Results 1 to 10 of 10
    Senior Member Three Rings A4 Dream's Avatar
    Sep 01 2008
    B5 A4
    Tacoma, Wa
    Exclamation How Do I Replace rack and pinion?!
    title says it all... I havent driven my baby in about a month because of the rack and pinion leaking. I havent had time to work on it until now. I actully just found out that it was leaking.. I knew I had a leak but couldnt find it without a little help.
    Now.... how do I replace it? Some one have a site to tell me? Or wanna give me some tips...
    thanks. I NEED HELP ASAP!
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: How Do I Replace rack and pinion?!
    if i remember correctly, there are 3 10mm 12point bolts. you will need a 12-point 10mm swivel socket for the bottom one, but it is very helpful for all of them. basically, you need to raise the front, remove the wheels, disconnect the tierod ends using a 13mm and 16mm sockets/wrenches. air tools and anti-rust spray help a lot too.
    there are 2 of the said 10mm bolts that face up. these are in the cowl area near the brake booster and battery. the third bolt comes from the underside, and you need to access from either the heatshield area from up top, or from underneath the car. it is on the drivers side.
    you will also need to remove the drivers storage compartment (under dash panel), and disconnect the rack from the column.
    there are also the 2 fluid lines (best to loosen these before removing the 3 10mm bolts). 19mm and 17mm iirc. make sure to bleed your power steering afterwards. and you will also need an alignment after transfering the tie rod ends.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    Registered Member Two Rings
    Apr 15 2009
    Michigan
    how do you know what rack and pinion you have. i found some rebuild kits for a 96 a4 quattro and they have a z.f. type kit and a cabriolet type kit. any info would help...thanks
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    i think theres a zr type and a koyo type. I'm pretty sure they are interchangeable but you might want to double check. I know the difference is one has a damper while the other doesnt. Its not a bad DIY but would take some time.
    Gotta take off knee bolster and disconnect steering column.
    Take off tires and unbolt Tie rod ends
    Then you have i think 12pt 10 mm bolts. One is by the brake booster and the other is under the battery.
    then you unbolt the 2 lines and you should be able to pull it out through on of the wheel wells. theres a plastic cover you might have to remove but not too bad.
    i did it my first time in about 2 hours by myself. that includes removing the old one, replacing the new one and bleeding the system.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Jun 30 2008
    Erie, Pennsylvania
    I've never done it, but here is a DIY article I ran across:
    http://audi-diy.blogspot.com/2007_10_28_archive.html
    Good Luck.
    Senior Member Two Rings pja0750's Avatar
    Jan 25 2007
    B5 A4 1.8T, 56 Ford Customline
    plymouth, minnesota
    mines leaking to and its about a 2 hour job in a shop but id add 2 more hours someone that hasnt done it before
    B5 A4 1.8TQ, soon to be BAT set up
    Apr 15 2009
    Michigan
    Thanks all the feed back will help out alot. I'll let you know how it goes
    Veteran Member Three Rings spyder101's Avatar
    Jan 25 2009
    some where in the U.S.
    Don't forget to align the car when your done.
    Veteran Member Four Rings savetheclutch's Avatar
    Oct 01 2006
    ducatis and a miata
    Fort Lee, NJ
    Items for Sale
    where are you guys going to buy yours?? I need one ASAP :(
