Results 1 to 12 of 12
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Spark Plug Gap APR 1+
    Just bought some new plugs "NGK PRF6Q" Should I keep the stock gap at .032, or go a bit smaller. I am APR Stage 1+ plus a test pipe. Thnaks
    2003 A4 GT2871r 303 AWHP 291 AWTQ- SOLD
    2001 Imola Yellow S4- SOLD
    2002 A4 Avant- CURRENT
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Spark Plug Gap APR 1+
    .028
    -Sami-
    04 Audi A4 USP,05 S4 Cabriolet
    Memphis, TN
    ive run stock plugs out of the box on APR 1+ with exhaust and test pipe for 40k miles with no problems. I peak 22-23lbs and no blowout.
    2004 A4 UltraSport
    APR 2+, Racetech FMIC, APR TIP, Southbend FE SS, Stasis 4:1 Center Diff, Neuspeed Exhaust/test pipe, Podi/VEI boost gauge, Stasis StreetSports, JHM Solid Short Shifter -1" Stern ACAs
    2005 S4 Sprint Blue Cabriolet
    Stock but 1 of 150
    Senior Member Three Rings Drew-B6's Avatar
    May 15 2008
    2005 Audi A4 1.8T USP
    Syracuse, UT
    Don't use those plugs with with APR 1+ I was using the same plug and was having problems with detonation. Go with the NGK BK7RE at a gap of .028, I no longer have any detonation and my car runs much smoother. Plus the plugs are only $1.99 each.
    Drew-
    Nov 04 2007
    Minnesota
    so will a gap of .028 on the pfr6q work?
    Feb 19 2007
    Charleston, SC
    I would go with a colder heat range than the PFR6Q's.....the BKR7E's should be great with a .028 gap
    -Sami-
    Nov 04 2007
    Minnesota
    Damn, I just spent like $40 on those plugs, so copper plugs will work just fine on our cars, and also the colder plugs will be fine in Minnesota?
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    For the cold winters, I would suggest using the NGK BKR6E instead. Ive read that the 7E's can cause some issues on cold startups, and I think I am having the same deal and I live in Cali!! The BKR6Es are similar in price to the 7E I usually purchase mine from Rockauto.com. They are one heat range colder than stock, and worked pretty well on my 1 and 1+ setup.
    Gap them to 0.28 because by the time you swtich them out, they will become somewhere around 0.32. WHich means if you kept it out 0.32 from the begining, you will experience a blowout ( which happened to me on stage 1!!!)
    another stereotypical Audi
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    you're in Utah and due to the elevation + local temps. my recommendation would be NGK BKR6E gapped @ .028
    here in Denver i'm GIAC 1+ and my car ran poorly with the BKR7E plugs. rough idle and low rpm detonation trouble. problems grew worse as the weather became colder.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    May 15 2008
    Syracuse, UT
    My BK7RE's seem to be doing great so far, I am at about 4000ft above sea and we have been in the low teens so far this winter. If I notice any issues I will bump up to the BK6RE's. At only 2 bucks a pop and 10 minutes to change, its no biggie. I am very happy I changed to the copper plug!!!
    Drew-
    Mar 27 2005
    Toyota 4Runner 4x4
    Here & There
    another option is the Bosch F5DP0R. they don't need gapping since they are a side fire plug and these only need changing every 40k miles or so. They have worked well with both my 1+ and K04 setups. I ran them at altitude and sea level and car ran well. APS in Denver recommended these plugs and they use them in alot of turbo cars there.
    2004 A4 1.8TQ6MT - Dolphin Grey
    -Maestro Stage III with a built block
    -STaSIS/Ohlin Dampers with Swift Springs
    -STaSIS/Alcon 355mm Mono4 BBK & 310mm Rear
    -STaSIS 4:1 Center Diff
    -19" RS10 Forged wheels w/ Nitto NT-05
    -Laser Intercepter Dual + Bel STI Magnum
    301hp & 331 ft/lb uncorrected
    on 93 oct
    Active Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Is it a problem to be running Iridium plugs that are gapped at 0.028 if you're chipped?
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
