Results 1 to 34 of 34
    Nov 05 2008
    MO
    Moisture in Headlight?
    Every time I wash my car or it gets wet the headlights get moisture in them. Has this happened to anyone besides me? How did you fix it..
    Veteran Member Three Rings UberDave's Avatar
    Mar 15 2008
    2005 S4
    Oregon
    Re: Moisture in Headlight?
    Search for 0-ring mod, it's been discussed many, many times.
    Senior Member Two Rings a62.7t4ceo's Avatar
    Mar 16 2007
    Call AOA with your VIN. There's a TSB on it. Extensions have been given on some models.
    Senior Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2005 Audi S4, 2000 Triumph 955
    Dutchess County, NY
    I am in the process of fighting this out with AOA. I will post the outcome when its done.
    2005 Moro/Silver 6MT; Hardwired V1, Escort 9500ci, Hardwired Dash Express, Hardwired Garmin 265wt, Uniden BCT15, RS Pro95 Scanner, Uniden CB, 2X Antennex Antennas
    Blackberry 9700 running Trapster
    More "covert" mods on the way.. Run Silent, Run Swift...
    Registered Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    Chicago NW Burbs
    dude, everyone has this issue. it becaue audi decided it would be a good idea to put vents on the headlights. you can put silica gel packs near the headlights or you can do what i did which is seal everything with some rtv sealant
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Quote Originally Posted by B6JoeA4 View Post
    Ugh... you certainly do not need to seal everything. Moisture is caused by water dripping down the adjustment screw past the crappy o-ring and then evaporating and causing condensation on the headlight. Like everyone has said search. Easiest and longest lasting fix for this is to get lithium grease take out that adjustment screw and put the grease all along the top of the screw above the o-ring. I did this fix 2 years ago and havent had a drop of condensation since.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Nov 19 2008
    San Jose, CA
    Quote Originally Posted by covertS4driver View Post
    You can fix it yourself pretty quickly for less than $2.00 in parts and a bit of time. Even if AOA replaces the headlights likely the new ones will fail in a short time also.
    Jun 09 2008
    California - Northern Californ
    I se
    Jun 11 2008
    Dutchess County, NY
    Quote Originally Posted by ClarkSJ View Post
    I've searched it, and I know exactly how to fix it. I paid for my car, and will pursue it with Audi.
    Thanks for the input though, I know everyone is just trying to help. I just think Audi needs to step up to the plate.
    May 30 2007
    MA
    I dont really think its a design flaw...O-rings wear out over time.
    2014 R8 V10 - Gated
    Established Member Two Rings mountainsnbirds's Avatar
    Nov 25 2008
    05' S4 Avant 77' Puch Maxi
    WVU, Morgantown, WV
    I had my entire headlight assembly replaced by the Audi dealer in October which cost around $850 and there is moisture/fogging appearing already. I'm going to use the silicon grease method and hopefully that will fix both.
    It is a very irritating problem that many of us seem to have.
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    2009 A4
    St. Paul, MN
    ROTFL, Good luck with that! While you have Audi on the phone, see if they're ready to "step up to the plate" on my DRC failure along with all 800 other RS6's yet. Ha
    Jun 11 2008
    Dutchess County, NY
    Quote Originally Posted by SuperAvant View Post
    Who cares what the prob is? If its under warranty, they should fix it.
    So they should replace the o-ring.. no big deal
    Jun 11 2008
    Dutchess County, NY
    Quote Originally Posted by V8weight View Post
    I hear you on that.
    They are replacing my headlight, but I'm sure it will happen again, as you all say.
    Veteran Member Three Rings ahhhudi's Avatar
    Dec 15 2008
    2005 Audi S4 B6
    north Chicago area
    If it's the common issue of moisture in the headlights, Audi is quite a stickler on this and most dealers will not replace (even if you tell them that you are not concerned about replacing the whole fixutre.
    Best solution is replacing the o-ring. I just replaced mine, dried out the entire fixture, and wall-ahhh, no more moisture in headlights as you can see in my new avatar. You need #6 o-rings which you can buy from Home Depot and some graphite powder to seal/lubricate. You should be good to go.
    My faith is in the /S.
    05 S4 B6... my second S4...Eclipse AVN726e nav unit, RS pedals, K&N filter, Audi Sport rubber mats, V8 insignia, 35%front/20% back tint, Pirelli P Zero Nero Max Performance Summer.
    01 S4 B5... my first S4...bone stock. Sold.
    How Many Speeding Tickets? Vote.
    Nov 19 2008
    San Jose, CA
    Except that they won't replace the o-ring. They'll replace the entire headlight assembly, which will then fail in the same manner in the near future.
    Yes, it's a warranty repair, and yes, Audi should step up to the plate. But why put yourself through the hassle, time, and aggrevation when you can fix it yourself for about $2.00 in parts and 30 minutes of time?
    Jun 09 2008
    Thanks.
    Dec 15 2008
    2005 Audi S4 B6
    north Chicago area
    Quote Originally Posted by akitamike View Post
    Can you post up a diy on this fix. Seems like the way to go and not have them replace the whole headlight assembly, which will have same problem? I apologize if someone already posted a diy, but I couldn't find it. Thanks.
    This is the exact DIY link that I used as a guide.
    http://forums.audiworld.com/a4gen2/msgs/893818.phtml
    However, I did not feel the need to shave/widen the grove at all as the link indicates. The #6 o-ring just fit nice and snug.
    I hope this helps.
    edit: here is another link that I found to be quite helpful when I was doing this.
    http://forums.audiworld.com/a4gen2/msgs/1003411.phtml
    Last edited by ahhhudi; 01-23-2009 at 10:39 AM. Reason: Adding another helpful link.
    Active Member Two Rings Celtic's Avatar
    Aug 09 2008
    1970 Coupé S, '07 RS4 and loads of crap
    Tampa, FL
    Had same issue on my '05 B6 S4 CPO. The driver side headlight would constantly fog up whenever I washed the car or nature did it for me. Called my dealer and surely enough they tried to wiggle their way out. "This is normal. Ventilation blah blah." Since I read the TSB and knew exactly what was stated in it, I called them out on it. They replaced the entire headlight assembly. I'd be happy to share more details if anyone is interested, just PM me.
    I know the problem will happen again and when it does, Audi will have to put a new headlight in again.
    I paid extra for the CPO and therefore I will continue to insist that these things are being taken care of, even if a simple DIY would fix it. Your engineering design team messed up, guess what, you'll be responsible for taking care of it. That's just how I see it, guys.
    Established Member Two Rings wat2022's Avatar
    Mar 24 2008
    04 S4,98 Jetta
    WA
    Where do I find the TSB?
    Aug 09 2008
    Tampa, FL
    Quote Originally Posted by wat2022 View Post
    Check PM.
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    Quote Originally Posted by Celtic View Post
    hey this is good stuff. this has been driving me nuts since i purchased the car. i have the CPO warranty as well...
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Items for Sale
    My dealer will replace it if I take pictures of it fogged up, I was once told if the moisture goes away after 10 min. of operation then the will not AOA will not authorize the change.
    Aug 09 2008
    Tampa, FL
    Quote Originally Posted by B18b1ex View Post
    Very correct, Sir. That's stated in the TSB.
    In my case 10 minutes took actually some 2 days. I, too, provided pictures via email showing the passenger side to be perfectly fine and the driver side fogged up. Plus, they day I took the car in I made sure that the headlight was fogged up so they could see it for themselves. It worked out for me - until the next time.
    Active Member Two Rings tomazo777's Avatar
    Jan 27 2009
    2005 S4 / 2008 Subaru Tribeca
    Utah
    I can not take out the headlight. there 2 bolts on the top. After I take'em out the headlight still does not come out. Can someone help/guide me to how take the lights out so that I could replace the o rings?
    thank you.
    T
    Senior Member Two Rings EssPhore's Avatar
    Jun 01 2008
    2005 B6 S4, 2007 KTM EXC 450
    So Cal./I.E.
    Quote Originally Posted by tomazo777 View Post
    thank you.
    T
    There are more bolts on the bottom rear of the headlight assembly. You do not need to remove the bolts completely. Loosen just enough so the assembly will slide out. Take your time and you will figure it out. The driver side is easier than the passenger side. I removed the forward part of the intake duct for easier access.
    Jan 27 2009
    Utah
    thanks again EssPhore!!
    T
    Aug 05 2008
    Boston
    PM-ed you; can you please send me the TSB as well?
    Aug 09 2008
    Tampa, FL
    Quote Originally Posted by dantm View Post
    Check PM.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Quote Originally Posted by a62.7t4ceo View Post
    expand on this...
    Audi seems to have adopted a 'fuckyou' attitude about the condensation.
    p.s. OP...this is now officially the most reposted subject in the B6/7 S4/RS4 forum! I ran a poll on it earlier in the month to see how prevelant the problem is in order to show Audi.
    Aug 01 2016
    Chicago, IL
    Ditto. I have a 2007 RS4 with the same annoying problem. Add me to the list if it will help. Here's a pic...
    Aug 01 2016
    Chicago, IL
    If I have to replace headlights, does anyone know where I can find these?
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Items for Sale
    O ring mod. Also, open the vent to the light and let it air out for a day or two. You may need to joey mod it with knew sealant. I get condensation like that too. I plan on buying new lenses and replacing the lenses on my soon. that should fix the issue.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Senior Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    The O ring mod didn't do it for me. Had cracked housings, so used sealant to plug them. Worked well for one, still condensation after car wash with other.
