Results 1 to 9 of 9
    Nov 19 2007
    08 A4 Avant 2.0TQ S-Line 6MT
    Nanaimo, BC
    Help on Stock DP with Milltek Exhaust.
    Hi there. I recently came across one Milltek Exhast for sell.
    It is for the Tip Quttrao version which did not come with downpipe,
    and my car is a 6-speed Quattro.
    I am wondering if I can use my stock downpipe and will it be a directly bolt-on?
    If not, any other modification needed?
    TIA!
    Apr 15 2007
    PA
    Re: Help on Stock DP with Milltek Exhaust.
    the stock downpipe is SEVERELY restrictive. Dont spend money on an exhaust and then not follow through with a correct downpipe.
    2007 A4QM
    Senior Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Buying a used exhaust is always kind of sketchy to begin with, imo. I'd buy something that you know is going to fit and operate properly from the get go, or if you're trying to save some coin, just keep an eye out in the classifieds. There's always a few people trying to turn their cars back to stock because their leases are up.
    Justin
    DTM S4 Sprint Blue
    Nov 19 2007
    Nanaimo, BC
    Thanks for the advices!
    I know it would be better with a downpipe coming with it.
    However, currently I could only find that deal around my area.
    I am still looking for the answer if it would fit my car.
    Or it will not fit unless I get the proper downpipe.
    Thanks again.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2006 A4 S-Line, 1990 944 S2
    aftermarket downpipe is 2.5'' compared to 2.125'' oem. the oem one is not restrictive. changing to a bigger one will mean more hp up top at a sacrifice of torque down low.
    See my thread for my part out with FREE stuff!!!
    Veteran Member Four Rings D0lphinGrey's Avatar
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Quote Originally Posted by RedS-line View Post
    Hi Red, do you know if tiptronic cars have the same 2.125" downpipe or are they even smaller?
    Mar 19 2008
    i BELIEVE the tip cars have the same 2.125 size but are shaped differently cuz of the transmission taking up space down there.
    Senior Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    You loose torque in the low rpms with a larger dp? Why?
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Senior Member Three Rings 9Hooker's Avatar
    Feb 24 2009
    06 A4, 10 4Runner
    Virginia
    not on a turbo car. ever.
