Results 1 to 40 of 42
    Senior Member Two Rings mystro's Avatar
    Apr 29 2005
    Woolrich Pa.
    If a coil pack fails, is the dealer suppose to replace all of them??
    My parents called me from there vacation and their 2006 Audi A6q is in limp mode. They limped the car 1000 miles to their destination. (Audi road side service was a joke).
    The local Audi dealer found one failed coil pack and replaced just the one. Are dealers suppose to replace all of the coil packs when only one fails??
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: If a coil pack fails, is the dealer suppose to replace all of them??
    Not sure if it's a rule to go by but they replaced all 8 on mine and I've heard a lot of other people having theirs replaced as well. They probably don't have to.
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    to get it to run i'd just replace one, and the rest asap.. but i'd be more concerned with them driving 1000 miles with a dead coilpack.. not good for the cat..
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Quote Originally Posted by mystro View Post
    Apr 29 2005
    Woolrich Pa.
    They had no choice. It was on a Saturday and "Audi Road side protection was a joke" They did nothing other than to tell them that no Audi dealer service was open until Monday. I got them into the Audi brand 15 years ago and this is the second time Audi Roadside service has failed in a emergency situation. I will probably put them into another brand when this A6 goes. They love the car but Audis service and dealer network are going to kill the brand.
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    yea its bad to drive the car with a bad coil pack
    daworldisyours.com/forum<----check it out!!!!
    Veteran Member Four Rings bsrpilot44's Avatar
    Feb 25 2007
    B7 S4
    So.Cal
    Do us all a favor and forward this to AoA...that's 100% unacceptable...limping a car for 1000 miles...
    Not only is bad for the vehicle, it could present a significant hazard toward the well being of it's occupants, over the course of 1000 miles...ie: cut off...floor the vehicle...no power.
    Good luck,
    -B
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    No, it is up to the individual dealers whether they will replace them all or not. I've had 2 fail so far and they only replaced the failed ones. They stated that "this isn't common with the V8 S4's (yeah, ok) . . . if it was a 1.8t, they would've replaced them all since there was a TSB out on it." It all comes down to money. They could go ahead and write it off as a warranty repair and forward the bill to AoA. AoA, however, can turn around later and do an audit saying that the other coilpacks were still good and did not show any codes. Therefore, the dealer has to pay AoA back. They don't want to risk loosing money so they only fix the ones showing a code.
    /S4
    AWE l Koni l H&R l Hotchkis l VMR l LEDs by fly
    Registered Member Two Rings
    Jul 14 2008
    il
    what is limp mode?
    Feb 12 2004
    2016 BMW M3, i3 REx
    Orange County CA
    They know they could have had it towed home right?
    BMW F80 ///M3
    BMW i3 REx (Daily Driver)
    Former:
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Follow me on Instagram: Raging_F80
    Mar 01 2008
    Quote Originally Posted by JMG View Post
    free up to 25 miles then they have to pay the rest of the way
    /S4
    May 31 2005
    Northeast
    I was just mentioning this last night on Audiworld.....
    I had 2 fail after the first week I had the car back in May of 05, after washing the engine bay (new car dust haha)... They replaced the 2 at that point... Then again 2 years ago another 1 went bad (same reason) and at that time they went and replaced all 8 stating a TSB which noted this is a problem and installed 8 newly designed coilpacks specifically designed to fix water intrusion... (I guess the rubber o-rings are better)
    .. anyway, they say driving a couple hundred miles on misfiring cylinders "isn't going to hurt anything".... but 1,000? I don't know if I'd like that...
    Jul 14 2008
    il
    how can you tell if coil packs are bad?
    Mar 01 2008
    Quote Originally Posted by theking View Post
    oh you'll know. your check engine light will start flashing and the engine will run rough and your car will feel like it's shaking and sputtering. there's also the loss of power. that's what normally happens. my first coilpack, though, completely fried, melted the wiring harness and the car just died and wouldn't start back up.
    /S4
    Established Member Two Rings nycats4's Avatar
    Nov 13 2008
    04 s4, 01 se-r
    nyc
    If you have a failed coilpack and know exactly which one it is, just swap it out individually with each of the other good 7 cylinders and start engine after each replacement. After that all cylinders will throw the code, then the dealer will replace all. Just my 2 cents. Man I can't believe the car lasted 1000 miles in limpo mode.
    Apr 29 2005
    Woolrich Pa.
    My parents were 250 miles away from home and 1/4 way to their vacation destination. Towing was not a option and after Audis horrible road side service I told them to just drive it as far as they could safely. As long as you were gentle on the accelerator pedal it would maintain 65mph. The car has another 2 years warranty and if the car gets damaged in the process, Audi will fix it. Its tough to talk your parents through a situation like this on their cell phone. We all agreed that Safety first, car second.
    Established Member Two Rings RocC4S's Avatar
    Dec 03 2007
    '10 VW GTI, '10 Audi Q5, '03 Ferrari 575M, '87 Alfa Romeo Milano Verde
    Mercer Island, WA
    I agree the timing of the failure couldn't have been worse, my sympathy goes out to you. Unfortunately, Audi Roadside is only capable of three things: flat tire, fuel, and jump start. It is not a rolling repair shop. They should have offered the trip interruption and fixed the car locally where it failed.
    Senior Member Three Rings Cyrix9445's Avatar
    Dec 05 2006
    2004 S4, 1995 Wrangler
    Orlando, FL
    Quote Originally Posted by ...Mark... View Post
    haha love it, tom delonge rules
    2004 Sauce4
    Established Member Two Rings AudiBenz's Avatar
    Mar 04 2007
    05 S4 Avant
    Foster City, CA (Bay Area
    Nope. Only the ones that fail
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Here is what road side assistance is capable of: http://www.audiusa.com/audi/us/en2/e.../Services.html
    Here are the benes they should get: http://www.audiusa.com/audi/us/en2/e..._Benefits.html
    They certainly qualified for trip interruption (more than 100 miles from primary address):
    • Lodging up to $100 per day
    • Meals up to $100 per day
    • Alternate transportation up to $100 per day
    I just went through the coil pack thing last week. I had three fail and the vehicle was towed 2x to the dealer. When I asked why they don't do all of them I was told that only the failed ones are replaced. Cost Audi a bucket of money since all quattro cars need flatbed towing. SA showed me the tow bill for $500 each tow (about 10 mile tow.) Audi and the customer are losing based on this policy. I pay $50 co-pay and Audi gets billed by both the tow company and the dealer.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Mar 01 2008
    ^ sounds like a formal complaint is in order.
    /S4
    Mar 01 2008
    Quote Originally Posted by FastB7S4 View Post
    Nevermind, after reading, it sound like when you call Roadside Assistance, you have to ask and get pre-authorized for Trip Interruption. Doesn't sound like they will just offer it to you. Seems like it is up to the owner of the vehicle to know what he is/is not eligible for.
    It is probably too late now to be reimbursed for anything since it is after the fact and the OP's parents did not get pre-authorization.
    /S4
    Apr 11 2008
    Pasadena, CA
    FYI - Audi isn't really running the program they contract out to Cross Country Automotive Services. http://www.crosscountry-auto.com/ (It's in the fine print at the bottom of one of the web pages)
    Guess if we all complain enough they could look for a new vendor...
    The Avant Garde
    Mar 01 2008
    Quote Originally Posted by ChronicTeutonic View Post
    Wow, that's a rip-off! $500 for 10 miles? I had mine towed from my house to the dealer 31 miles away. Audi covers the 1st 25 miles and I had to pay the difference. Tow company only charges $4/mile so I ended up paying an extra $24. Audi must've paid $100 for the first 25 miles, probably less since they probably have cheaper contracted rates.
    /S4
    Veteran Member Three Rings road race s4's Avatar
    Jan 03 2009
    camry
    what is limp mode?
    http://www.grego.ca/limp.htm
    May 31 2005
    Northeast
    You know... I never ended up doing it... but I always thought it'd be a good idea to stow away 2 new coilpacks in with the spare before a long trip.... The first 6 are simple to remove with just the right torx bit.... and if you had a spare, it would make things a loooot easier! Nothing like feeling like you're driving a broken down POS... and good luck just picking up a coilpack for your car at AutoZone hahaha.
    .. They're expensive from your dealer, but ECS has them for a decent price... deffinately better than getting your ass towed or having to drive 30-40mph on a 400 mile trip!
    Registered Member Three Rings DuncanC's Avatar
    Oct 07 2008
    Visit me on EuroAddiction.net
    Edmonton, AB
    The dealer only did the one when it blew in my 3.0l.
    Mar 01 2008
    well, looks like i'm getting towed back to the dealer friday morning. blew my 3rd one this evening. i texted my service advisor there and he told me that definitely they will replace the rest this time under warranty. i hope he's not b.s.'ing cause the tried to get them all replaced last time, but the service manager wouldn't do it.
    /S4
    Veteran Member Four Rings Silver B6 S4's Avatar
    Dec 08 2008
    2003 PT Cruiser GT Stage 2
    Petaluma, California
    When I purchased my CRX, it wasn't registered for 2 years. I called a towing company to flat-bed it to my house 35 miles away from where the car was. They quoted me $150, I said thats fine. When they dropped off the car(10:30pm) I offered the driver and his wife a beer(they accepted). We bullshitted for 20 minutes, and when I asked how much did I owe him for the tow, he said $75!
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    One of mine jsut failed, they are replacing all of them despite the fact that only B5's are the current "wave" in this massive recall.
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Senior Member Three Rings MonkeyBiz's Avatar
    Feb 27 2009
    Nashua, NH
    So you're saying that there wasn't an Audi dealer within 1000 miles of where they were when the coil pack blew?
    Assuming there was a dealer near(ish) to where the incedent occurred, couldn't they have the car towed to the nearest Audi dealer and have them replace the 1 coil pack fairly quickly?
    As opposed to going to the Audi dealer nearest to their destination...and driving 1000 in limp mode.
    2004 B6 S4 6-Speed MT - Black w/Alcantara
    | ~ JHM ~ Magnaflow ~ Hotchkis ~ Hawk ~ Hankook ~ Hartmann ~ more to come...|
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    If Audi is paying for it (still in warranty) one coil pack.
    If you are paying for it (out of warranty) all of the coil packs.
    LOL
    Veteran Member Three Rings justinperkins's Avatar
    May 14 2009
    B6 S4 Avant & C5 A6 Avant Q
    ATX
    Quote Originally Posted by B7 Projectile View Post
    fyi, this thread was created well before the recall and also no, the B5 is not the only chassis affected by the recall
    the recall works like this:
    - you have a coil pack failure, dealer will replace all coilpacks for free
    - dealer will not replace your coilpacks until at least one fails
    - you can replace them yourself and then bring an invoice for the parts and they will reimburse you (though you should confirm beforehand)
    -justin
    Feb 27 2009
    Nashua, NH
    Not true...I got a letter from AoA a week ago regarding the coil pack issue.
    B6 S4 here...
    In, Out and Around...
    if the car does not fall under the recent 'action' (aka recall) then yes that is protocol... however if it falls under the new 'action' then all will be replaced with the revised coil packs.
    Registered Member Four Rings Auditude2.0T's Avatar
    Jan 01 2008
    Long Island NY
    This is completely unacceptable i would definitely without a doubt contact AoA and maybe they can do something for your parents man.. You would think for spending 50+K with a company they would support you a little better than that....
    May 14 2009
    ATX
    Quote Originally Posted by iconoclast View Post
    it's an old post, before the recall, so just replacing the failed coilpack is completely fine
    -justin
    ah i missed that, thanks justin.
    Dec 17 2009
    MA
    FWIW, I noticed some lag in the throttle about a year ago, was scared to change lanes because the engine wouldn't respond as expected. They diagnosed it as coil packs and replaced 3 of them. Never a peep out of the idiot lights on the dash or info screen, which is especially annoying considering every time I get a dipped headlight it's like a missile alert at NORAD, but there's never a code in the computer when the dealer checks...hmmmm.....
    Anyway, was in for some other minor issue a few months later and didn't even mention noticing a problem and when I got the car back was told they went ahead and replaced the other 5. All 8 at no charge to me. Car was still under original warranty, under CPO now and I just got the letter from AOA, so I'm having them check them tomorrow.
    Feb 22 2008
    B5 a4 sedan&avant, c6 a6 avant,99 Chevy 2500 plow truck, 67 c-10
    ma/ct
    Items for Sale
    to clarify weather or not all of the coils should be replace, if the coil is causing a missfire the coil will be replaced. also there is a list part numbers that audi considers good coils, all others should be replaced even if they are not missfiring. this is aplicible weather or not the car currently has the recall open.
