Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
Thread: B6 Dyno Thread
  1. #41
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2004.5 A4 1.8T Quattro 6 speed
    Montreal, Canada.
    Quote Originally Posted by reapersa4 View Post
    No beef, thank you for clarifying. You are very thorough.
    No problem, I'm glad I cleared up the confusion.
    The 1/4 mile in 13.3 sec. @ 107.3 MPH! Possibly the world's fastest K04 motorized A4 power by MTM (that was then...)
  2. #42
    Senior Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    Brampton ON
    2003 Audi A4 Quattro Avant
    Frankenturbo F4h-l
    W/m injection
    034 3" cat with 2.5 exhaust
    Unitronic 2+
    Stock Intercooler
    Need some work done on your VW/Audi in the GTA? Former VW/Audi tech. Send me an IM, let me know what you need. Timing belts, brakes, etc... Quality work, save money.
  3. #43
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2003 2.0 PTE 5857 B6 A4 quattro 5spd, 05 E55 AMG
    Jacksonville, Florida
    2003 quattro 5 speed
    2 liter, aeb head, Schrick 252/260 cams
    Cat valve springs, Supertech exhaust valves
    Apikol intake manifold, 70mm throttle body
    Precision 600hp core with 2.5" piping
    Psi Concepts T3 turbo manifold, Precision 5857 .63 a/r
    3" downpipe and exhaust to the 2.25" split at rear (what is left of a Neuspeed exhaust)
    Unitronic 830cc incomplete beta file, 830cc Lucas injectors
    B5 A4 rising rate fuel system with adjustable fuel pressure regulator running static fuel pressure ~4.5 bar
    Snow Performance methanol injection with 625cc nozzle (8" from the throttle body) spraying -20f washer fluid
    437whp 394wtq at 31psi on 93 octane and "meth injection." Stock B5 S4 with K&N filter did 204whp 222wtq on this dyno.
    ~David~
    I can help you with your 1.8t work (timing belts, etc)
    2.0 Billet PTE 5857 A4
    Those who say it can't be done should get out of the way of those who are doing it.
    119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
    527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
  4. #44
    Active Member Two Rings -03 tq's Avatar
    Jul 25 2009
    b6q 372kw / b5 timeattack
    FIN
    1.8, NA cams, diy manifolds, 70 tb, aeb head, inconel valves, Ti retainers, springs, wiseco 82, eagle rods, tial38, holset hx35 54/60 #16, returnline, 005 pump, ev14 1000, oil cooler etc etc. Motronic tuned.
    506 was on 101-102 oct mix of carless FIA fuel and v-power/xylen mix. Maybe there were some left to have, tuning was aborted as soon as 500 was achieved..
    b6 1.8tq 506hp/548nm
    b5 timeattack car "redbull"
  5. #45
    Oct 21 2005
    y
    ^did I just read that right. 1.8L - 500awhp (based on km/h on dyno sheet), full boost by 4300rpm? Or is this CHP (which is still great)?
    And I thought the 1.8 NA cams were exactly the same as the 1.8t? Even the euro 1.8na.
  6. #46
    Jul 25 2009
    FIN
    They have slightly more duration and about 1mm more lift. Imo they work great at top and help spool too, They are ADR cams. On the road its full boost 3800-4200 actually :) We dont use whp. Aiming for 600(+?) with another higher comp engine and hx40#18 using E85. Timing was about 11 on e98 and 15 on racefuel.
  7. #47
    Active Member Three Rings bondar1989's Avatar
    Oct 16 2010
    03 B6 A4 TQM
    Long Island, NY
    My car: 2003 B6 A4 1.8TQM 5 Speed 95k miles
    - Fresh cylinder hone, Freshly milled cylinder head with new valve seats, new valve stem seals, new cam seals, and new piston rings. Compression is 190 on all 4 cylinders.
    -New head gasket, new red top coil packs, new spark plugs, Timing belt done.
    -Stock K03, Spikes 22psi and holds 19psi
    -APR Stage 1+ software with TT225 Injectors
    -AWE Tuning Exhaust with test pipe
    -K&N Cone Air Filter
    -Forge DV
    A whole lot of stock parts replaced. This car is running at it's best right now.
    Here is my graph from the Dyno day at ICS performance on Oct. 23 2011
    This pull was the best one of the day. I am happy with the number's considering what I have done to the car. Very nice low end torque.
    This pull was only held out to 5500rpm. the turbo is on its way out. You can see on the graph how it's slightly choppy.
    198WHP / 248WTQ stock engine. stock K03. APR Tune. AWE Tuning Exhaust w. Testpipe. K&N Cone Filter. Forge DV. B5 A4 1.8T Trans. JOM coilovers. B5 S4 Wheels. 11mm Forge spacers. Painted Lowers. 4500k HID's. Track density engine mounts. APR Snub mount. Apikol Trans/Rear Diff mounts. Engine Refresh(cylinder hone/piston rings)
    BT Build Coming Soon...
  8. #48
    Active Member Two Rings AWDxTY's Avatar
    Nov 07 2011
    Fayetteville, NC
    MORE GRAPHS PLEASE!!! I need help deciding which direction I wanna go
    B5 S4 brakes/ Hawk HPS pads, apikol snub
  9. #49
    Active Member Two Rings A-FourLO's Avatar
    Dec 28 2011
    A4 3.0 6-speed M/T
    miami
    2002 A4 3.0 6-speed, Converted to FWD. Dynojet SAE corrected Sea level
    2002 A4 3.0 V6-6speed converted to FWD :)
    (Current): 185fwhp/177fwtq
    9.930 @ 72.1mph 1/8th mile
    20-55mph 2nd gear street test 6.2s
    (Stock): 156awhp/182awtq
    10.369 @67mph, 1/8th mile
    20-55mph 2nd Gear Street Test 6.6s
    Dynos & Progress Thread
    http://www.audizine.com/forum/showth...rogress-thread
