Carbon Copy Designs
+ Reply to Thread
Results 1 to 22 of 22
    Active Member Three Rings
    Sep 20 2007
    Harrisburg, PA
    ECS 306mm rear brake upgrade?
    I was thinking of doing the ECS tuning 306mm rear brake upgrade. I was wondering if anyone has done it and what the opinions were? In addition any pics? Thanks.
    Active Member Four Rings blmlozz's Avatar
    Jun 01 2008
    01 B5 S4 # 1481
    VA
    Re: ECS 306mm rear brake upgrade?
    go 034 or go home.. don't mess with the floating ecs rotor crap. You don't need anything bigger than the S8 rotors anyway unless you plan to make it a deticated track car. To answer your question on has anyone done it, a quick search will find a number of people having problems with loose hats and bad ECS service.
    Sep 20 2007
    Harrisburg, PA
    yeah but I also found a thread about 034 and fitment problems.
    Jun 01 2008
    01 B5 S4 # 1481
    VA
    Quote Originally Posted by johnkent1212 View Post
    Very little grinding is required, yes. However I would rather use an oem rotor that can be bought anywhere for cheap rather than a one-off design that costs $100s and has to be ordered online.
    Jul 06 2005
    Germany
    The ECS rotor isn't "crap". And it will take years of hard use to wear out a rear rotor.
    I'd bet it's lighter than the S8 rotor too because of the aluminum hat.
    Slow, stock, smurfy blue car.
    Relax, I just troll this place for fun.
    Sep 20 2007
    Harrisburg, PA
    Quote Originally Posted by Shomegrown View Post
    Do you have it?
    Jul 06 2005
    Germany
    Do you have it?
    Yep.
    Senior Member Four Rings GramCracker's Avatar
    Mar 11 2007
    '01 S4
    Somewhere in CT
    ^^^^^ Nice car.
    #3 2001 Silver S4 fucking VAST powered
    "A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster." - Jeremy Clarkson
    "Silver > Cum Pearl" - Rated S
    Senior Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    San Luis Obispo
    Both 034 and ECS rear brake kits have their problems, imho go stasis if you want quality(I have them and love them!)
    Senior Member Three Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4, 00 ML320
    The city with tall BUILDINGS!
    Sigh....
    034 is the way to go you get a 320mm rotor. Even though you cant use the full rotor the larger size of the rotor disperses heat quicker then the stock rotor. If you want to spend money on a rear BBK look on www.rs246.com theirs a write up on getting B6 s4 rear calipers and rotors to work on a b5
    l gotta-- l gotta get
    a form from a scientist.
    Jul 06 2005
    Germany
    Quote Originally Posted by TommyGunn View Post
    Sigh....
    To be honest, I can't see anyone having a heat issue with the rear brakes. Our weight distribution just doesn't put much load back there under hard braking.
    I've worked the brakes harder than 90% of S4 owners out there, and the rears don't need much help.
    However, you might want to upgrade the rears just to keep balance in check as a front BBK can change your brake bias.
    Not to mention looks, although that was minor reason for me.
    Let me put it this way, I would begin to crack the front rotors (cross-drilled) after just a few 180+ mph hard stops (ECS Stage 4). I went through two cross-drilled front rotor sets and one slotted front rotor set. All trashed.
    The rear brakes are cross drilled, don't have a single crack, and haven't even changed the pads yet (they were installed at the same time).
    Sep 20 2007
    Harrisburg, PA
    Yep.
    Do you have any pics of the rear brakes up close? BTW very nice, clean, car
    Jul 06 2005
    Germany
    Thanks.
    I've got some more pics, but I don't think I have any of the rear brakes...
    http://www.pbase.com/nogaroblue/s4&page=all
    http://www.pbase.com/nogaroblue/most2006&page=all
    Give me a few days and I'll snap some for you.
    Nov 20 2007
    01.5 S4, 00 ML320
    well, how can you change your brake bias by changing your rotors? How can heat affect your rear rotors. Have you ever driven on a track?
    Jul 06 2005
    Germany
    Here, I found one I hadn't posted yet. Is this good?
    Jul 06 2005
    Germany
    I might have taken the S4 on a track a time or two...
    Rotor diameter has a huge effect on brake bias. Increasing the rotor diamter increases the effective lever arm you have on braking force. That's just like how a longer wrench or a cheater bar applies more torque to a nut you're trying to loosen.
    If you buy a BBK on the front, you may shift your braking bias forward due to piston diamter changes, rotor braking torque changes, or pad compound changes.
    Adding a larger rotor in the rear can help balance this.
    ECS has made a spreadsheet explaining it, though I haven't double checked their numbers. Don't hold me to them. I can verify though my car was more balanced after I added the larger rear rotors.
    As I said, heat and fade is not an issue on our rear brakes. I've never heard anyone complain about this, and I've never had a problem over 6+ years of running an S4 hard.
    Active Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    B5 S4 Stage 3+
    The Bay, Cali
    Hey Shomegrown, not until I saw this pic did I realize who you were and then I noticed the plates.
    You have a couple of great You Tube videos. Like the one where your on the Nuremberg Ring and I believe you have another one where your going flat out on the Autobahn.
    Nuremberg Ring video:
    http://www.youtube.com/watch?v=-RS8yrjWelM
    Great song too.
    "Always know if the juice is worth the squeeze."
    -Hooked on Meth-
    Mar 11 2007
    '01 S4
    Somewhere in CT
    Quote Originally Posted by skunkoncrunk View Post
    Great song too.
    WAIT. That's shomegrown?!?!?! OMG. I didn't even know.
    Your car is awesome, however I did prefer the RS4 rims. But that's all your choice.
    Jul 06 2005
    Germany
    lol,
    Well, that NOT me in the picture. That's just my car y0.
    I run the B5S4 rims in the winter and B7RS4 rims in the summer.
    Apr 18 2007
    B5 S4 Stage 3+
    The Bay, Cali
    lol,
    Hahaha, I just remembered that pic from the movie so I was able to put two and two together.
    I couldn't find the one of you going flat out though.
    -Hooked on Meth-
    Senior Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Stage 2+ Audi S4; R56 Cooper S
    The 3-0-5
    Nurburgring video:
    Great song too.
    Diddo. As a matter of fact, his were some of the first B5 S4 vids that got me hooked on these cars ... Nice Noggy Shomegrown
    p.s. fixed
    2001.5 S4 // Brilliant Black // 6MT // Alcantara/Sport Package
    328.51WHP/382.55WTQ on 104OCT (w/ dumps open)
    MODS: GIAC-Xr; Milltek SuperDual; Piggies w/ DMH Cut-Outs; DARINTAKE; AMS TBB; Forge 007's; AWE SMIC's; Zena Racing Hoses; AWE Vent Boost Gauge; eBay Trunk Lip Spoiler; 18" RS4 DTM's; STaSIS Street Sport's; AWE DTS; APR Snub Mount; JHM Shifter; Clear Corners; Aero Wipers
    Sep 20 2007
    Harrisburg, PA
    Yup. Good enough atleast. Looks great. I'll probably do that kit. I have a front bbk and I need the rears to improve the bias distribution.
+ Reply to Thread
    © 2001-2010 Audizine, Audizine.com, and Driverzines.com
