Results 1 to 40 of 42
    Senior Member Three Rings B00sted20VUSP's Avatar
    Nov 11 2008
    Junk
    Chicago, IL
    Smell Coolant? No Leak? I have your answer
    I know this has probably already been discussed but it has been bothering me for 2 months. Everytime my car was HOT i noticed when i got out of my car that it had a sweet coolant smell. Could never find a leak. Always had this white/pinkish trail down the side of my block near the thermostat housing, thought is was the runoff from when i blew off my shitty plastic vent cap on the top hose (another story). But no i finally found it. Its that stupid block plug right next to the thermostat held in with 1 bolt. Changed it and that was the end of that. Hope this helps somebody.
    -Nick
    http://s242.photobucket.com/albums/f...rent=plug2.jpg
    /S4 25 Quattro #139 | JHM 93 Oct Tune | Fast Intentions Non-Res Exhaust | Trexturk Downpipes | VMR Staggered Gunmetal 710's | RS4 Grille | RS4 Pedals
    Nov 11 2008
    Junk
    Chicago, IL
    Re: Smell Coolant? No Leak? I have your answer
    Oh yea and the revised part # is 06B 103 033 A. I think it was like $9 bucks
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    haven't heard of this before, good to know.
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Established Member Two Rings Mac's Avatar
    Jul 11 2007
    Atlanta
    Is it hard to change? I have been having this problem as well.
    Oct 16 2006
    Naperville
    Items for Sale
    Can you take a picture of the plug and its location, im having the same problem since my thermostat change.
    Nov 11 2008
    Junk
    Chicago, IL
    Its basically under the intake manifold, behind the alternator, next to the thermostat housing. Yea it was kind of a bitch to get to, only held in with a 13mm bolt. But getting to it sucked. I took out the throttle body and thermostat housing cuz mine actually cracked off in the block, what a bitch. Just take your time. Afterwards noticed car has better heat, and no smell now . Audi actually has a TSB too, thats how i found it, cuz i have access to ELSA web. Heres some pics:
    Good Luck!
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    YES THAT WAS MY 1st EVER REPAIR ON MY AUDI!!! MEMORIES!!
    2013 Audi S4|EPL Stage II Dual Pulley ECU and DSG Tune|JHM 179mm Pulley| EuroCode Sway Bars |Moog Endlinks| CTS Turbo Intake|Alu-Kruez|034 Mount Inserts| CR-15|AWE Touring &Track Section Exhaust|AWE Resonated DP| Vogtland Coilovers| AMS Boost Cooler
    11.815 @ 116.69mph
    2007 Mini Cooper S Daily Driver
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    I am having that smell now, and have yet to find a leak... Im going to have to look into that. Thanks
    Apr 26 2007
    Detroit
    did you have white smoke coming out of exost?
    Dec 09 2008
    Wisconsin
    exost?
    Senior Member Three Rings chimchongdlight's Avatar
    Jan 02 2007
    Sacramento Ca
    is that close to wear like that harness is?..like lets say ur standing in front of ur car with the hood open...top kinda left to middle side of ur bay..u look down..u see a cylinder shaped looking harness...well somewhere around there im leaking coolant..is that where this part is?..i had a mechanic kinda take a little look at my car..and he said it was the thermostat and thermostat housing..is this part u guys are talking about in the mist of the same area?..bc if so ima just buy all three parts and really see whats wrong and if i have to replace all three then so be it
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Items for Sale
    good boosted. i got this problem.
    May 24 2007
    Southern California
    I'm glad I replaced it during my build.
    Kyle
    2.0L Revo GTRS Eliminator
    Senior Member Three Rings Boston_USP_327's Avatar
    Nov 24 2008
    2004 A4 USP 1.8T 6MTQ
    Grafton, MA
    dealer just told me i have the same issue... they wanted 350 to fix it hahahah, is this a DIY in your driveway with minimal tools?
    Nov 11 2008
    Junk
    Chicago, IL
    Yea it takes some time, To make it easy start buy removing the throttle body and hose, remove the intake man. support. Remove wires in your way. Then remove all hoses to thermostat housing. Remove thermostat housing from block. Then you can get to it, you can also remove the alternator, i didnt but its alot more room. Oh and remove the dipstick, just dont crack it!! Good luck, any questions, just ask.
    Veteran Member Three Rings oaybar007's Avatar
    Sep 17 2006
    Items for Sale
    SOB... I think that I have this too. I have a slow leak but I haven't pin pointed it yet.
    I have no temp change or smell. Just a slow PITA leak.
    Jan 24 2007
    If you look where the oil stick is follow it to the close to block you should be able to see the thermostat & that plug, also sign of coolant leak. If you have the small hand & quick you could sneak it out & replace new one. I think its better than draining the whole coolant because if you do it way i did you won't be loosing that much coolant.
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    Quote Originally Posted by SpacemanSpiff View Post
    exost?
    lol
    Established Member Two Rings ABsKiLLz's Avatar
    Jul 03 2008
    2002 Audi A4 1.8T
    Bronx, Ny
    Can I buy this part at like an autozone or other place? Or is this a stealership only? Internet Site? I really hate the stealership and would not like to give them any profit so if any1 can help out with an alternate place i would get it... Thanks
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    I think I need to do this too =\
    Jul 03 2008
    2002 Audi A4 1.8T
    Bronx, Ny
    umm i tried searching for that part number and i couldnt find anything online? is this stealership only or wat?
    Nov 24 2008
    Grafton, MA
    yes dealership... the part is only $5, so no need to go searching
    USP CLUB MEMBER #327
    Semper Fi.
    Established Member Two Rings Subyroo651's Avatar
    Jul 12 2009
    04' A4 Avant 1.8T
    Chicago(Suburbs), IL
    ESC Has it as well, or at least it matches the part no listed above..
    http://www.ecstuning.com/Search/06B_103_033_A/ES279940/
    I just had my coolant flange repaired and I still have a coolant smell, all the spills were cleaned so could it be this?
    Thanks
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Quote Originally Posted by Mark View Post
    Me, either. Rep to you for something new to me... if I can figure out how to do it.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Jan 11 2011
    Las Vegas, NV southwest
    i will be taking a shot at replacing the coolant plugg. Should i replace the thermostat rubber housing aswell? Does anyone have any DIY on this fix? it would help :)
    Veteran Member Three Rings AvantJunkie's Avatar
    Jul 17 2009
    Too much shit.
    Longview, WA
    Quote Originally Posted by grllanaudi View Post
    Do a search for "J plug" and you should find all the info you need.
    **Brett**
    2002 A4 Avant 1.8TQM Brilliant Black/Platinum with some stuff.
    My car and I have a lot in common--we're both kind of old and slow, but still manage to look pretty fucking cool.
    Jan 11 2011
    So iam assuming that the the thermostat should be changed if you have a j plugg issue. i ordered a j plugg and thermostat and i was wondering is there any good DIY on stats. 02 1.8
    Veteran Member Four Rings 3vom's Avatar
    Aug 26 2009
    Remove TB hose
    Remove headlight
    Remove Alternator bolts to get more room
    Unscrew the hard OIL line (PITA)
    Remove Thermo
    Remove J Plug
    Reverse.
    I love boost.
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Good to know when this comes up(Knock on wood it doesn't soon).
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    2004 Audi A4 & 1991 Toyota MR2
    Worcester, MA
    What does coolant actually smell like? I have this methane sort of smell.
    Anthony:[In regards to GCC] No, I own it (but have it on loan to Tu). | 4.14.11
    Co-President of the "I ♥ Selena Gomez AZ Fanclub" | 7.22.10
    ASE All Same Everything | Est. 2011 MA to FL
    Leader of the WGLYC Movement | Est. 2009
    Rapey Twins | H20i '11
    GCC Law/Rule #22 | ∞
    -=[SBSC]=- | 2010
    Dec 19 2007
    York, PA
    like hot candy
    Dec 18 2005
    nevada
    Correct ^^. It's a very sweet distinctive smell, More so in taste.
    Veteran Member Three Rings daghstdrummer's Avatar
    Feb 09 2007
    2012, Honda CRV - 99 Ford E-150 Conversion van
    Astoria, N.Y.
    Good Post! I've been having an issue like that for a while... good to know now i can fix it!
    2002 A4QM 1.8t Frankenturbo Tuned by SSP... R.I.P.
    135
    24R
    Veteran Member Three Rings plug1's Avatar
    Mar 31 2008
    Colorado Springs, CO
    Quote Originally Posted by AvantJunkie View Post
    This^ It's a common failure on our cars.
    -Current: '17 Q5 3.0T BO Suzuka Grey-
    -Past: Glacier B8.5 AR, Arctic B6A4 USP, Black B5S4, Black B5A4-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    Quote Originally Posted by 3vom View Post
    Remove TB hose
    Remove headlight
    Remove Thermo
    Remove J Plug
    Reverse.
    Quote Originally Posted by B00sted20VUSP View Post
    Negatory.
    It can be done with only removing the coolant reservoir and the block breather hose.
    The bolt backed out on mine and the plug was moving around leaking coolant. So, I replaced both the j-plug and the bolt. J-plug was $9 from my dealer. Bolt I had in my box-o-bolts from disassembling various Audis and VWs. Plug was perfectly fine but since I was there and had a new one I replaced it (old one has 160k on it)
    The 13mm stubby wrench on the bolt.
    Took me about 45minutes including riding my bicycle to the grocery store and back to pick up distilled water for the coolant system.
    -Doug
    '02 A4 Avant 2.7T 6spd
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2016 Golf Sportwagen TDI, 1988 Alpinewei 325iC
    Mount Rainier, MD
    Thanks for posting the "easy" way Doug.
    I wonder if this is yet one more part I should plan on replacing next time I'm in there...160k and I'm pretty sure its never been replaced (unless it would be common practice to replace it with the thermostat housing?).
    ~Eric
    FOR SALE: '03 Ming Blue A4 Avant 1.8TQM | GTRS | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    It is not common practice to replace the thermostat or this item when you do a timing belt. Its also not common practice to replace this when you do a thermostat. Its up to the end user to determine when they want to replace it.
    Mine had 160k on it and it looked perfectly fine. And that was after swapping it between three different motors.
    -Doug
    Apr 10 2011
    People's Republic of NJ
    Dayam. I've been going crazy looking for the source of that smell (was never losing any coolant so it must have been losing only a few drops here and there). Think I'll wait until I've got the front of the car apart for the timing belt and do it all at once (usual TB stuff + thermostat + plug + any other incidentals).
    Best,
    2002 A4 1.8TQM
    Formerly...2001 A6 2.7TQM 6sp
    Before that...1999 A4 1.8TQM w/lots o mods
    Senior Member Three Rings mexiricer's Avatar
    Aug 20 2011
    Alhambra, CA
    Items for Sale
    Great to run into this thread....I could smell the coolant but no leak?! Since nothing was dripping I just put it off and topped off my coolant for the time being. I'm going to check and see how that plug is sitting on the block and hopefully that is the culprit.
    Nov 11 2008
    Junk
    Chicago, IL
    Nice you'll find it, Its kinda buried. I miss my 1.8T. That was like....4 cars ago lol
