not wear as easy as the OEM one. Its easy to do while your there and they only cost 30 bucks.
    Senior Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Any harsh vibrations with aftermarket snubs?
    Jan 08 2008
    2005 S4 Avant
    Quote Originally Posted by nimski62 View Post
    a little not to noticeable at all
    -Matt
    Mar 09 2005
    Santa Clara, CA
    just ordered a belt today. didn't realize it was cheap
    Feb 29 2008
    Northern NJ
    Quote Originally Posted by ngng View Post
    Yeah very cheap
    Active Member Two Rings 93hrdtptt's Avatar
    Aug 21 2008
    2004 S4-Nogaro Blue 6spd, 2000 Yamaha R6
    Bergen County, NJ
    i ordered my belt a few days ago...now you got me thinking about the snub mounts... how difficult is it to do? 30 bucks worth it? i just had new oem ones put in under warranty lol..blehhh
    Feb 29 2008
    Northern NJ
    Quote Originally Posted by 93hrdtptt View Post
    Yeah it is worth it. We will talk about it when you come by later.
    Active Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    good write up. thanks for taking the time to photo everything, writing and posting it up here.
    Mar 24 2008
    khgkhg
    OK this is kind of ridiculous but I can't get the bumper off. Granted this is the first time on B6 but it's not that complicated. Anyway, all bolts/torx and headlights have been taken out but the center of the bumper, right above the where the license plate goes will not budge. There is something back there holding it and I mean it's really holding it. I though maybe there were snaps but I've pulled on it to the point of it breaking and will not move at all.
    Any ideas?
    BTW this is on 2004.
    |^^^^^^^^^^^\||____
    Feb 29 2008
    Northern NJ
    Any ideas?
    Check Step 13...
    Did you remember to loosen the 2 hex bolts that are accessed through the fog grills? You have to loosen them significantly in order for the bumper to give. Im guessing they are not loose enough.
    Try that and let me know if it works.
    Senior Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2006 S4
    Houston, TX
    This is a great DIY. Very well done. This should be the same for a B7 except maybe for getting the bumper off, right?
    Mar 24 2008
    khgkhg
    Check Step 13...
    They are completely removed. When I pull on the bumper both sides and the bottom of it are loose and move freely. Top part of it won't budge.
    At this point I went over everything at least 3 times and I got everything
    |^^^^^^^^^^^\||____
    Feb 29 2008
    Northern NJ
    Hmm, very weird. By chance are there any screw holding the bumper on from the bottom where the belly pan is?
    Mar 24 2008
    khgkhg
    Nope, the bottom of it is loose. I can pull on it and it moves freely so there is nothing there holding it back. Like I said, the only place that I feel any tension is the top but I can't see anything back there that holds it. There were these plastic tabs that kind of looked like this O===) which I removed but they didn't release it.
    I think I just might take it to the dealer since I know the snub is cracked and let them take it off. It's still under warranty. Thanks anyway
    This pisses me off, I've never taken the car for anything to someone else
    |^^^^^^^^^^^\||____
    Feb 29 2008
    Northern NJ
    Sounds like some funny issue. If you followed my steps it should of come right off. Good luck bro.
    Mar 09 2005
    Santa Clara, CA
    Can you confirm which bolt to remove first and which one to turn? I have a better pic:
    Forum Moderator Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Might want to replace the valve cover gaskets.
    If you don't have haters, then you're not kicking enough ass.
    AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Mar 09 2005
    Santa Clara, CA
    Quote Originally Posted by Justincredible View Post
    yeah, already have a kit on order :) might, would be an understatement
Closed Thread
    © 2001-2010 Audizine, Audizine.com, and Driverzines.com
