Results 1 to 6 of 6
    Veteran Member Three Rings woofster's Avatar
    Jun 10 2007
    Toronto, Ontario, Canada
    Question Reading your engine oil dipstick
    Silly question: How do you read the engine oil level on the dipstick if the orange oil level marker is no longer fixed on the dipstick? I was checking the oil level the other day, when I pulled out the dipstick only to realize the orange marker has now slid up the length of the stick. I slid it back down to the kinked area at the bottom of the dipstick but wasn't 100% sure where it was supposed to sit. Any insights?
    Jun 10 2007
    Re: Reading your engine oil dipstick
    ^ Bump.
    Does anyone know exactly were this orange marker is supposed to sit on the engine oil dipstick? Mine is loose and sliding along the length of the dipstick. It's pictured below with the orange marker at a random spot on the dipstick.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Go by the textured area at the bottom. Here - don't go over A or below C. Even with that piece moving around, this picture should help.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Registered Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    Chicago NW Burbs
    get a new dipstick
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    new dipstick is $8 from genuineaudiparts
    worth it.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Jun 10 2007
    It's silly but perhaps a new dipstick it is.
