Results 1 to 19 of 19
    Mar 18 2008
    Waukesha Wisconsin
    Odd squealing noise when heat is on
    Hey guys my car has started making a weird squealing noise while my heat is on. The noise isn't always there though. Generally after about 10 min. or so the noise will start up. Once it has started it is NOT constant and it doesn't increase or decrease in volume if I turn the fun up or down. When I turn the fan off though the noise is gone.
    Any ideas?
    I could only really think of two scenarios first the fan is hitting the housing, but then the volume or frequency would change when adjusting the fan. Second there is something in my vents that is being moved around or something when air contacts it.
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    Re: Odd squealing noise when heat is on
    Your blower fan, behind the glove box isn't lubed still. Oil it up and your good
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Mar 18 2008
    Waukesha Wisconsin
    Thanks I'll give that a shot tomorrow
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    I have this same problem. Any suggestions on what to use to lube it?
    Senior Member Three Rings therox182's Avatar
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    I used WD40 the first time i tried it, but the noise came back after a month or two. The second time i used some 3 in 1 oil we had at the house, seems to be holding up pretty well. No noise since
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    Items for Sale
    I have the same problem.
    It only makes the noise for the first 5 minutes while making a left turn only.
    Haha.
    Senior Member Two Rings jayski006's Avatar
    Dec 06 2008
    06 A4 Sline...B5 S4 Stg2+
    hahaha i have that problem too.. i noticed it got louder when i opened the glove compartment .. im guessing it is the fan behind there.. ill try lubing it.. hope that works!
    Veteran Member Four Rings LowA4's Avatar
    Aug 04 2007
    00 S4, 01 Allroad
    Gardnerville, Nv.
    Items for Sale
    Yeah mine does it around right hand turns. It's really annoying.
    C5 RS6
    Stage 3 b5 S4
    8P A3 quattro
    B6 usp A4
    C5 Allroad
    Senior Member Three Rings BamfiNogaroS4's Avatar
    Feb 12 2008
    Denver, Co
    Same problem here ha I ll lube it today as well!
    Oct 31 2005
    C7.5 S6, 14 Jetta 1.8t, 15 ZX6R
    Ashburn
    Items for Sale
    Yeah me 2, mine gets louder the faster i drive. So annoying
    C7.5 Glacier Wht | Prestige | Blk Optics | EPL STG2 | Mike's Downpipes | Becker Catback | Roc Euro | EC Diff Mount | EC F/R SB| EC Trans Mount | Airmatic Links | HRE FF04 20x9 et25| Carbon Mirrors | Yellow Calipers |
    Instagram: @Sinister_S6
    Jan 21 2007
    01.5 Silver Avant
    dc
    thats odd, id think its just with the fan speed, not car speed, i used 3-1 oil, sound came back, i think!!! not sure, i think i hear it for a second, turn the music down, and its not there anymore...fcuker keeps playing a game on me i think...but lube it from behind the glove box, and from the cabin filter area.
    May 26 2008
    Long Island
    Quote Originally Posted by casawhites4 View Post
    so u dont have to drop the glovebox and pull out the whole assembly to lube it? i need to do mine as well.. was thinking silicone spray would be the best bet since u guys havent had lasting effects with wd40 or 3-1 oil
    Dec 06 2008
    yeah how would we go abouts doing it?
    Mar 18 2008
    Waukesha Wisconsin
    What they said...is there an easy way of doing this or do we have to drop the glovebox assembly
    Jan 29 2007
    08 S4 00 S4
    MD
    Items for Sale
    Quote Originally Posted by Hyperlitebordr View Post
    Drop the glovebox. It's pretty easy to do
    http://forums.audiworld.com/s4/msgs/2729810.phtml
    08 S4- Stock
    Jan 17 2005
    2001 S4 - A4 1.8t
    New Jersey
    I have this same issue. It is more pronounced when I turn left. Also, if I turn the fan speed up it goes away.
    Registered Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    i thought i was the only one but i guess ill try to oil it up too myne only does it making right turns too
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    i just replaced the entire thing.. heh
    Lurker
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Quote Originally Posted by csre9 View Post
    Haha.
    Left turn squeeler here as well!
    I am going to try some Mobil 1 synthetic spray lube on mine.
