Results 1 to 40 of 48
    Registered User Four Rings Issam@INA's Avatar
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** 1.8 to 2.2 STROKER KITS - Increasing your displacement - KITS,TECH & FAQ ***
    PSA : PLEASE USE THIS THREAD TO ASK ANY AND ALL QUESTIONS YOU MAY HAVE ON YOUR MIND.WE PRIDE OURSELVES ON KNOWLEDGE SHARING SO DO NOT HESITATE TO ASK (no matter how dumb YOU think the question is.)
    Since the introduction of the 1.8T engine in North America,sourcing stroker kits have been limited to 1 source.
    Fast forward a couple of years and we are now able to offer you every possible configuration that your heart desires :cool:
    Combinations range all the way from 1803cc's to 2190cc's!
    1803CC KIT - MAHLE PISTONS
    This is the introductory level kit for those of you who want to do a simple hone on a tired block.This kit includes Mahle Pistons which are superior in design & construction when compared to anything else on the market.
    Kit includes:
    (4) - SCAT 144mm/20mm Forged Connecting Rods
    (4) - 81.5mm Mahle Forged Pistons w/ 9:1 Nominal Compression Ratio
    $999.99 + Shipping
    1803CC KIT - JE PISTONS
    This is the introductory level kit for those of you who want to do a simple hone on a tired block but with the more affordable JE Pistons.
    Kit includes:
    (4) - 81.5mm JE Forged Pistons w/ 9:1 Nominal Compression Ratio
    $969.99 + Shipping
    1870CC KIT
    For the user looking to really *open* up his block.Very popular kit amongst those users looking to increase displacement without changing the stroke.
    Kit includes:
    (4) - 83mm JE Forged Pistons w/ the following choices of nominal compression ratio:
    * 9.5:1
    * 9:1
    * 8.5:1
    *** 83.5mm Pistons available upon request ***
    $969.99 + Shipping
    2008CC KIT
    The most popular kit of the lot for the 06A block,a full "2.0" kit using a Forged OEM crankshaft from the 2.0FSI motor along with OEM quality Forged Supertech Pistons.
    Kit includes:
    (1) - 92.8mm Forged 2.0 FSI Forged Crankshaft with correct Oil Pump gear to utilise the stock 1.8T oil pump
    (4) - 83mm Supertech Forged Pistons w/ 8.9:1 nominal Compression Ratio (82.5mm bore available upon request)
    $1699.99 + Shipping
    2190CC KIT
    NOT FOR THE SOFT!!!
    This is a kit for the very serious VW/Audi owner who wants a manly 100mm stroke crankshaft & paper thin cylinder walls.
    Kit requires the purchase of the ALH 236mm TDI block.
    Kit includes:
    (1) - 100mm Eurospec Forged Crankshaft with correct Oil Pump gear to utilise the stock 1.8T oil pump
    (4) - SCAT 159mm/21mm Forged Connecting Rods
    (4) - 83.5mm JE Forged Pistons w/ 9.5:1 nominal Compression Ratio
    (10) - ARP 12mm Head studs to allow the use of a 20V head on an ALH block
    $2699.99 + Shipping
    INDIVIDUAL PARTS:
    Main Bearing Girdle Kit - 058 Block $480 + Shipping
    Main Bearing Girdle Kit - 06A/06B Block $580 + Shipping
    Billet Main Bearing Caps: - $139 + Shipping
    AEB MACHINED IM SHAFT - $105 + Shipping
    034 Motorsport Anti-Friction Main & Connecting Rod Bearings - $215 + Shipping
    BIG BORE Head Gasket - $95 + Shipping
    ARP Main Stud Kit - $135 + Shipping
    ARP Head Bolt kit - 06A - 10mm - $175 + Shipping
    2.0 ABA FORGED - 058 - 92.8mm crankshaft - $375 + Shipping
    2.0 AEG CAST -06A - 92.8mm crankshaft - $375 + Shipping
    2.0 TFSI FORGED - 06A - 92.8mm crankshaft - $874.99 + Shipping
    Supertech 82.5mm/83mm Pistons - $589.99 + Shipping
    SCAT Forged Connecting Rods - $369.99 + Shipping!!
    PAUTER Forged Connecting Rods - $779.99 + Shipping!!
    PAUTER Forged Connecting Rods w/forced pin oiling - $939.99 + Shipping!!
    RACEWARE Head Stud Kit - 10mm/11mm - $469.99 + Shipping
    Please send me a PM when you are ready to order and please select which displacement you desire ;)
    Thanks :beer:
    p.s. Some assembly may be required :laugh:
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: *** 1.8 to 2.2 STROKER KITS - Increasing your displacement - KITS,TECH & FAQ ***
    Nice prices!
    But I am still wondering about the 95.5mm TDI crank in an 06a block.....assuming one was to use the 144mm Rods, what is the appropriate piston height for this combination? And what kind of machining is necessary to shorten the crank. All I've read is that one would need our 1.8T oil pump gear and 60-2 crank sensor ring....true? false?
    Sorry if these questions fall outside the purpose of the thread
    2000 Audi A4 ** 4.2L 40v S6 6spd swap in progress - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Jan 25 2006
    A4 2.0T
    MD
    hmmmmm no stroker kits of the 058a huh???
    Feb 26 2006
    Earth
    Quote Originally Posted by JumboBlack1.8 View Post
    Nice prices!
    Those are fine!
    I didnt include the 95.5mm stroker kit because it is not a popular seller with the 1.8T crowd.Maybe in a couple of years
    I am actually building a custom 2.1 short block for a customer right now using an ALH crank & stroker pistons.
    With 144mm + 95.5mm crank in a 220mm 06A block you are looking @ a compression height of : 28.25mm
    The ALH Cranks allready have the correct oil pump gear on them.VW only changed the design of the oil pump in the later 2.0 MKIV bettles & MKV GTI.
    Quote Originally Posted by Don Supreme View Post
    ...forgot to add that
    ABA Crank + MACHINED IM SHAFT + SCAT RODS + Supertech Stroker pistons = 1429.99
    Sep 16 2006
    '98 528i
    Thanks for the info Issam!!! I'll definitely be going the 2.1 route when the time comes, so that info is very useful.....I'm lovin this thread already!
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    How much for an 058 95.5mm stroker kit?
    Jun 01 2008
    VA
    makes me wish I hadden't left the 1.8T scene. Where's the APB love?!!?!
    Sep 28 2006
    Lexington
    058a? What does that bring it to? Sorry for the dumb question
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | Neuspeed Exhaust | ATP Test Pipe | N75 Race | Forge007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    Sep 16 2006
    '98 528i
    Quote Originally Posted by AudiTurbo View Post
    read these to start:
    http://www.audizine.com/forum/showthread.php?t=188078
    http://www.audizine.com/forum/showthread.php?t=187836
    Sep 28 2006
    Lexington
    Well thank you, but a simple answer would of been ok.
    Thanks for the reading material though
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    Oct 02 2007
    Lone Tree, Colorado
    Dont know what the hell im doing wrong but i cant calculate it right now.
    Oct 02 2007
    Lone Tree, Colorado
    Roughly 2091cc if im right with 83.5mm pistons. Which i am probably not.
    Feb 26 2006
    Earth
    Quote Originally Posted by jrock View Post
    At that point you might as well run an ABA or TDI block....
    The only 95.5mm crank that will work for you is the AAZ and those are hard to find new.
    Quote Originally Posted by blmlozz View Post
    It there
    send me a PM if your interested
    Oct 02 2007
    Lone Tree, Colorado
    i figured. i guess i will just have to go w/ the 92.8 stroker kit. unfortunately cant afford it right now
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    04 Nissan Xterra 3.3 S/C
    New Port Richey, FL
    thanks issam for putting it all in one place for us. i think ill be going the route of rods/aeb pistons when i upgrade, but if i come into a substantial amount of fund-age, i will be coming to you guys for a vr6t buildup....
    RIP:
    Brilliant Black 01 A4 1.8T QMS
    GIAC-X. AEM Dryflow. BlinkTek. 710N (BOV). Rebuilt K03s. C4T Delete, AC Delete, B7 DSMIC, custom charge piping.
    Pearl White 99 A4 1.8t QMS
    spent 5 saturdays Frankensteining the powerplant, manual gearbox, quattro drivetrain, suspension, brakes, and
    electronics from the black car after it wrecked, only to wreck the white one one 2 weeks after getting it running.
    Feb 26 2006
    Earth
    Quote Originally Posted by B5A4Kevin View Post
    Watch this space for V5 Turbo crate motors.
    Feb 26 2006
    Earth
    All PM's replied to
    Senior Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    1- any ETA on 11mm ARP head studs? i know i asked you before and you said a few months but its rapidly getting closer to when im going to be needing those.
    2- how much are you charging to do IM shaft machining if i send mine to you, or do a core charge swap thing?
    3- those billet main bearing caps would require line boring/honing correct?
    Active Member Two Rings sprAfour's Avatar
    Jan 28 2009
    98' B5-A4 2.8L Supercharged
    Connecticut
    any chance of a 2.8 kit coming out for the 30 v !?!??
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Quote Originally Posted by sprAfour View Post
    what would you do it for? They have stuff for the V6 already
    - Clint
    C5 RS6 4.2TT Motor FS - Click Here
    Gone: White '04 S4 2.7T - Stage 2+
    Not a fan of the AZ Classifieds? Tell Anthony here: http://www.audizine.com/forum/showth...assifieds-suck
    Jan 28 2009
    Connecticut
    for engine upgrades? i havent seen anything
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    Is it possible to get different rods (Carrillo) and pistons (Weisco or JE) in the 058 kit at a different price?
    Feb 26 2006
    Earth
    Quote Originally Posted by ghost6303 View Post
    1. We have 2 sets of Racewares @ a really good deal if you want.
    2. Core swap + 105US
    3. Correct
    We can offer Wiseco & Carillo combinations.Simply send me a PM as I dont want to defer from the main products we offer.
    Feb 26 2006
    Earth
    All PM's replied to
    Thanks for the awesome support everyone.We are working on some new pieces for 2009 that will really make you salivate
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    if someone were to get the 2.0 stroker for the 058 block and also buy cams, exhaust valves, valve springs, retainers, and other parts for the head....would they need tuning to install and run this?
    NOOB
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Feb 26 2006
    Earth
    Quote Originally Posted by a4mafia(Red) View Post
    NOOB
    I would recommend it
    Feb 26 2006
    Earth
    All PM's replied to
    Senior Member Four Rings somebody5788's Avatar
    Aug 13 2008
    Indiana
    So I have a spare 1.8t and a spare 1.9 TDI sitting in the shop..... What can I do? The TDI had a valve go through the piston (literally) and the 1.8t the dealer told him the engine was bad so we got him a new one even though we drove it in and it didn't knock. Whats the cheapest way to do something to this engine?
    -Nic
    2001.5 Audi S4 - APR 93/100 | 710n's | EvoMS intake | RS4 clutch | Stern Snub | Stern motor mounts | GROM Bluetooth | DEI Remote Start
    Feb 26 2006
    Earth
    Quote Originally Posted by somebody5788 View Post
    Which codes on the engines?
    AEB and ALH or AWM and ALH?
    Aug 13 2008
    Indiana
    Quote Originally Posted by Issam@034 View Post
    The 1.8t is an ATW according to the head there are pix in the link for it in my sig. I really need to find out what the TDI is though.
    Edit: the 1.8t was also out of an 01
    -Nic
    Feb 26 2006
    Earth
    Put the ALH crank into the ATW block.Thats what I would do.
    Feb 26 2006
    Earth
    Special on for the Month of June!
    http://www.audizine.com/forum/showthread.php?t=289049
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    02A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Does anyone have a rough guesstimate of the cost to install the 2.0 stroker kit with the crank and rods??? Not including all the extra parts like bushings ... etc???
    'SOFTWALKER MODS
    Do u have the Bentley or Dealership Manual & Tools it takes to work on YOUR car properly? Or...
    Are u just going to continue to wing it & keep expecting manna to fall from AZ?
    Apikol>Snub/Diff APR>ExhTIP-TB hoses,Stg3 AWE>DV
    JHM>ShortShift-the works
    Misc> 18x8x9 235/265;HSport S4 barsTT225;Bosch-F6DTC;CarbonioV2+V6Intake Inlet;HFC;Podi-P2;ATP mani;GPopK04;034mounts
    SPEC>Stg3+,LWFW
    STaSIS>328/305mm,40/60,SL
    Personal Motto>Walk Softly Carry a Big Stick
    New Member One Ring
    Jun 06 2009
    Orange County, CA
    If you were in Orange County... It would be 40/hr
    '98.5 2.0BTQM- Sadly Sold ... Like I Sold My Child
    May 13 2008
    NoCal - EBay
    Quote Originally Posted by LedFtDrvr View Post
    Ok that's a start up here we are looking at like 100-140/hr.
    I need a better scope. How many hours does this job take?
    Am I better off building up another block on the side and just paying to have that swapped in directly?
    'SOFTWALKER MODS
    SPEC>Stg3+,LWFW
    Feb 26 2006
    Earth
    Quote Originally Posted by A4SoftWalker View Post
    Average 8 hours to remove and disassemble motor and 8 hours to put it back together.That does not include the machine work.
    Do it yourself...if you are on a forum then you are more than capable.
    Feb 15 2008
    1991 325iX
    616/MI
    F- That. Find a friend or another forum member in the area that's willing to help you out.
    I don't know anyone in that area, otherwise I'd point you in the right direction. All the people I know are on this side of the Mississippi pretty much.
    7A head, AAN intake mani, 034MS T3 Turbo mani: FOR SALE $600 + shipping
    325iX 1991 5-sp 4dr Alpine: For Sale $2500(firm)
    Feb 26 2006
    Earth
    Guys is there anything you would like us to update in this thread?
    New Member One Ring
    Jun 06 2009
    Orange County, CA
    How about pricing on AEG cast crank, pauters, 83mm JE? Kinda like the 2008cc
    I dont think i'd need it for high 300whp to 400 whp
    Feb 26 2006
    Earth
    You dont need Pauters for 400whp but if you must pricing will be : 1799 SHIPPED.
