Page 1 of 3 123 LastLast
Results 1 to 40 of 101
    Feb 10 2004
    2009 A4 2.0T Sedan
    B8 A4 E-Codes successfully installed. Car washed. Photos taken. - Now with DIY!
    So here she is after a successful day of modding and washing, just in time for another week of rain. She really needed a bath though. Afterwards it was off to fetch a new battery for the camera then head to one of my favorite spots to snaps a few quick pics.
    Overall the E-Code install was a breeze, definitely easier than I remember on any of my past Audis. Further details after the photos...
    All in all I am extremely happy with the outcome. I love how easy Audi has made it to remove these housings and change bulbs. Also the fact that this eliminates all of the exterior amber on the car (no other reflectors to change out or paint as on the B7), it's just great.
    It being my first white colored car, the washing process will certainly take some getting used to. Even on a cloudy day, the reflection off the white paint was overwhelming at times. Also, dirt and debris show up in all new ways!
    Next mod due soon will be by means of another pair of parts coming from Europe, and we also hope to tint the windows in the next few weeks. Then it'll be time to play with the engine...
    In the next post below I'm going to be putting together a little DIY/How-To for getting at and changing out the housings.
    Follow Audizine on...
    Instagram, Twitter, YouTube, and Facebook
    CURRENT: '95 Ur S6 Avant | '12 A6 3.0 TFSI sedan | '08 TT 2.0T Coupe (the wife's)
    Feb 10 2004
    2009 A4 2.0T Sedan
    Headlight Housing Removal & E-Code DIY/How-To
    Here is a little How-To which may help those that are a bit apprehensive about removing their headlight housings and/or changing out bulbs. The pics aren't great since they're taken with my cellphone, but they'll do the trick.
    It's a very easy process, and is illustrated in the owner's manual as well.
    First off, a shot of the US-Spec HID LED housings and E-Code housings side by side. The most notable difference is the amber reflector at the corners on the US housings, but there's also a bulb inside at the corners as well (and not one in the E-Codes). There are also slight differences to the projector lens and beam cutoff which effects the overall light output.
    To get to all of the bolts holding in the housings, you first need to remove the upper front grille cover. This plastic over is held in place with four torx head screws, circled here in red. Once the screws are removed you simply pull up on the back of the cover and then and away from you (towards the back of the car).
    Once that is removed, getting to the two screws and two bolts securing each housing is a breeze with the proper tools. Again these are all torx heads, and the locations are shown below in red arrows. The two arrows pointing up are highlighting the two lower bolts that don't need to be fully removed. The two screws up top (shown with the downward pointing arrows) can be fully removed. You'll of course need to unplug the wiring harness in order to remove the housing, which is at the top back.
    Below you can see the back of the housings and the two ballasts that you'll be swapping out. Both are held in with smaller torx screws. One is for the HID main beam, and the other for the LED strip.
    Below are shots of the HID bulb and the front and back of the ballasts.
    And below we have a shot of the internals of the housing, with the HID bulb removed. To remove the bulb, you simply turn the base to the left then pull it out. To put the bulb back in place you insert it at a slight left tilt (Ten O'clock) then turn to the right until it clicks into place (as shown in the photo below).
    Now just be sure that all of the torx screws are back in place, then it's a matter of putting the housings back into the car. This is actually the most difficult part of the process, and will take a bit of finagling to get lined up and seated correctly. There are tracks on the bottom of the housings which need to line up with the mounting plate on the car. Once in place you'll know it, and all four torx screws/bolts can be tightened back down. Don't forget to plug the wiring harness back in, replace the upper grille cover, then fire up the car and test out your new bulbs/housings.
    If you've installed E-Codes like I have, then the very last thing you'll have to do is VAG the car in order to remove the bulb out warnings (since the E-Codes don't have the amber bulbs at the corners).
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    Re: B8 A4 E-Codes successfully installed. Car washed. Photos taken.
    I was just going to ask about the process until I read all the way through. So I'm guessing all bulbs are accessible from the engine bay, if so that's awesome.
    Past: DTM 2005.5 B7 A4 2.0TQT (sold)
    Past: 2008 Infiniti G37s Coupe (totaled)
    Past: 2007 Honda Civic LX Sedan (sold)
    Past: 2006 BMW 330i Sedan Sport (sold)
    Current: 2006 BMW 330i Sedan Sport
    Future (2013): A5, B8 S4, 335
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by Sharkfin View Post
    Well, not easily accessible, no. But all of the bolts are, which allows for easy removal of the housings.
    Veteran Member Four Rings PESAPC's Avatar
    Aug 19 2007
    B7 RS4 + B8 A4 Avant
    Looks great Anthony!
    B7 RS4 - JHM LW Clutch/Flywheel/Shifter + Milltek Exhaust + JHM Downpipes + F/R Brembo BBK
    B8 AVANT S-Line Prestige + F Brembo BBK + STaSIS Exhaust
    BOTH Singh Tuning + Ohlins Coilovers + Rear Sway Bars + Michelin PS2 + Tint
    Veteran Member Four Rings A4Ber's Avatar
    Feb 13 2007
    2010 Audi S4 Phantom Black
    San Francisco, CA
    holy shit...looks nice..i hate you Anthony! We are no longer brothers...maybe stepbrother
    2010 Audi S4 Phantom Black Prestige 6MT
    Current Mods: JHM Short Shifter, A.W.E. exhaust, Stratmosphere Intake, Ecodes with 6000K, Höen Endurance Fogs, Diffuser Painted
    News: Thinking about sellin my HRE p41 et35 and new mods next Friday~
    Forum Moderator Four Rings Blake P's Avatar
    Mar 02 2007
    Fresno, CA
    Dayum, it looks so clean with the clear corners!
    Senior Member Two Rings Wolfs9's Avatar
    Jan 08 2009
    a4 b8 avant 2.0TDI 6mt..
    belgium
    hey anth !! Nice to hear it all worked out as we hoped ;)
    The first swap in b8 history lol !! ;)
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by Wolfs9 View Post
    Thanks again, Mr. Wolfs!
    Unfortunately I'm not the first one to install E-Codes on their B8 A4, as I know at least one other AZ'er has done it already. Although I may be the first to successfully get themselves a set off a fellow AZ'ers car.
    And ya know it's kinda funny...as excited and happy as I am with this (and of myself for accomplishing the mod), and how gorgeous I think it looks, it's still just a regular old stock A4 to anyone in Europe. It won't really be unique until we get some suspension and new wheels on it.
    Senior Member Four Rings aznpxdd's Avatar
    Feb 16 2009
    2012 Alpine White BMW X1 (China)
    LA/Dongguan/Taipei
    Damn, that looks great!
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    2013 S5 Coupe
    Westchester, NY
    Nice job on the ecodes! Seeing your car makes me want to order white as well.
    Buying Adams car care products? Use "Mops10" for 10% off your order!
    Buy my laser jammer/radar detector here
    2013 Phantom Black S5, 6 Speed, Prem plus, Navigation, B&O, Advanced key
    2001.5 Nogaro S4 6 Speed (Sold)
    Active Member Two Rings g75y's Avatar
    Dec 28 2008
    Singapore
    Beautiful! Cant wait to see pictures when rest of changes go through :-)
    Feb 10 2004
    2009 A4 2.0T Sedan
    Thanks, guys. Any thoughts on the ghosted Audizine.com decal on the front plate delete? It's the first time I've tried it. Pretty subtle/stealthy, and looks cool at different angles and in different light.
    Active Member Two Rings 2007DolphinA4's Avatar
    Apr 04 2008
    B7 2.0T Quattro
    New York
    Beautiful car. Can you please post some interior shots?
    Veteran Member Three Rings amd is the best's Avatar
    Oct 05 2007
    '91 200, '01 S4, '10 Jetta TDI
    Schenectady, NY
    Beautiful car! Any pics from before to compare?
    Nick
    2013 VW Golf R
    2001 S4 - 11.80 @ 119
    1991 200 20v - 11.94 @ 115 (slipping clutch )
    www.pbase.com/amdisthebest
    www.youtube.com/amdisthebest
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by amd is the best View Post
    Nick
    Before...
    After...
    You may notice there's no bulb at the amber corners either. I still need to VAG out the warning light for that...
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    I think it looks good, very subtle yet effective!
    Oct 05 2007
    Schenectady, NY
    Thanks for the pics! Subtle but awesome mod.
    2013 VW Golf R
    Senior Member Four Rings oneohone's Avatar
    Nov 13 2007
    E30 BMW // GMT400 Tahoe Z71
    Dallas, TX
    Mmmm that looks nice.
    00' Audi B5 Quattro + 91' BMW 325is
    In.Progress - V6 Biturbo Swap (w/ K04's) + Respray - Straight Six
    -Originally Pimpman101-
    Active Member Two Rings blaxuede's Avatar
    Jan 27 2009
    Long Island
    wow that looks so much better then stock.. sorry for being so unfamiliar with the B8 platform but can you run only the DRL's w/ the fogs? as in just those two, and no headlights?
    drive it like you stole it
    Veteran Member Four Rings robots_are_neon's Avatar
    Feb 16 2004
    SoCAL
    jealous! Great Job Ant!
    Current: B8 A4 S-Line Avant
    Previous: B7 S4
    Before that: B5 A4
    ETH
    Veteran Member Two Rings VSO's Avatar
    Feb 22 2004
    Vancouver
    Quote Originally Posted by blaxuede View Post
    Yup you sure can.
    2009 A4 2.0T Premium quartz grey quattro sedan:
    APR tuned Eurocode test-pipe , FMIC StaSIS cat-back
    Forgestar F14 Titanium Brushed 19x9 Eibach Pro-kit OEM E-code Bi-xenon retrofit
    TTS Steering wheel
    Veteran Member Four Rings 10MPG's Avatar
    Oct 25 2006
    '06 AW S4 // '11 PB A8L
    Bay Area CA
    Nice and clean
    Too bad it's raining today - and I just got a full detail over the weekend too
    Stage 3 Forum Advertiser One Ring
    Feb 23 2009
    Orange County, CA
    Looks great! very clean.
    OEMpl.us | OEM Euro Audi Parts | 949-600-6111
    Your chassis: 8P | 8D | 8E | 8K | 8T | 4B | 4F | 4E | 8R | 4L | R8 | 8J
    Please PM for any questions
    Active Member Two Rings GTurboI's Avatar
    Feb 21 2009
    B8 A4 Prem + w/Sport pkg
    Denver
    I know it's a little OT but thanks for reminding me just how great looking the 18" Sport wheels are! I'm going to take my A/S tires off of my winter wheels and put them on the OEM wheels and run those for a while until I figure out what I'm going to do. Oh and BTW, the e-codes look great
    Senior Member Three Rings Castor Troy's Avatar
    Dec 17 2008
    Billings, MT
    shot with a turn signal or your hazards on?
    Feb 10 2004
    2009 A4 2.0T Sedan
    The Headlight Housing Removal & E-Code DIY/How-To has been added to the second post. I hope that it helps anyone looking to change out bulbs or housings.
    http://www.audizine.com/forum/showth...54#post3434454
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Mk2 TT 3.2 Sline, AWE Stage 3 c5 a6, 1990 CQ
    hamilton, ontario
    looks great anth!
    2008 Audi TT 3.2 S-line w/magnetic ride
    2001 Audi A6 2.7T AWE Stage 3
    1990 Audi Coupe Quattro
    2006 Audi A6 4.2 S-Line (SOLD)
    manuals only...
    Mar 02 2007
    Fresno, CA
    Re: B8 A4 E-Codes successfully installed. Car washed. Photos taken. - Now with DIY!
    I lowered Anthony's car today with the PS coilover kit. The drop looks good and it drives the same as stock!
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    DTM S4, B6 USP (DD), B5 1.8T (RIP)
    Fremont, CA
    tell me you have a shot against the wall or something before/after..if/when i go B8 ecodes are going to be one of the first things i do..just like i did in my b5..b6..
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Senior Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    awesome car
    two thousand two audi a-four quattro five speed
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    off topic, but while pulling the lights, could you tell if the grill is removable without pulling the bumper? kinda looks like it might be from the pic showing removal of the cover
    Current: '12 4dr GTI Autobahn, Black on Black
    09 A4 2.0t, premium +, black on black, sport, nav
    Old: 07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    03 a4 3.0qms, thermal exhaust, hyperflow, neuspeed sport, neuspeed bilsteins, h-sport (s4) sways, b&m ss, votex lip, s4 blades, rs4 reps, ecodes, rs4 pedals, 35% tint
    Older: 2000 A4 1.8TQ, bilstein/hyperco, apr, blah blah blah
    Feb 10 2004
    2009 A4 2.0T Sedan
    Ooohhh that looks good, even on the stockers! Thanks for the PS.
    Quote Originally Posted by oatzel View Post
    Sorry but I didn't look.
    So the other parts arrived today from Europe. New thread coming in a bit.
    Veteran Member Four Rings minira's Avatar
    Feb 13 2004
    '01.5 A4, 07 Q7, zx6r
    chino
    damn anth, very nice as always. can't wait to see the new parts.
    Senior Member Two Rings AUDITOPGUN's Avatar
    Aug 16 2007
    VW GOLF R
    wow awesome mod whats next?
    Senior Member Four Rings B6bomber's Avatar
    Jan 05 2009
    05 B6 S4; 98 Nissan Altima
    LA area, Back in Simi
    That looks awesome, I was debating a B8 but I decided that I didn't want a brand new car. Maybe in a few years I will see.
    Veteran Member Four Rings Agent Kitten's Avatar
    May 14 2007
    A6
    Santa clara
    Re: Headlight Housing Removal & E-Code DIY/How-To
    Interesting. I have a car like that. Too. Looks like the same mods on mine too.
    Mrs. Audizine
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by AUDITOPGUN View Post
    Well we were going to tint the windows but it's up to the woman. It's her daily driver. If she's still up for it then software, suspension, and wheels as well.
    Would also like to pick up the LED S4 tails as soon as they're ready. Waiting on Rich @ OEMPl.us and Kufatec.
    Sep 11 2004
    2013 S5 Coupe
    Westchester, NY
    I was actually going to comment on that in my first post but I forgot to do it. I like the way it looks and i think thats an awesome spot for it. Like you said its subtle but you can still see it which is cool. It actually looks redish in that side shot. Is that just the way it came out in the pic?
    Jan 18 2008
    TX
    Is there any other mods needed to go from non-projector to the e-codes besides vag-com?
