Results 1 to 22 of 22
    Stage 2 Banner Advertiser Three Rings Parts4Euro.com's Avatar
    Sep 16 2008
    Michigan
    Parts4Euro.com | EVOMS & Forge Replacement Diverter Valves for VAG 2.0 TFSI
    NEW ITEM!!
    Forge Blow Off Valve Kit for VAG 1.4T 1.8T 2.0T Engines
    PLEASE ORDER HERE
    NEW ITEM!!
    Forge Recirculation Valve for VAG 1.4 TSi Twincharged Engines
    PLEASE ORDER HERE
    NEW ITEM!!
    Actuator for MK5 Golf 2.0L FSiT
    PLEASE ORDER HERE
    Replacement Valve for 2.0litre FSIiT TFSi Engines
    FREE SHIPPING WORLD WIDE!!
    PLEASE ORDER HERE IN STOCK READY TO GO!!
    We’re proud to announce another industry first for the Volkswagen and Audi tuning market from Forge Motorsport!
    For owners of VAG vehicle equipped with the all new 2.0T FSI engine that have the electronically controlled bypass valves, situated at the front of the engine (as shown in the photo below), we can now offer an alternative.
    If you are running increased boost pressures, after a software remap (chip), or the OEM valve is being subjected to high temperatures, the lifespan of the unit is significantly reduced.
    Even without any modifications taking place to the vehicle at all, this OEM valve has been shown to fail over time and it’s boost holding capacity also leaves some room for improvement. Our alternative is a fully engineered solution offering both significantly improved reliability as well as valve related boost response. Our valve and installation kit replaces the original unit with a pressure/vacuum operated piston valve that still also retains the desirable OEM ECU control over valve actuation. This product has been thoroughly designed and tested with the expressed intent of offering improved valve response and maintaining ECU control while resulting in absolutely NO fault codes, NO check engine lights, and no adverse effects of any kind. All of the necessary components and detailed instructions are included and everything is designed to make installation as simple as possible.
    As of May 2009 this kit is supplied with an additional uprated spring (coded Yellow) that may be required if the vehicle has had a significant boost increase.
    Blow Off Adaptor for VAG Turbo Engines
    Yet another first for the Volkswagen and Audi Tuning Market from Forge ! With the introduction of the VAG TSi Turbo Engine, we have developed a Patented Atmospheric Blow-Off adapter specifically designed to fit this application. Simple in execution, yet offering the desirable atmospheric blow-off valve sound, this product has been designed to be fully compatible with the Bosch engine management systems employed. This is a replacement for vehicles fitted with the OEM solenoid valve part number 06F 145 710 D. As found in the 2009 onwards 1.4 and 2.0 liter vehicles fitted with the "D" version of the solenoid.
    Please note: For the twin charged 1.4 engine (Turbo and Supercharger) please see FMDV14TSi
    Replacement Vacuum operated Valve for VAG 1.8 and 2.0 FSiT
    Please See below for more information from Forge Motorsport's Website
    Many owners of any VAG vehicle equipped with the all new 2.0T FSI engine, have unfortunately discovered, that the OEM electronically controlled bypass valves, which bolts directly to the compressor cover of the turbocharger, have their limitations. If you are running increased boost pressures, after a software remap (chip), or the OEM valve is being subjected to high temperatures, the lifespan of the unit is significantly reduced. Even without any modifications taking place to the vehicle at all, this OEM valve has been shown to fail over time and it’s boost holding capacity also leaves some room for improvement.
    We now have the world’s first fully engineered solution offering both significantly improved reliability as well as valve related boost response. Our valve and installation kit replaces the original unit with a pressure/vacuum operated piston valve that still also retains the desirable OEM ECU control over valve actuation. This product has been thoroughly designed and tested with the expressed intent of offering improved valve response and maintaining ECU control while resulting in absolutely NO fault codes, NO check engine lights, and no adverse effects of any kind. All of the necessary components and detailed instructions are included and everything is designed to make installation as simple as possible.
    This product is applicable for all of the following 2.0 FSiT applications:
    VW Golf MK5 GTI/Jetta GLI, VW Eos, VW Passat (B6)
    Audi A3, Audi TT Audi A4 (B7)
    SEAT Leon
    Skoda Octavia
    For all vehicles where the OEM valve is mounted remotely (8P Audi S3, MK5 Golf Edition 30 and the Seat Leon Cupra), please see product reference FMFSITVR. )
    Parts4Euro.com NEW WEBSITE!!
    We turned off the PM option, please email info@parts4euro.com
    Subscribe our Newsletter
    Follow Us on Twitter
    Join Our Facebook Page
    Your best source for high quality European parts & accessories for your VW, Audi, BMW, New Mini Cooper & Porsche
    Sep 16 2008
    Michigan
    Re: Parts4Euro.com | EVOMS & Forge Replacement Diverter Valves for VAG 2.0 TFSI
    ON SALE!!
    Active Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A 4 2.0 TFSI Quattro
    Ukraine, Kiev
    Quote Originally Posted by Parts4Euro.com View Post
    ON SALE!!
    HI,
    I have B7 2.0 TFSI. What do you have for my car?
    ABT AS4 aero package, ABT AR type 8,5x18 ET 50 rims, F&R 15 mm spacers, ABT rear muffler, RS 4 front and rear sway bars, SuperSprint center exhaust,Cat delete and Down Pipe from Supersprint, GSG FMIC, K&N, KONI shocks with Eibach springs.
    274 HP and 389 N\M
    Sep 16 2008
    Michigan
    The above items will fit your car, we also have the EVOMS intake for your car.
    PLEASE SEE HERE
    Quote Originally Posted by DOBERMAN@UA View Post
    HI,
    Senior Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    DTM B7 Audi A4 Quattro
    Newark, NJ
    DV and Blow off spacer have nothing to do with each other correct ?
    Sep 16 2008
    Michigan
    That is totally correct.
    Quote Originally Posted by AWDTURBO View Post
    New Member One Ring TCleezy's Avatar
    Dec 19 2008
    2005 B7 A4 2.0T FWD
    Texas
    if i could only get one of the top 2 items, which one would you recommend?
    Sep 16 2008
    Michigan
    We would recommend the EVOMS one it is on sale right now.
    Quote Originally Posted by TCleezy View Post
    Senior Member Four Rings ataylor's Avatar
    Dec 15 2008
    stock car parts
    hamp
    if someone installs the BOV and then chips/flashes down the road .. problems?
    AT
    B7A42.0TQ
    mister_tu: Lion is my favorite OS
    Sep 16 2008
    Michigan
    There will not be any problems down the road.
    Quote Originally Posted by ataylor View Post
    Senior Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    Ordered my EVOMS last night! Just like the AWE but its aluminum instead of plastic. Same valve as the 997TT! BUT, I can't find any install instructions or more info. Is this that new on the market?
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Nov 02 2007
    Albany, NY
    Well,
    I have the valve now, but still no install instructions. It looks real pretty though...
    2008 Ibis A4 2.0T
    Nov 02 2007
    Albany, NY
    Anyone installed the EVOms yet? Weathers getting nice in NY and I might this weekend.
    2008 Ibis A4 2.0T
    New Member One Ring
    Oct 11 2004
    taipei
    can u install the spacer just by itself?
    Senior Member Three Rings aleicgrant's Avatar
    Jun 28 2009
    Florida
    anything for TTS?
    Jun 06 2009
    s
    I also need the Forge dv for a TTS. What is the special??!!
    Jun 06 2009
    s
    TTS Forge DV yes or no??!!!!
    Senior Member Three Rings chaldowhiteboy's Avatar
    Oct 21 2009
    San Diego/Pasadena
    anything for the mk1? maybe like the forge 007 on sale?
    Oct 21 2009
    San Diego/Pasadena
    again, anything on sale for the mk1?
    Dec 01 2007
    08 A4 2.0T
    Toronto, Ontario
    Any intake options for the TTs ?
    TT-s
    carbonino teins ss abt sp1 forge dv 35% all-around alpine w200 rs4 rear sway some chip reflashed strat ss apr exhaust - gone...
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Sep 16 2008
    Michigan
    PLEASE SEE HERE
    Quote Originally Posted by evilgabbie View Post
    Sep 16 2008
    Michigan
    To The Top !!
