Just did mine last night.
Once everything is apart, you have to de-solder about 50 points that are about 1 mm wide. There is a product called QuikChip to help remove the old chip and it does work, but can make a mess. You got to be really sure you clean up the excess solder it dumps so as not to short anything. If I were to do it again, I would buy an inexpensive hot air rework tool. Re-installation was not easy.
I have alot of experience with electronics and trying to get all those points soldered properly took patience, a new .07 tip, a magnifying lamp (old eyes) and a few attempts. Whole process of removal and re-install of chip about 1hr, 45 mins. I can tell you I destroyed the old display upon removal and can see how you could damage the new one easily. Not for the faint or heart or those with little soldering experience. I figured I saved $100 over having it repaired by
www.ModuleMaster.com. You need to decide if it is worth it.
FYI, I tried the heat trick on the ribbon cable and the pressure trick on the display edges and neither worked. When I looked at the ribbon cable with a back light, I could see points where the cable had come apart. I can not see how it could be fixed without creating jumpers over the broken parts. Considering those "wires" are hair thin, it is doubtful anyone could repair.
