Page 9 of 13 FirstFirst ... 7891011 ... LastLast
Results 321 to 360 of 496
  1. #321
    Senior Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Re: Tuning your Motronic ECU (ME7.1)
    NM, it's back up now.
    Josh
  2. #322
    Senior Member Three Rings TWiST's Avatar
    Jun 08 2007
    2007 B7 A4 - 1969 Mercury Cougar *FOR SALE*
    Agoura Hills, CA
    I was just on the site like 10 minutes ago, maybe he hosts it and rebooted his server heh
    ECU throwing a code for you're EGT sensors? How about a o2 code from those piggie pipes? Or just looking for a custom tune? Shoot me a PM and I can help you with all you're ECU tuning needs. 2001.5 S4, 220,xxx Miles - Darintake mod w/ cone filter, 2 x 12inch JBL Dual Voice Coil, Polk Audio 1200 Watt Amp, Independent Fogs, Dual rear fogs (for brake checks ) DIY piggie pipes (coded out rear o2s) My own custom ECU tune.
  3. #323
    Senior Member Three Rings rarak69's Avatar
    Jul 15 2007
    73 Benz 450SE, 01 Yamaha Blaster
    Pittsburgh, PA
    Quote Originally Posted by TWiST View Post
    Windows 7 has a virtual XP mode for backwards compatability built in, it allows you to install a program into the virtual XP and then you can run it directly from Win 7. If you need any help with any of that stuff or changing drivers or whatever let me know bro I am a IT systems engineer and deal with that kind of nonsence everyday
    I need to read thru this thread complety as I was about to go to Neuspeed and get my ECU flashed but if I can do this myself I would much rather just invest in some hardware and or make my own stuff so I can get into tuning my car myself, it would be WAY cool
    i heard of this, however it is sill a VM at the end of the day supposedly. so it MAY be sketchy still.....
    B7 A4 2.0TFSI 6MTQ
    Pro Tuner
  4. #324
    Senior Member Three Rings NefMoto's Avatar
    Jul 02 2009
    Vancouver
    I pay $4 a month on GoDaddy.
    Forum could be faster, Wiki is slow on logging in, and there is no support for automatic backups. But it is hard to beat $4 a month.
    Plus, I don't really want to spend any time hosting the site on my own box.
    ECU flashing software should be done in the next couple weeks. Just got the installer written today. Now i just need to handle some security stuff and pretty up a couple pieces of the UI.
    For information on ME7 ECU tuning, free ECU flashing tools, and free tunes, check out www.nefmoto.com
    Please post in the forum before sending me PMs. I suck at replying.
  5. #325
    Active Member Two Rings EJB's Avatar
    Oct 19 2009
    07 R1, 10 1198R, 06 Ram Diesel, 03 KX250
    IL
    Quote Originally Posted by NefMoto View Post
    SWEET!!!
  6. #326
    Awesome news!
    I'm still waiting on my KWP2000 Plus cable :(
  7. #327
    Jan 24 2010
    2002 GSXR 600
    Ive been reading up on this for quite sometime.I am just curious if theres anyone out there as far as tuners go that still install chips? for instance why not just get a ecu socketed that way we are able to switch between chips and so on.Has anyone looked into this?or seen it done?Ive seen it on 1.8T aeb mostly just wondering if its possible on our s4 ecus
  8. #328
    Jul 02 2009
    Vancouver
    Quote Originally Posted by EuroxS4 View Post
    No one installs chips anymore. Flashing is just so easy.
  9. #329
    Jan 24 2010
    2002 GSXR 600
    yeah I hear ya there.Definitely easy.However still time consuming i would think.I just liek the fact of having a socket. and being able to swap chips are i please whenver i need to instead of hooking up a laptop and reading out the bin file back and forth.
  10. #330
    Account Terminated Four Rings
    Sep 18 2009
    Andrews
    Hey if anyone needs a KWP2000 Plus cable setup etc. I have one of the kits with all the parts I am probably going to put up for sale. Just PM me if you are interested. Need to get rid of some things before I move to Chicago!
  11. #331
    Hey I still need to get that email together for you... Just kinda dropped the ball on that lol.. been kinda busy as well.
  12. #332
    Jan 11 2007
    SLC,UT
    Where'd the drive for progress go with this? lol I was relying on you guys to figure it out so when I want to try to tune a 2.7t A6 in a year it would be laid out for me
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
  13. #333
    haha... well actually, I finally got around to installing a clean version of XP Pro on a spare laptop, and also finally got my KWP2000+ cable recently.
    So slowly I want to start tweaking a little, and I'm also looking for a deal on a 90mm Lightning MAF.
    Also don't forget to check out http://www.nefmoto.com there's lots of good info there!
  14. #334
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    I have a Galletto Flashing cable for sale if anyone is interested PM me.
  15. #335
    Jul 02 2009
    Vancouver
    Quote Originally Posted by NOTORIOUS VR View Post
    No rush on that. Whenever you have some time. I also said I would send you some stuff too. ;)
    My car is as tuned as I can get it without going on a dyno, and I don't want to go on the dyno until my data logging software has had some visual upgrades. I don't want to do one run on the dyno and spend 10 minutes going though logs.
    In the meantime I'm happy with 22psi at 12.0AFR with 8 degrees of knock retard.
  16. #336
    Jul 02 2009
    Vancouver
    Quote Originally Posted by jibberjive View Post
    It's all coming.
    Been bogged down with some crazy .NET security stuff.
  17. #337
    Sep 19 2006
    Boston
    You don't need a dyno to tune, it just simulates a flat road, just get an AFR gauge and log it you should be good.
    You don't want ANY knock, I'll try to link you to a website explaining how the decay and recovery works, it takes a long time to recover from knock, so it's just silly
    "In the event of a 15 degree KR event, it would take nearly 19 seconds for the ignition timing to be restored to pre-KR levels"
    **** http://www.stlclubgp.com/tech/kr/ ****
    Read the whole thing if you are serious about tuning
    2001 Imola Yellow Audi S4
    ~ FrankenTurbo Hybrids
    ~ALLLLLL BOOOOST
    ******K04 installs in MA starting @ $1000******
  18. #338
    Jul 02 2009
    Vancouver
    Quote Originally Posted by Nexus1155 View Post
    If I don't have a dyno, I can't determine if my changes increase or decrease power output.
    I already have a wideband AFR and my own custom data logger. That is great for good base tune, but you can't use it to determine how to tweak the AFR and timing at specific load points to make more power.
  19. #339
    Sep 19 2006
    Boston
    Dude just tune it safely, 11.1-11.5 AFR for a turbo car, 0 KR and everything will play out just fine, no need to slowly damage your engine. If you only have K04s you don't need more than that, if you do get meth or NAWZ.
    Unless I am missing something, that you have monster turbos and you need to run lean and assloads of timing so you can be hotter and spool somewhat quicker?
    And yes, all you would need is an LM-1 and EcuX in order to tune an S4 properly.
    FATS runs tells you if you are getting any faster if you are consistant at mashing the pedal the whole time.
    ~ALLLLLL BOOOOST
  20. #340
    Jul 02 2009
    Vancouver
    I already have my target AFR, and no knock. Now I am seeing where I can push the car further. Just because I don't have knock, doesn't mean I am running the optimal ignition timing.
    I would rather run on a constant load dynapack dyno, than try and do FATS runs without getting caught by the police or mowing down a pedestrian. Not to mention I can get much more consistent data on a dyno.
    And if zero knock is optimal, why are all the major S4 tuners running tunes that generate knock causing between 4 and 12 degrees of ignition retard? Not saying it is the right way to do it, but there must be some reason for it.
  21. #341
    Jul 15 2007
    Pittsburgh, PA
    everyone has knock in their tunes that ive seen on vw/audi, i know chris tapp has some in my buddies 1.8t tune when we were at the dyno logging. And he is a tuning guru in my eyes, very impressive thing's with that tune
    B7 A4 2.0TFSI 6MTQ
    Pro Tuner
  22. #342
    Jul 15 2007
    Pittsburgh, PA
    well the drive is gone because the people that started this thread and tried working on it are running custom tunes, doesnt seem like to many people were interested.
    ALL the info is on tony's site or s4tuningwiki that one could need.
    most time consuming part is finding maps, however.....there are winols files and tunerpro files for M-box, i have one for both H-box versions and M-box, and could make one for the A6 if you needed help.
    Notorious-
    you can get lightning maf's with the adapter for the air filter for like 115 shipped from various sites. start checking out the ford sites, also 034 makes a weldable aluminum flange for the hitachi maf's....if you wanted custom for close to the cost of a lightning maf
    B7 A4 2.0TFSI 6MTQ
    Pro Tuner
  23. #343
    Senior Member Three Rings skinnytirez's Avatar
    Dec 28 2007
    Lawrence KS
    I've searched the hell out of this...
    Is everyone using ECUx to do their logging? I know it isn't really supported/sold anymore, and i would rather avoid the $250 pricetag...
    Is there some comparable freeware somewhere/anyone know how to get ECUx for free?
    Thanks.
  24. #344
    Jul 02 2009
    Vancouver
    Quote Originally Posted by skinnytirez View Post
    Thanks.
    I am using my own data logging software that I wrote. It works the same as ECUx, just faster, but no nice visuals yet. I plan on releasing it after I release my ecu flashing software.
  25. #345
    Dec 28 2007
    Lawrence KS
    well i can't wait!
    What's everyone else using?
  26. #346
    Jul 15 2007
    Pittsburgh, PA
    vagcom works with ebay cable, cheapest solution, low sample rate
    B7 A4 2.0TFSI 6MTQ
    Pro Tuner
  27. #347
    Quote Originally Posted by rarak69 View Post
    Notorious-
    Hmmm... that's a good idear, I didn't even think about checking out some Ford forums and such... I'll also look into that flange, sounds interesting!
    BTW, you have email ;)
  28. #348
    Oct 19 2009
    IL
    Did you guys see that Eurodyne has the Maestro Tuning Suite that's compatible with our ECUs now? It's about $900 bucks. Worth it or not? Those of you that have been tuning with kwp2000, TunerPro, ECUx, and so on...would you do it again or go another route? I'm looking for advice as I'll be finishing my GT build soon and will need a tuning solution.
  29. #349
    Jul 15 2007
    Pittsburgh, PA
    Quote Originally Posted by EJB View Post
    well its pretty simple, ~$50 bucks for the cable give or take the prices change, or $900 for eurodyne. you make the call.
    now the software is very nice from eurodyne, screenshots on the vortex. and he sends you a base tune so you dont fubar your motor.
    to tune yourself you can use the tunerpro, or find other program out there that is very expensive, but there is a demo ;)
    B7 A4 2.0TFSI 6MTQ
    Pro Tuner
  30. #350
    Account Suspended Two Rings
    Jan 21 2010
    Lansing
    WOOT, this is sweet. got tuner pro working, opened the bin file, then opened the xdf file and it works great. Now i had a few questions though (of course) back in the subaru days of opensource tuning there was a boat load of info about what each peramiter did and everyone shared maps and ecu files often. Any chance you would be willing to share that "stage 1" tuned ecu for others to... um... analyze... lol. id love for this to be a freesharing community but some companies would get pissed if you started sharing there chiped ecu's data. If your willing to send me the stage one tune so i can look at it ;) send me a pm.
    also anyone with tuned ecus it would be sweet if we could get a big database of ecu files for various stages and mods, that way everyone could have good basemaps.
    Especially for those who want to throw some injectors on and a basemap for that, then fine tune fueling after that.
    Sharing is caring :) so share your ecu files pretty please :P not just the stock bins though ;)
  31. #351
    Senior Member Four Rings
    Sep 11 2009
    NE
    It is not that simple... You'll also need logging software (ecu explorer) which runs what, $250?. Plus CRC fixer program, that also runs some $$. I bought Maestro and the software is pretty amazing plus I got an OTC Stage 3 tune which runs extremely well on my car (Allroad).
  32. #352
    Jul 02 2009
    Vancouver
    Quote Originally Posted by boomerro View Post
    To a certain degree, that is the point of www.nefmoto.com
  33. #353
    Jul 15 2007
    Pittsburgh, PA
    wow....really wanna beg some more for everyone elses hard work. learn like we did, ask questions, no one is going to hand you a file.
    B7 A4 2.0TFSI 6MTQ
    Pro Tuner
  34. #354
    Jan 21 2010
    Lansing
    Thanks dude! didnt know there was a forum dedicated to tune! thats awesome, im glad you guys have it. This will be sweet! just like the subie days ;)
    haha, didnt know there was a lot of info on this, i just found the forum for tuning, so i will be doing my own research to find these things out. Back in the subie world people were not so touchy about their files and were happy to share. I hope some of you will be nice enough to share info like the OP has. ill be looking on the nefmoto forum now to learn about me7 specific tuning.
    i didnt mean to sound like i was begging for other files, but i just dont get why everyone has to hid all their maps. :P just my thoughts though.
  35. #355
    Jul 15 2007
    Pittsburgh, PA
    no ones hiding maps, i just wont give you MY SPECIFIC values in the maps, i would gladly send you definition files.
    B7 A4 2.0TFSI 6MTQ
    Pro Tuner
  36. #356
    Jan 21 2010
    Lansing
    ok, well i understand tuning takes a lot of work so you dont want to just share your maps for free.
    could you just help me out a bit on things. "U/min" looks like its related to revs but is it exactly RPM or some other value?
    Also in the Ingition angle map, are the values on the z-axis (values in the table) exact ignition timing in degrees? or is this an advance map? if it is an advance map, is there a basemap that it adds to?
  37. #357
    Senior Member Three Rings A4DRIVR's Avatar
    Sep 08 2009
    2001 Golf GLS 1.8T
    Goshen, OH
    I would love to see some definition files. I'm still trying to figure out what affects what... or when editing a specific map, what does a lower or high number equate to? Probably the simple stuff... yet stuff that I don't want to screw up for fear of damaging the motor.
    It's SOLD!... 2001 B5A4 QMT BAT: Used to be... My BAT Build
    "When life gives you lemons, paint that shit gold!"
  38. #358
    Jun 08 2007
    Agoura Hills, CA
    So did Tony ever release his software yet ? It's been a couple of weeks
  39. #359
    Jul 02 2009
    Vancouver
    It coming soon :)
    The Olympics really screwed up my development time. I do most of my coding on the train while commuting, and the train was a zoo during the Olympics.
    I'm just wrapping up the last piece of the code security, so I am hoping it will be another two weeks tops.
  40. #360
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    00 S4, 01.5 S4
    WA
    Yessssss I can't wait.
    - 00 Nogaro S4 - Single Turbo Project / 01.5 - Silver S4 - Stg. 3 / Five other B5s that have all been sold
    -Girodisc-BW EFR-Fikse-AMD-Stoptech-Stasis-034-JHM-Stern-Neuspeed-Dahlback-Eurogear-CPP-Group 2-
    WWU Formula SAE - 600cc's and 450lbs = Lots of fun
