Results 1 to 33 of 33
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Seat back repair
    Has anyone ever used the Audi seat back repair kit part# 8E0-898-470? How do you install them?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Seat back repair
    What came in the kit, two black clips and some glue?
    Mar 21 2006
    Lakeland, FL.
    Three different style clips, none look like the ones on the seat back itself.
    I'm back bitches!
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    They slide into the mounts where the old clips broke off. The toothed edges snug up to the inside of the depression in the old mount. They press-fit in.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944
    Mar 21 2006
    Lakeland, FL.
    I have red, orange and black clips.
    I'm back bitches!
    Oct 01 2007
    Too small
    N/A
    Mine were bare metal, stainless it looked.
    1968 Charger R/T
    1987 Porsche 944
    Mar 21 2006
    Lakeland, FL.
    Mine are plastic.???
    I'm back bitches!
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    this is the lumbar fix kit?
    i thought you already did that with your new DIY?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    x2 the clips on the bottom are platics and they just broke off the three up top are metal
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Mar 21 2006
    Lakeland, FL.
    I did my own lumbar repair. I'm talking about the seatback repair kit from Audi.
    I'm back bitches!
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by dirtybrd View Post
    oh, im not aware of a seatback issue.
    what's wrong with your seatback.
    sorry, i have to helpfull info. im just curious as to what you are dealing with
    Current:
    Previous:
    Mar 21 2006
    Lakeland, FL.
    When the lumber goes bad it'll break the seatback clips.
    I'm back bitches!
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    So that's what happened to my seat back... Shit.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Mar 21 2006
    Lakeland, FL.
    If it popped off out of no where, then yes.
    I'm back bitches!
    Oct 01 2007
    Too small
    N/A
    My bottom clip replacements were metal, and had toothed edges that bit into the plastic when pushed into the cavity from the old clips base.
    1968 Charger R/T
    1987 Porsche 944
    Mar 21 2006
    Lakeland, FL.
    Odd, maybe I got the wrong parts?
    I'm back bitches!
    Oct 01 2007
    Too small
    N/A
    Perhaps there's two kits? Or maybe you have a newer revision? Though I can't see why they'd go with glue and plastic over the metal replacements.
    1968 Charger R/T
    1987 Porsche 944
    Mar 21 2006
    Lakeland, FL.
    Don't know, will check into it.
    I'm back bitches!
    Veteran Member Four Rings Raus's Avatar
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    In a write-up I read here or AW, the repair kit was plastic clips and glue.
    I just used 1/8"x1" aluminum that I had around and attached with nearly invisible black screws from the seat back.
    Ich bin der Musikant mit Taschenrechner in der Hand
    Aug 26 2005
    Yeah, sounds like the wrong kit. The kit I used, is two metal hook inserts that fit the plastic bases glued to the seat back at the factory. (The base pads of the broken hooks) There are also two pieces of felt that are applied to the seat sheet metal where the new metal hooks engage to prevent squeeks. See link for write up. Kit PN 8E0 898 035. http://forums.audiworld.com/a4gen2/msgs/915544.phtml
    Mar 21 2006
    Lakeland, FL.
    I got PN 8E0 989 470. I guess the wrong part was ordered.
    I'm back bitches!
    Feb 17 2008
    where do you get this kit?
    Veteran Member Three Rings infinitigor's Avatar
    Jul 17 2008
    02' b6 1.8t
    Quote Originally Posted by Mike02A4 View Post
    same here, my whole back of my seat is popped out, ppl in the back always say, hey ur seat is broken soo annoying
    Aug 26 2005
    Any Audi Dealership. Or online at http://www.genuineaudiparts.com/ and enter (copy>paste) part number 8E0 898 035 in the search by Part number field.
    Aug 26 2005
    Checking that PN online shows: 8E0898470 Seats and tracks - Rear seat components - Seat back cover - Mount kit
    Just FYI.
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    Quote Originally Posted by infinitigor View Post
    Your lumbar support broke, you'll need to fix that first.
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    Items for Sale
    The back of my seat popped off also, but my lumbar support seems to be working just fine? Am I missing something here?
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    Quote Originally Posted by nein-reis View Post
    It usually breaks on one side at a time, have you removed the seat back cover to see that it's fine?
    I didn't see any way for the seat back to pop off with a good lumbar support but you never know.
    Feb 01 2008
    SLC, Utah
    Items for Sale
    Hmmm I'll have to investigate further. But it adjusts and feels just fine.
    May 24 2007
    Southern California
    How do you get the seat back off? Just yank from the bottom?
    Kyle
    2.0L Revo GTRS Eliminator
    Oct 01 2007
    Too small
    N/A
    That's one way to do it, but you'll break the clips doing so. If I remember correctly, you pry it out at the top and lift.
    1968 Charger R/T
    1987 Porsche 944
    Aug 26 2005
    Quote Originally Posted by nihil View Post
    Confirming you remember correctly
    May 12 2012
    Boston, MA
    Audi Seat Back Repair
    The cost of the seat back repair kit was $50, so I fixed the problem myself. Here is how:
    1. With the seat back cover off, place a block of wood (approximately a foot long, 1/2 thick, and about 2-3 inches wide) behind the two tabs at the bottom. Make sure height of wood does not interfere with lumbar support movement.
    2. Use two screws to secure the block of wood. Screw through the two tabs and into the wood. This secures the wood behind the tabs.
    3. Replace the seat back cover.
    4. Use a third screw (placed at bottom center of seat cover behind mesh) to secure the lower part of the seat back cover to the block of wood you attached above.
    You will see the third screw if you are sitting in the back and looking at the floor.... but this fix saves you $50 and it works well.
