Stage 3 Forum Advertiser
Four Rings
JHM 4:1 Center Diff Now Available for B6 & 05.5 B7 S4! More power to the rear tires
UPDATE: 4-09-09. We just received a couple core transmissions we bought today. So we have diffs ready to ship out if you want to do the core exchange and not have downtime!
First off a BIG THANK YOU to everyone here in the B6/B7 S4 forum who has called me or emailed me lately with inquiries and praise for our hardwork. For those who's calls we missed, emails or PMs we have been slow to get to we deeply apologize and have some more help coming on soon to keep up. If you do call PLEASE leave a message, we WILL return your call.
Also a special Thanks to the B7 RS4 owners who have called from all over the world asking about our possible future offerings for you guys. We will get to you guys with some cool hardware soon enough. If there are any B7 RS4 owners in the SF bay area or Sacramento Area feel free to contact us to help us with R&D for new B7 RS4 parts.
NOW TO THE NEW PRODUCT.
For Manual Transmissions Only (Please specify in the comments during checkout, the year, model and how many speed transmission your Audi has when purchasing.)
Intro price of $350!
As of 3-27-09 we have the following coverage and cores ready to ship.
- B6 S4 and 05.5 B7 S4 - FVD, HEP, HSM trans codes only (We have Cores in stock!) The 06 and up B7 S4 and the B7 RS4 have a different part number for the center diff and are reportedly already 4:1, we are investigating this further.
ABOUT THE PRODUCT
The factory torsen center differential in the S4 and A4 provides a 2:1 torque distribution between front and rear. What does this mean? This enables the end of the car that still has traction (most of the time the rear) to deliver double the torque to the tires with traction. JHM's experience has found that this closer to even distribution is best for drag racing. So this modification is not for you if you are into drag racing primarily. However for Auto Crossers, Road racers and others who prefer the twisties JHM recommends a bias ratio of 4:1. This is the same bias ratio that Audi has provided in the stock B5 RS4 driveline.
So if you are tired of going through corners while using a lot of throttle and still getting "understeer" then this product is for you and will help you get a little more "oversteer" and allow you to drive the car a little more like a RWD car but still have the superior control of AWD.
Core Exchange
There is a core charge of if we send out a JHM center differential to you (see drop box below for amount). When you exchange your center differential for a JHM unit, send your differential back to JHM and we will refund the core charge. $650 core charge, check the chart above to see if we have a core in stock for you.
You may also send your differential to us for modification and not incur a core charge. We can usually modify and ship out your differential within the same day. If you will be sending yours in, unselect the core option and specify in the comments that you will be shipping it in. Also put the invoice number on your box when shipping it in for modification.
VISIT OUR ONLINE STORE HERE TO ORDER -> http://www.jhmotorsports.com/shop/ca...products_id=46
UPDATE: I had many people asking for instructions. So I used a trans core I had here and some existing pictures and put together a decent instructions for you guys. These should get you through it with not too much headache.
JHMotorsports.com - 209-968-0077
Follow us on Facebook
Please PM Tech/Sales@JHM or email us at sales@jhmotorsports.com if you need a question answered in a timely manner by me. My duties as President of JHM keep me behind on PMs & emails. I am accessible to my sales team for answers.
2005 Audi S4 - JHM Stage 1 Supercharger (ET: 11.96 @ 116mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph)
2001.5 Audi S4 - JHM RS6-R (ET: 10.8 @ 130mph)
Senior Member
Three Rings
Re: JHM 4:1 Center Diff Now Available for B6 & 05.5 B7 S4! More power to the rear ti
Yet another good product from JHM. Cant wait until i have the funds to get one of these on my car. Keep up the good work.
Senior Member
Three Rings
So for my own knowledge I'm just going to summarize the improvements of this upgrade. Please tell me if i am off base.
Essentially a torsen diff manages torque imbalances. This is measured as the Torque Bias Ratio. The stock B6 S4 uses a 2:1 TBR. This means the maximum possible torque imbalance is 66%...(2+1 = 3. ---> 100% / 3 = 33.3%. ---> 33.3% x 2 = 66.67%) I suppose this means the diff can only manage/split 66% of the torque in either direction, front or rear? Is this correct?
The JHM upgrade is a 4:1 TBR meaning that the center diff can manage a possible 80% torque imbalance. (4+1=5. ---> 100% / 5 = 20%. ---> 20% x 4 = 80%.)
So essentially this diff can send up to 80% of the available torque to the front or back?
Now this torque imbalance is different from the normal traction situation where the B6 develops a 50/50 split front and rear.
Four Rings
You got it. Generally it will send the higher percent to the rear due to how the car reacts due to weight transfer on accel, but when under braking more can go to the front at times.
We have noticed a big difference at the drag strip trying stock diffs and then 4:1 diffs. The fronts can spin when it is stock when the car squats. With this mod we have noticed the car could actually fishtail pretty good at times, so we would end up needing better rear tires.
Senior Member
Three Rings
Beautiful...thanks for the reassurance.
I guess i was unsure about the 50/50 split which is only true under normal driving conditions where equal traction is present at each wheel. It's only when different wheel speeds / traction conditions are present when the center diff can distribute greater than 50% of the available torque to the front or back.
Thanks...seems like this would be a worthwhile mod for corner carvers.
Four Rings
Exactly man. The corner guys generally love this mod. Those who drag race tend to prefer stock diffs and just stick drag radials on all 4 corners. Obviously when drag racing you could run one of these diffs and put sticky tires on the back, but that will really strain the rear diff a lot more. Seen some gnarly results from it too.
Senior Member
Three Rings
I can't imagine an S4 with a proper clutch and DR's on all four corners. I would expect short times in the ~1.7 range.
My toy car is a '91 mustang with Al heads, cam, intake and all the supporting mods. I run the MT ET streets and a spec stage II clutch and that car leaves HARD. I dont think i ever did any better than a ~1.85.
Senior Member
Three Rings
Definitely a worthwhile mod! Great pricing too.
2013 S5 6-speed
Stasis Ohlins coilovers, 20" BBS CH-Rs and spacers, custom exhaust  , tint, Roc Euro short shifter
Previous: B7 S4 6-speed, mods.
Four Rings
WOW! Yet another Awesome product for our cars! You guys are on Fire!
Whats the average labor hours to install one? thanks
Don-
Light Silver/Blk 2005 B6 S4 Six spd every option - Carbon Fiber - LM25's on stockers - Ruger R10 19's - Falken 452's 235-35-19's - Milltek Non Res CB-Magnaflow 14851's Mufflers- X-Pipe - APR DP's - Rs4 Pedals - JHM SSK - Flapper mod - WAITING on JHM LT's
Senior Member
Three Rings
anyone who has this care to comment on how/if it changes the drivability during weather conditions, especially winter? Id assume more power to the rear would alter the driving mechanics. Definately not a bashing question, just wondering.
GIAC Stage 1 ::: H&R S4 Coilovers ::: V&S Short Shifter ::: B5 Rs4 Reps ::: Intake ::: N75R ::: Tints ::: 12'' Kicker Square Sub
Need to sell this A4 asap...SOLD
Active Member
Two Rings
est cost for install?
...I may have to take a little drive over there
2005 Arctic / Silver S4
Labree H-Pipe CB | PSS9 | Hyperflow Hypershift | RS4 Rear Sway
19" VMR V710 MB | RE-01R 245 35 19
Senior Member
Three Rings
During normal driving, you will still maintain an even distribution of torque amongst all wheels. It is only during aggressive driving/accelerating the torque will be sent to the rear wheels more. The car still handles huge downpours with high honors.
I believe JHM quoted me approximately 2-3 hours labor. Stasis wanted either 4 or 5 hours, IIRC.
2013 S5 6-speed
Active Member
Two Rings
Jason, for those of us who are local(-ish), is this something we could schedule to have installed while-we-wait? This is just a little too tempting.
Senior Member
Three Rings
Sounds like the 4:1 diff mod if for those who like carving the corners. Do you need to turn off the ESP to get the advantages of this when in the canyons, or is it rendered not effective if you leave the ESP on?
For track or Autocross, I'd take the ESP off, but when I'm hanging on a canyon edge I leave the ESP on, just in case.
So, is this mod only effective with the ESP off? And, does anyone turn off the ESP when canyon carving?
Senior Member
Three Rings
On stock tires i am able to cut 1.8s and thats on stock clutch too. So i wouldnt see no reason why one couldnt cut a 1.7 or maybe even better.
Whats the turn around time for someone that has shipped you their diff? meaning how long does it take for you to work your magic?
Four Rings
The day we receive it we will modify and send it out that SAME DAY.
Senior Member
Three Rings
Very quick turn around times, keep up the good work
Senior Member
Three Rings
Is it correct that the RS4 is set up stock to send up to 80% of the traction to the rear tires, if needed, during daily driving?
If so, then it sounds like this mod is good for a 2005 S4 which only sends up to 60% (?) to the rear tires, if needed. Is this mod only noticeable when during aggressive twisty road driving IF you turn off the ESP, or noticeable even with ESP on? I usually leave ESP on during canyon driving. Thanks for your input.
Senior Member
Three Rings
Will these work for auto and 6spds?
Four Rings
My 60fts with my B5 S4 on street tires is in the 1.7 range. With drag radials 1.6s or better should be the expected. On street tires 1.8s to 1.7s are what you aim for. I have a couple times gotten 1.6 60fts on street tires, but rarely.
I have a 91 Mustang as well with a 347 stroker and have had the same tires you ran on it and got a high 1.7 60ft with a full street setup, so I know the feeling.
2 to 3 hours depending on cat back and downpipes.
Here is a nice response from a B5 A4 owner who has had this kind of mod for a while. He posted this in another thread of mine.
 Originally Posted by UCFQuattroguy
I modded the center diff of my A4. There is a difference, but you'll really need to be able to drive the car at 10/10ths to really appreciate what this does for our Quattro cars. If you do this diff without doing a rear LSD as well, the difference will be subtle...simply because you cannot defy physics. Yes, the car will be *MUCH* more neutral going through long-sweepers, but if you have enough weight x-fer away from the inside-rear, you will have some wheelspin (especially if you're packing K04's), which will cause the car to go right back to power-understeer because spinning a tire is taking load away from the rear, putting the torque towards the front.
Even with a K03 in my A4 with R-Compound tires I feel this every auto-x event. Just like anything, you learn to drive around it. But, in all, if you have the $$ to do it...get the rear clutch-pack LSD at the same time. That will allow you to get the most out of the center diff upgrade. I've been itching to find the $$ for me to upgrade to the rear LSD.
Oh...and U-Turns are a riot with the 4:1. In general, the less available grip there is on the road surface/tires the larger the difference is between 4:1 vs 2:1.
We do the install for only $200 since it is an in house part. We tend to give better deals on labor for in house made parts. So $200 plus $350 plus about $50 in some new gear oil.
Feel free to call us to come down. 209-968-0077
Yes we could do it in a 2 to 4 hour period. There are several restaurants nearby. We also around the corner from the ACE commuter train for those who can't find someone to come with them if they need to drop the car for a day or two.
Generally you will notice this most when you are pushing the car harder than the ESP will allow. However it seems most people are happy with it in most any condition.
Same day in most cases.
As for drag racing it depends on your tires and suspension. For cars that don't squat as much using a stock diff tends to be better. If you wanted to put stickier tires in the rear some have found in those cases the center diff does help.
From what I have read the 06 and up S4s and the RS4 do already have this mod. (they both share the same part number for the center diff). In 06 the part number did change so there is a difference. Until I get an 06 and up in here to tinker with their trans we are at the mercy of what was claimed. But I would bet that this is really the case.
We have all the 6 speeds covered. We haven't looked into this for auto transmission cars yet. Haven't even looked at one. Not sure if their center diffs are built similarly and are as easy to remove. In time hopefully we can check into this.
Three Rings
Looks like I am driving up to Lathrop again.
Senior Member
Three Rings
 I want....
2000-Porsche 996 AERO Fabspeed stg 1 300RWHP
2008-VW R32 #595
2004-AUDI A4 USP AVANT
1999-AUDI A4 AVANT GT28RS
2005-AUDI S4
2006-AUDI A3
1994-VW JETTA
1985-PORSCHE 944
1982-PORSCHE 911SC
2007-SAAB 93 AERO 2.8 TURBO
Four Rings
Also with these transmissions we are going to be officially offering a transmission rebuild service soon. We can do them now, we are just working out the details. We have been doing this for the B5 S4 guys for years now, so wanted to offer it to you guys.
Senior Member
Three Rings
Sounds good, keep up the good work. I might have to do this mod sometime down the road.
Senior Member
Four Rings
Will there be an option for a better overdrive 6th gear with the transmission rebuild kit?
Four Rings
Yup. I actually found a used 6th gear from a Europe diesel trans today. I got a guy in LA who is buying it from me to test. So we finally might get results on that as well in the real world. It will be an 800 rpm drop at about 80mph.
Holy... On it already. Good stuff guys. I have a question on the diff though, I never plan on using drag radials, just street. Will this diff hinder or help my 0-60 ft or mph, if by much? I guess next thing would be to get upgraded rear diffs as well, no?
Three Rings
do you have a ball park range on a tranny rebuild??
Senior Member
Four Rings
Cool, the full transmission rebuild seems like a much better method of installing the overdrive. To me its a no-brainer if you have to replace a synchro or something. And a 800rpm drop would be awesome, beyond just the better mileage it'd be nice to have the engine at 2000-2500rpm at normal highway cruising just so the engine wouldn't be straining and groaning as much.
Four Rings
If you put larger rear tires and your car had a tendency to spin the fronts a little then yes it would help. It depends on suspension setup and tires. Traditionally for the drag strip we prefer the stock diff.
If you sent yours in and no gears or shift collars were damaged (usually due to neglect or shifting with a bad synchro and ignoring the grinding for a long time). I would say in the $2000 to $3000 range. Still pricing out the parts needed and haven't gotten back my european direct prices.
i'm trying to get the stasis sL c/o and the rear wheel for the set i'm looking in to is 9.5 for the rear. not sure on tires yet though.
Senior Member
Three Rings
Any word on the 6th gear conversion?
Four Rings
Four Rings
We have sourced a .56 gear from a European diesel transmission. Just waiting for it to arrive then we need to find a volunteer.
Senior Member
Three Rings
If i wasnt soo far away i would be down for it. But i dont think it will happen for me atleast until i need to pull the tranny for a clutch job or something like that.
Four Rings
Understandable, when the trans is out it is only like a 10 minute job. So it saves on labor time.
Four Rings
This is a super easy job on the a4 but it looks like you guys have that damn second exhaust pipe in the way  i sure wouldnt mind that though........ it really helps the car stay planted in the rear when powering out of turns and you can get it nice and sideways while the quattro makes you look like a pro pulling out of the slide! one of my fav mods!!!!!!!
2004 A4 UltraSport APR 2+, Racetech FMIC, APR TIP, Southbend FE SS, Stasis 4:1 Center Diff, Neuspeed Exhaust/test pipe, Podi/VEI boost gauge, Stasis StreetSports, JHM Solid Short Shifter -1" Stern ACAs
2005 S4 Sprint Blue Cabriolet Stock  but 1 of 150
Active Member
Two Rings
Did you have the rear lsd as well or just the center diff? The review posted above said that unless you had both it would still understeer.
Account Terminated
Four Rings
NOw that JHM has cores, tehre is NO REASON you should not do this.
- You may not post replies
- You may not edit your posts
Forum Rules
