Results 1 to 24 of 24
    Senior Member Three Rings dchan189's Avatar
    Jul 20 2008
    2004 Audi a4 1.8T Quattro USP
    San Diego
    Oil near spark plugs? Problem?
    Hey,
    So I was changing my spark plugs and came upon oil in and around where the spark plugs go. What would cause this? I know when I do my oil changes, I make sure oil doesn't go where it shouldn't. Will this be a problem? The car has been running fine.
    This is also the first time changing the spark plugs so who knows how long it's been in there. Any input/info would be appreciated.
    - Danny
    Sep 02 2005
    2003 B6A4
    Kanukistan
    Re: Oil near spark plugs? Problem?
    Valve cover gasket.
    :: 2012 A5 S-Line :: http://instagram.com/ur_mxrz :: mods: scratches & dents ::
    Mar 28 2008
    Northern NJ
    ^^^ X2 valve cover gasket.. just had mine replaced on my A6 back in December and the A4 after i blew a coil back last week. I noticed oil on cylinder 1 CP so i will be replacing my valve cover gasket soon. Simple DIY
    Things I am selling just PM me
    - RS4 Pedals (Automatic)
    - USP Lower Valence
    Active Member Two Rings gelkad's Avatar
    May 07 2008
    RS5,911 TTS,911TT 2010 (Sold), Panamera 2009 (Sold),R8 2008 ( sold ),RS4 2008 (sold),R32 2006(Sold)
    Saint Cloud, MN.
    Has nothing to do with the Gasket if the tip of the spark plug is oily, its probably one of the rings around the piston in that specific cylinder.
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Quote Originally Posted by dchan189 View Post
    Hey,
    doesn't sound like just the tip to me... I'll Times 3 you the valve cover gasket.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Jan 24 2009
    Lancaster
    Quote Originally Posted by gelkad View Post
    isnt that part of the valve cover gasket kit?
    Dec 28 2006
    '09 CC VR6 Sport
    Quote Originally Posted by BreakMyWallet View Post
    Yes it is:
    Still have all my hoses and check valves and proud of it!
    Stage 2 Banner Advertiser Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Any good writeups on how to do it?
    Prob need this done also.
    Podi offers free shipping to Audizine members! Use promo code AZNOSHIP at checkout!
    Dec 28 2006
    '09 CC VR6 Sport
    Quote Originally Posted by 04b6sport View Post
    Here is one from A4mods. Fairly straight forward procedure: Clicky click
    Account Terminated Four Rings
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    Yes major
    Senior Member Three Rings Jarim's Avatar
    Nov 27 2008
    N/A
    valve cover gasket +1
    B6 A4 1.8t MODS: Custom 3" to dual 2.5" Turboback Exhaust, 034 3" Testpipe, K&N Drop-in, FMIC, Hitachi Coilpacks, 007 Diverter, Neuspeed Snub, RS4 Sway, Custom Interior, Yellow Fogs
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    I had the same issue. Valve cover x2 Also, would any of you recommend changing the plugs when doing this if there was oil in them. Cyclinder 3 and 4 had oil in the spark plug recess for me. Is it necessary to replace them or should I just use brake cleaner to remove the oil and be done with it?
    || APR Stage 2 | RP K04-015 | Racetec | Neuspeed | Forge 007 | Carbonio | DTH Accessories | OEM S4/RS4/R8 Parts | '10 RNS-E | Hotchkis | Adam's Rotors | Podi | OCarbon | E-Code Headlights | Euro '02 Color DIS | Euro MKII TT MFSW | Euro Trunk | BBS LM's | Airlift | Accuair E-Level ||
    Veteran Member Four Rings maclem8223's Avatar
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Should burn off once gasket is replaced...if it's on the tips.
    ~Matt~
    BetaAlphaTauMemeber #45
    USPMemeber #1001
    04' 1.8T Q6M 2871R Revo Tuned
    Feb 05 2008
    Illinois
    your saying the oil should burn up in the coilpack area? Wouldn't that most likely cause the coilpack to fail and a misfire?
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Quote Originally Posted by jursch2211 View Post
    No only at the tip (of the spark plug) where combustion takes place... Once gasket is replaced, no more oil on plugs, oil that was will be no more it will burn off...
    ~Matt~
    USPMemeber #1001
    May 21 2007
    07 A4 Ibis White/S-line/Ti/2.0T Q
    Northshore, MA
    no hes saying if it were blow by in the cylinder and the tip was covered in oil it would burn off. i wouldnt use brake clean. just use a rag and wipe it up.
    -Nate
    07 Ibis White A4 S-Line Ti Package
    B7A4 Build Thread: http://www.audizine.com/forum/showth...58#post7310258
    WANTED: Cupra lip, FRP Relak side skirts
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    This is a valve gasket issue as many have stated. It is an easy fix. The quick fix is to retorque the existing, but this does not always solve the problem, particularly if the little cam tensioning gasket is leaking at the back of the valve cover. Follow the link provided above for the procedure and you'll see what it takes to replace all the correct components. It isn't that hard to do the entire replacement and your engine will thank you for the "leakless" results. Good luck.
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • 034 mounts • SB OFE HD • APR snub • B5 S4 binders • 18" Ultraleggeras w/ Neova AD08s • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    Quote Originally Posted by doublezero30 View Post
    Thanks...sheesh, I thought that was obvious.
    ~Matt~
    USPMemeber #1001
    Feb 05 2008
    Illinois
    I got that part but I was trying to clear up my issue. Thanks all and sorry for anything thread jacking. There's been other thread about this issue and some say to replace coils, some say don't do anything so I just wanted input.
    Oct 16 2006
    04' A4 USP 1.8T QM
    RSM, California
    If the oil is just apparent on the electrodes of the plugs don't worry about it 9 times out of 10 it's a valve cover gasket; and once replaced the oil that has built up will be burned off during the normal combustion process...
    ~Matt~
    USPMemeber #1001
    Jul 20 2008
    San Diego
    Thanks guys for all the responses. Where can I purchase a valve cover gasket?
    Sep 02 2005
    2003 B6A4
    Kanukistan
    ECS, dealer...
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Any blowby from bad rings would vaporize. As others said, it's the valve cover gasket ON TOP OF a plug that was improperly torqued and seated. Improperly torqued plugs would also cause the coils to pop up from cylinder pressure. For those wondering why their coils always pop up... torque your plugs!
    PSi Concepts, LLC
    URL: www.psiconcepts.com
    E-Mail: jeff@psiconcepts.com
    Active Member Two Rings FutureStage1's Avatar
    Dec 18 2007
    2002 Audi A4 1.8TQ
    Bozeman,MT
    Just had the same problem... Search function FTW!!
    2002 Audi A4 1.8TQ AT - Its still an Audi
    |Revo Stage 1|
