Results 1 to 14 of 14
    Apr 14 2008
    '14 A6 3.0 TDI, '06 A4 2.0 Quattro
    B7 A4 Brake Pad Change Only??
    At 26k F&R pads look low, if I had no pulsing in my pedal and the rotors look v-good, can I get away with just doing a pad change? If the rotors are not in great shape can you cut them or is it best to just change them? Also, the dealer said I should wait until the warning light comes on before changing the pads, does that sound right? They look pretty low now and almost didn't pass inspection.
    Veteran Member Three Rings Latin Audi's Avatar
    Mar 18 2008
    '63 & '75 Nova
    Texas
    Items for Sale
    Re: B7 A4 Brake Pad Change Only??
    What do you mean by the rotors are not in great shape? Worn down? Im sure you can just change the pads but while you already have brakes disassembled you might as well take the rotors to a local auto shop to get turned, get some more life out of them if they have any left.
    Brilliant Red 2005.5 A4 2.0T Quattro 6MT
    APR 93 | Evoms CAI | RS4 Sway | CC | De-Badge | ECS Snub Mount | 5%| Ziza City Lights
    Veteran Member Three Rings 9Hooker's Avatar
    Feb 24 2009
    06 A4, 10 4Runner
    Virginia
    just change brake pads, no need to turn the rotors unless they look scored really... def no need to wait for the light if they look low. if these are oem pads than haven't been changed before you should be just fine. EBC greenstuff is always a good bet.
    yes if the rotors are scored for whatever reason you can just have them turned... the shop will make them even again by putting the rotor on a lathe and taking off a very small amount. again, if not damaged just change the pads.
    Apr 14 2008
    That's what I thought, I just didn't want to ruin a new set of OEM pads or have a problem with pulsation. The rotors look almost perfect. I'll try it and if it dosen't work out I'll do the rotors when the Spring arrives. What brake fluid should I use (and where's the best place to find it) if I want to flush it out?
    Feb 24 2009
    06 A4, 10 4Runner
    Virginia
    no need to flush the brake fluid unless it's starting to turn DARK. then use some dot 4 stuff. it's really all the same, hydraulic fluid with XXX temperature rating. avoid dot5 as it's synthetic and not supposed to be in the same system as dot4. i think i used castrol dot4. i would tend away from OEM pads. they're expensive for what they are. I LOVED EBC pads when I used them in my big brake kits. Greenstuff is a no drawbacks upgrade from OEM in terms of bite. I say do it!
    Also, if you are going to flush... spend the 100-150 for braided brake lines and do them at the same time. that should improve feel a bit.
    Apr 14 2008
    Bought the OEM pads at a dealer that gave me the 20% discount. I didn't know if having non OEM brakes could give me a warranty issue in the future, so just to be safe I paid the xtra $$. The OEMs were fine, the only complaint is the dust, I had to clean the wheels with a pressure washer so they could stick new weights on when I got tires. Unbelievable that we're talking about replacing tires and brakes at 26k!
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    Quote Originally Posted by dadman View Post
    My stock tires (ContiSport 2's) lasted me only 13k
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Senior Member Two Rings D-techniK's Avatar
    Feb 24 2008
    Miami Lakes, FL
    The stock Conti's are smooth but they don't last for crap. Before changing wheels I put on dunlop.. (great bang for buck) Yes stock pads don't go past 24-26k and I drive pretty laid back.
    Apr 14 2008
    Another problem, maybe a separate thread, the new Bridgestones that I got on clearance at TireRack have less of a sidewall ridge than the stock tires. With my 2 sons using the car I was hoping to still have some protection from scraping our "flat faced" wheels. Now the rim looks like it sticks out further than the tire. I'll have to research this and see if there is a tire that fits and has that hard rubber "bead" on the sidewall.
    Veteran Member Four Rings Stewy's Avatar
    Jan 24 2010
    2007 Audi A4 S-Line 6MT, 2012 F-150 Platinum 6.2L, 2003 Suzuki GSX-R750
    Vancouver, B.C., Canada
    Yep. You can definitely just replace the pads if the rotors are fine. I would advise "scuffing" them up, to help seat/bed the new pads to the existing rotors. Proper seating will avoid glazing your new pads and improve braking performance.
    2007 Audi A4 S-Line 2.0T FSI - APR Stage III GT2871R, APR HPFP, Carbonio intake, AWE FMIC, BSH CC / PCV delete, OEM "D" DV, APR downpipe, Neuspeed exhaust, H&R coils, ECS Stage 4 BBK, JHM 4:1 center diff, Neuspeed short shift, RS4 rear sway bar, Neuspeed snub mount, Defi MeterBF gauges with Defi-Link, Vag'd, de-badged, black rear valence, Cupra R lip, Huper Optik tint, RS4 grille, EU amber tails, 19" Hartmann RS4 replicas with H&R Trak+ spacers
    Jul 08 2008
    AZ
    I took off my wheel to take a peak at what tools I may need and noticed the bolts for the calipers are large toes - anyone know what sizes I'll need to replace pads/rotors so I have the right tools?
    Jul 19 2011
    Northern Minneapolis, MN
    I'm at 80k with stock rotors and they work perfect. just fyi
    [FONT=Arial Narrow]Corey - BSME
    08 A4 6MT, Quattro, VAST Stg1, JOM C/O's, 034 RSB, BFI Snub - 24.75" FTG, 255/35-18 V12's
    ------------------> Buy my wheels/tires/spacers/bolts! <------------------
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    2016 F-150 SCREW and 09 A6 Avant
    Idaho
    Items for Sale
    Quote Originally Posted by fluid View Post
    Everything you need to know: http://www.audizine.com/forum/showth...s-To-B7-Brakes
    Oh and stock rotors are 320mm.
