Page 1 of 4 123 ... LastLast
Results 1 to 40 of 142
    Active Member Two Rings DceptvS4's Avatar
    Nov 10 2008
    Everywhere.. but nowhere
    my single turbo project
    just some teaser pics. the project should be done this year funds permitting. still im excited about it and wanted to share.
    Its pretty slow..
    Built GT40R B5 Audi S4
    Buy my car!
    Senior Member Three Rings Blue_S4's Avatar
    Feb 26 2008
    1968 plymouth roadrunner 440+6
    Rockford, MI
    Re: my single turbo project
    looks nice, doesnt it sit a little far foward??...what snail are you sporting?
    B7 RS4...mmmm.
    Veteran Member Three Rings Go_S4's Avatar
    Mar 20 2007
    2000 Audi S4
    Bay Area/San Diego
    post pics of the R33....
    Senior Member Three Rings AK1RA07's Avatar
    Dec 07 2007
    2001 S4, 1992 Miata, 1993 RX-7
    DFW
    Looks neat, but why did you choose to mount the turbo in that direction?
    Veteran Member Three Rings your daddy's Avatar
    May 29 2007
    NOW-02 337, 08 A4 Ti, 10 Tiguan sel THEN-01 S4, golf sport, 92 gti vr6,90 corrado, mk2(s)+mk3(s)
    Billerica/Lexington,MA
    Quote Originally Posted by AK1RA07 View Post
    your downpipe is nearly touching your fuelrail...
    flip the snail around.
    Senior Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    ^^^Isn't that a heat shield around the downpipe?
    Why would it be benificial to turn the turbo around?... Is it to keep the heat away from the intake manifold or fuel rails?...
    Also OP, if there is a reason for the hotside being towards to front care to explain?
    Sep 01 2007
    2000 S4
    Columbus, Ohio
    Looks just like a fat downpipe haha. Will that downpipe be restrictive or turbulent with that immediate bend or is it big enough where that wouldn't matter? I like the location for the inlet, nice cool air in there. Will a MAF fit in there or are you goin MAFless? Also the dp does look close to the fuel line and intake manifold. Any heat issues there with the manifold Last question haha what turbo?
    Senior Member Three Rings Oceanside's Avatar
    Dec 12 2008
    2001 A4
    St Pete FL
    clever
    Active Member Two Rings SlowGolf's Avatar
    Jan 17 2008
    1987 Conquest TSi, 2002 Golf, 1998 A4 Quattro
    Right Behind You
    Please wire wheel the sch 40 bends
    Jan 29 2007
    00 S4
    MD
    Quote Originally Posted by laxman851 View Post
    Looks like because of where the turbo is located, there's no room for an exhaust channel if he had the turbo the other direction. He'd melt everything around it and he still might
    APR 93 Piggies Custom True Dual exhaust AWE DTS ECS/Bilstein Coilovers 710N's Samco TBB Omori 52mm boost gauge
    Registered Member Four Rings ThirdStrike's Avatar
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    how is this going to be safe? ?
    K04|Eurodyne ME7|E85|No bitchassness
    Senior Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    Love the Pitcrew Sticker in the background. Great shop I buy all my snowboard stuff there.
    This is an interesting build, the turbo seems kinda close to the fuel rails, might want to do alittle heat wraping
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Nice job there.
    Guys, as for fuel rail proximity to downpipe, it's not completed yet, I'm sure the OP knows the relationship between a red hot exhaust, and a thin-walled PTFE / steel braided fuel line.
    Mar 01 2009
    manchester uk
    why is nobody attempting this kind of thing in the uk , i mean road stuff not satans ?
    Siena think you should do this with the 8 that would be interesting if it would fit that is
    Jan 09 2008
    United Kingdom
    Quote Originally Posted by rstyleuk View Post
    I know exactly what you mean.
    My choices for Outlaw are a single snail, or an Eaton off a Jaguar XK8/R.
    They're also 4,2L V8, so will be more than man enough for the S8 motor.
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    ahhhhhh....
    Nov 10 2008
    The engine is still in the factory location..
    Obviouspro and mholme are correct as to why I chose to have the turbo face in the opposite direction, cause theres cooler air there vice under the hood right around the block.. and something would probably melt
    Yes, the DP is rediculosly close to the fuel rails because the project isnt completed yet.. I still have a few tricks up my sleeve before this project is complete.
    Edit: Oh yeah.. im running a GT4094
    Its pretty slow..
    Buy my car!
    Nov 30 2006
    annapolis, maryland
    ever thought about how the paint on your hood would like the hot side of the turbo and dp?
    New Member Two Rings
    Oct 28 2007
    PA
    Coating and heat reflective material under the hood go a long way, I've run with a exhaust Mani almost touching the hood with no ill effects.
    I personally would have turned the turbo 90* and ran a 90* intake pipe back to the battery tray if you wanted that cold air. That would be much less restriction then the DP angle you have on there now with a more gentle bend for the DP.
    FS- Giac X Ecu $350shipped
    Senior Member Four Rings Evilevo's Avatar
    May 26 2008
    2001.5 S4 2.8L, 2012 Golf TDI w/Tech
    Potomac, MD
    Quote Originally Posted by noclutch View Post
    Ya, i was gonna say that. That 90 degree bend for the DP isnt gonna help much
    Senior Member Three Rings XSilverJ's Avatar
    Apr 29 2005
    01.5 Audi S4 Stg.III
    MA
    For some reason I feel if the turbo was mounted sideways as in the exhaust housing was facing the drivers side that it would be way easier to route everything and for some reason just be better, no?
    -01.5' Audi S4 Stg.III+ - 89' BMW 325ix - 98' Eagle Talon TSi AWD-
    http://i2.photobucket.com/albums/y24.../P42804151.jpg
    AIM: XSilverJ04 / E-Mail: KapitulJay@Gmail.com
    .:Kinesis//Status//Revo//FiberImages//Duh//Stasis//:.
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Great build so far...
    1-Dont be scare to push the limits.
    2-Dont look at comments like to much 90 bends here and there, affect the flow and all that shit... On Az people think whe are doing rocket scinece... A 90 degree bend in a down pipe or an exhaust will affect shit in your case, YOUR TURBOED, not a F1 engine N/A that needs equal lenght everything...
    3-As for fuel rail, I guess you are intelligent enough if you build this yourself to change to steel braided high temperature hose... And it wioul look a lot better at the same time...
    4- Keep it up, I love it
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Mar 13 2007
    Montreal
    Look at ringlord's setup, he spool's faster than a few k04 cars...
    Far from beeing equal lenght, centered and perfect balance between the banks.
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Rochester & Belmont
    looks real good.
    i love the idea of sticking the cold side where the battery is, it will definetly be cooler back there.
    Thor Technik
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    i like it... very very simple and straitfoward... dont need to go all out on it as long as it works well..
    similar placement to my single setup. but a little rotated
    Nogaro 01 s43.0L GT28rsfinally pounding pavementVAST300/360 untuned 13psi
    Senior Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Guru's right...don't listen to all the internet experts and e-racers...how many people on here have succesfully built a single turbo s4? yeah, exactly, not many. And how many of the people on here fully understand the physics behind building an efficient and productive turbo kit? even less. The build look sick and make sure to post a ton of pics for us.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Senior Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Like Guru said, dont listen to everybody about having a 90 bend is the worst thing. Bends have a lot less effect on flow of air then they do for a liquid. I cant prove it, but I know that the theory is correct. Plus with such a big exhaust, your retarding factor (loss of flow) is going to be small. Once you figure out something with the fuel lines, you should be well on your way. Good work.
    Oct 28 2007
    PA
    Hey I just made a statement that I felt a 90* in the intake side is less restrictive then the crazy bends in the DP; Being that the cold air is the reason he gave for the turbos position. It just seems like turning the turbo 90* would make DP fabrication easier and less restrictive and charge piping a little more direct.
    I think its a great looking project personally.
    Dec 07 2007
    DFW
    Is there any room for a filter or inlet pipe of any kind the way you have it situated or are you just going to leave it open?
    May 24 2005
    middle river
    i wanted to clear up a few things and thank everyone for the enthusiasm. we are even more excited about the project!
    1. the system is far from finished. we are making the entire fuel delivery system including the rail. that is only there for mock up. also we are making a entire new cooling system.
    2. the turbo is a gt 4094
    3. the location of the turbo is the only place we found the keep manifold travel to a minimum. the turbo is twin scroll and has a bank feeding each side of the scroll. the tight radius bend in the dp is not a problem for flow, also with this setup we can do a pipe that goes straight up and out through the hood of the car ;). the turbo itself is the biggest exhaust flow impeadment. also it was important to put the turbine section in front of the firewall. the plenem cover still fits onto the car covering the compressor housing. looks crazy with that on lol. the log portion of the manifold (3 piece manifold vband flanged) is sized 1.25 inch at the front 2 ports than upsizes to 1.5 inch at the 3rd port and continues to turbine this size.
    4. we are going to be running standalone management. no maf. air filter fits.
    5. no expense was spared when it comes to heat containment. everything will be ceramic coated minus the turbine housing. that will be in the bag. we will still thermal wrap everything as well.
    all in all this is a amazing project. i cant wait to get it started up.
    RAI MOTORSPORT
    Capital Area Unitronics Distributor
    Senior Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Exhaust is also close to coolant outlet pipes coming from heads, but you know what your doing.
    I like that kind of project. That's amazing.
    Please keep us updated.
    There's no recession where you live right?
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T Modded.
    LI,NY
    I would love to see more about Ringlord's setup with the turbo where the airbox used to be... Any threads on that? Couldn't find by his name...
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me
    Ran an 11.8 @ 119 at MIR Sept 2008.
    Mar 13 2007
    Montreal
    Quote Originally Posted by ENDEE666 View Post
    The thing is it's a Audi coupe 1991 with a swapped 2.7 single gt35R
    The frame rails are a bit wider in the front compared to a B5.
    Maf goes down between inner fender and front bumber.
    I'll try to fin a picture of that tomorow in his computer...
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Jan 09 2008
    United Kingdom
    ^^^ I guessed it was a B3-based car, was looking at the top of the fenders, and the right-hand hood catch, with metal front panel.
    Subframe was a clincher too.
    Good work!
    Mar 13 2007
    Montreal
    Quote Originally Posted by Siena View Post
    Good work!
    Looks like you know your euro cars
    look here:
    http://www.youtube.com/watch?v=2hCC2VQdxmk
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    May 04 2007
    A6 2.7T Modded.
    LI,NY
    Ah, didn't look that close to catch those things. Was distracted by the 35R on the 2.7... But that in a 91 coupe sounds SICK! Why not just have built the 5 cyl or swap urS4 motor tho? Aren't those things insanely capable?
    Nov 22 2008
    01.5 S4
    Michigan
    im gonna kill someone i cant wait to start mine !!!!!!!!!!!!
    Nov 10 2008
    Just an update for everyone whos been following my build.. Rods and valvetrain are on the way, FMIC is here, were still discussing which injectors we want to run.. once we get the motor built, we'll hopefully be starting on fab by the middle of next month
    Its pretty slow..
    Buy my car!
    Jun 24 2008
    '00 S4 Tip
    Just to answer this question... yes, they are VERY capable. I would've done exactly that (swap a Turbo I5 in) instead of the 2.7T. They are very very strong motors and cheaper to get high horsepower out of. Also sound better than our 2.7s, IMHO.
    [I know I know, blasphemy! ]
    Jan 09 2008
    2001 S4
    NC
    Quote Originally Posted by DceptvS4 View Post
    Please keep us update as often as possible.. very cool build!
