Page 5 of 16 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 610
  1. #161
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Re: Jibberjive's RS6 Build Log
    keep going man
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
  2. #162
    Senior Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    nice progress, looking forward to the motor build.
  3. #163
    Registered Member Four Rings ThirdStrike's Avatar
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    i heard ronnie/slowgolf is selling you some DV's?
    you will like em. perfect style and performance
    K04|Eurodyne ME7|E85|No bitchassness
  4. #164
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by ThirdStrike View Post
    Wow, word travels fast Do you work there? I think your pics were the ones that introduced me to them
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
  5. #165
    Senior Member Three Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2002 A6 3.0, 2010 Camaro
    michigan
    Quote Originally Posted by jibberjive View Post
    those are sweet! they look like little hand grenades!
    CAR FOR SALE!
    http://www.autotrader.com/cars-for-s...18789624&Log=0
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    Gone but not forgotten:
    2000 S4 tip "Grumpy Smurf" stage 2++
    2001 M3
  6. #166
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    Quote Originally Posted by obijohn22 View Post
    they are supposed to do that :-P
    http://4ringsftw.com/gallery/main.php?g2_itemId=19601
    pm slowgolf
    no i dont work there.. but the EJ people are good friends of mine.
  7. #167
    Active Member Two Rings SlowGolf's Avatar
    Jan 17 2008
    1987 Conquest TSi, 2002 Golf, 1998 A4 Quattro
    Right Behind You
    Rob (Thirdstrike) is a real good friend. His car was the first car we ran the small DVs on.
  8. #168
    Senior Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    I would consider meth, but it wouldn't likely do much when I'm running 115 octane E85 daily
    Meth won't help advance timing with the E85 but ERs and a Meth kit will put your IAT deltas in the negatives.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
  9. #169
    Senior Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    whats it cost to do something like this after everything is all said and done?
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
  10. #170
    Veteran Member Four Rings Bimmerchop's Avatar
    Aug 23 2004
    2000 BMW 328i
    subscribed
    Rich | 2001.5 EPL stg III Pearl White S4 | Flickr
    EPL | ER | SDR | APR | Stratmosphere | 034 | ASP | SPEC | Fidanza | STaSIS | H-Sport | AWE | H&R | StopTech | Fikse
  11. #171
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by Trigger Happy View Post
    For the average consumer buying new and paying near retail, well north of $10k, and well north of $15k if you're including the built longblock and 2.8 heads.
    Some new prices off the top of my head for some of the more expensive stuff
    ER SMIC's- $1300-1400
    RS6 turbos- $3600
    Clutch and LWFW- $1400
    Rods- $1000
    supertech springs/retainers - $750
    Inconel exhaust valves- $400-500
    Inlets- $400
    X-1 intake- $475
    Bosch 044 drop-in fuel pump- $425
    That's just about $10k right there and that is sorely incomplete, even missing some of the higher dollar items (downpipes, catback, 2.8 heads, motor/tranny mounts, wideband 02, fuel injectors, tune, all of the seals/bearings/bolts/pumps to replace while the engine is dismantled, short shifter, diverter valves and more). Also, that's not including any of the labor, which just for the regular KO4 swap is usually around $2000 (pull engine out, put on new turbos, and put back in). Other additional labor costs are for breaking down and disassembling the engine, hottank/clean/mic stuff and hone if you're replacing rings, balance the rotating assembly ($175-250), valve job and valves install ($600-700+), complete engine reassembly ($$), then bolting on the turbos/etc and reinstalling.
    It all adds up for sure. I just don't want anyone to embark on this underestimating the cost (I'm way over budget.) On the other end of the spectrum, if you don't change a single seal or even touch the engine, you could do a base RS6 setup with an OTS tune for about the same as a new KO4 setup + ~$1000-1200 for the turbos + ~$100-200 for an inline fuel pump.
    Most of the engine internals and a bunch of other components I got from 034 motorsport, or more specifically Issam on here (except for the rods, I got them from Pete at Integrated Engineering.) So if you need these parts, talk to those guys and they'll get you set up cause they were a pleasure to work with.
    I've got some new goodies that I'm super stoked about, but haven't had time yet to take pics. I'll update soon
    --RS4 AIRBOX--
    LOOKING FOR:
  12. #172
    Active Member Two Rings Drinnen's Avatar
    Jan 26 2009
    Sac
    how much did those cost you? is his handle slowgolf on az? those dv's are sick.
    // 01 Silver S4 6 speed // Apr Tuned // Stage 2 // Milltek 3" Cat-back //
  13. #173
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by Drinnen View Post
    Look directly below his reply
    They look even better in person
    --RS4 AIRBOX--
    LOOKING FOR:
  14. #174
    Senior Member Four Rings Evilevo's Avatar
    May 26 2008
    2001.5 S4 2.8L, 2012 Golf TDI w/Tech
    Potomac, MD
    RS6 turbos- $3600
    Rods- $1000
    Inlets- $400
    X-1 intake- $475
    Agreed. It is ALOT of money. I am also over budget but at this point, so far in that you cant do anything about it.
    BTW, from what i have found/been told, the stock intake valves dont like to be revved that high. IDK about you, but i plan to rev my car out to 8-8200. I just went ahead and got new intake valves too. But than again, i had 160k on all my motor parts, so it was also for Peace of Mind knowing all the parts going in are new.
    Good luck on your build man, cant want to see the finished product!
  15. #175
    Oct 08 2008
    MA
    I'd be worried about running stiffer springs on the stock intake valves...You're soo deep into this project you should just break down and spend the extra couple hundo so you can rev it out nice and high all day without any worries of a snapped valve. Although it's not really necessary to bump up your rev limiter that high with rs6s since they don't flow well at 8000. good luck with the build
  16. #176
    Jan 11 2007
    SLC,UT
    You guys got me thinking...
    --RS4 AIRBOX--
    LOOKING FOR:
  17. #177
    Oct 08 2008
    MA
    after over $10k invested what the extra $500? Plus, if you ever want to upgrade to GTs you can hit 8400redline all day.
  18. #178
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by wdbdy2000s4 View Post
    That was my rationale with building the heads in the first place, I've just never heard of any issue with using the stock intake valves.
    Did guru drop an intake or exhaust valve?
    --RS4 AIRBOX--
    LOOKING FOR:
  19. #179
    Oct 08 2008
    MA
    don't remember...I know he built the heads himself though.
  20. #180
    Account Terminated One Ring
    Mar 25 2009
    Michigan
    Quote Originally Posted by GURUMAN View Post
    I'm jealous of your setup to work on the car, look what I used on my previous engine pull
    ouchh!! i hate that jack b.s
    when i did my clutch
  21. #181
    Senior Member Three Rings diabolical1's Avatar
    Mar 24 2009
    New York and Toronto
    seems to be a well-thought-out, comprehensive - albeit expensive - build, but i like it. can't wait to see when it fires. good luck with it.
    quick question: what's the deal with the 2.8 heads? just curious why those over the stock 2.7s.
  22. #182
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    2001.5 s4, 2001 porsche 911 996
    Quote Originally Posted by diabolical1 View Post
    bigger, better air flow
    Stage 3 2001.5 Silver S4
    | RS4 K04's | ASP | SSAC | AWE | Darintake | EV14 | Forge | Southbend | 034 | JHM | Fidanza | Avic | DuH | 10SecS4 |
    Need your transmission rebuilt around the Tri State area? PM me
    Audizine IRC Chat
    buy my Porsche 911, you know you wanna.
  23. #183
    Mar 24 2009
    i take it either:
    (A) it's not common practice in the community to port 2.7 heads OR
    (B) it's just cheaper to get 2.8 heads (which would be similar to porting 2.7s).
    am i close? :)
  24. #184
    Oct 08 2008
    MA
    2.8 heads flow better. There isn't that much room to work the 2.7 heads either
  25. #185
    Nov 18 2008
    2002 VW GTI 337 1999 A4 27T
    Chicago
    i take it either:
    am i close? :)
    Yea you are, people then just port match the 2.8 heads. I'm gonna be doing that along with 2.8 cams since I had a 2.8 NA motor prior to my swap which are more aggressive than RS4 cams. You won't see a huge difference with cams unless you go with GTs. Also I the you have to weld shut a few coolant holes on the 2.8 heads as there are more than on the 2.7, I believe. Won't know for sure until I actually get around to that.
    Go BIG or GO HOME!
  26. #186
    Jan 11 2007
    SLC,UT
    i take it either:
    am i close? :)
    2.8 heads have a way bigger intake ports to start with and come with more aggressive cams (almost the same as the RS4 cams). Also, the 2.7 head castings have bigger coolant ports in them, so you can't work them as much as you could 2.8 heads, though people are for sure also running 2.7 heads ported.
    --RS4 AIRBOX--
    LOOKING FOR:
  27. #187
    Mar 24 2009
    thanks for the replies, guys. i have a better idea of what's going on now. i thought i had read somewhere that the 2.7s we got here shared the same heads with the 2.8s - which is clearly not the case. that's pretty much why i was somewhat baffled.
    sorry to venture a bit off the focus of your build with this stuff. :) i'm good now though.
  28. #188
    Mar 11 2008
    north east
    awesome! great work and updates
  29. #189
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by Evilevo View Post
    Just curious, who told you that? Cause I've never heard anything about the stock intake valves, and I've talked to quite a few people.
    Also, my intake valves and heads have less than 60k on them
    --RS4 AIRBOX--
    LOOKING FOR:
  30. #190
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Trust me, CHANGE THE VALVES to at least stainless.
    If you want to keep the stock ones, dont put springs. This is riciepe for diaster.
    And you change your lifters too.
    You neen to put at least 2k in your heads if not keep the stockers, or take your 2.8 heads an swap everything from your S4's. I really think it's useless tho.
    Too hard to say what went wrong in my setup, the 5 valves are broken on cyl #1
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
  31. #191
    May 26 2008
    Potomac, MD
    haha, from him ^^^^^^^^
    But than again, i had 160k miles, so i wasnt putting stock back in anyway. My turbos came in and lets just say that no one is running them
  32. #192
    Jan 11 2007
    SLC,UT
    So I got these in the other day and I must say I'm impressed with the quality of the machining, packaging, and overall presentation. These look incredible in person, and I can't wait to get them on the car. Looking into one of the holes I see that they came pre-lubed, so it seems eurojet cares about the functionality as well, not just the good looks BTW these are the eurojet "Kugel" DV's
    http://www.eurojetracing.com/Product...0&Redirected=Y
    --RS4 AIRBOX--
    LOOKING FOR:
  33. #193
    Senior Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    Rocheste MI -> NYC April 1st
    I'm going to say it before anyone else does. Those look like grenades.. bad ass man post pictures when they are installed. When is the car going to be finished?
  34. #194
    In Limbo Two Rings
    Apr 18 2008
    Utah
    Sweet Dv's Jibberjive!
  35. #195
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by TweetsS4Estate View Post
    Already been said a little ways up And they're made to look like grenades. I'll be hitting the build up more seriously after about April 23rd, I just hope I can get most of the rest of the parts by then.
    Quote Originally Posted by Cobrakiller08 View Post
    Thanks Chris. You're setup running yet? If not, what's the holdup?
    --RS4 AIRBOX--
    LOOKING FOR:
  36. #196
    Registered Member Three Rings antoanS4's Avatar
    Jul 05 2008
    miami
    do you finish the project
  37. #197
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by antoanS4 View Post
    Is that a question? Past or present tense?
    I'm going to, but haven't yet.
    --RS4 AIRBOX--
    LOOKING FOR:
  38. #198
    In Limbo Two Rings
    Apr 18 2008
    Utah
    I have been swamped with work and this bad weather! I am almost ready to put the motor back in the car, every thing else is done. somethime next week it will be up and running.!! I may have one an altenator you can have, i have two of them sitting around one my be a a bocsh I need to check it out. I will let you know. Btw what did you do about your heads? did you call my friend?
  39. #199
    Jan 17 2008
    Right Behind You
    Lookin good. Glad you like em! Im happy to see another S4 running these!
  40. #200
    Nov 17 2006
    b5S4, mk4GTi
    Norf Las Vegas
    Quote Originally Posted by SlowGolf View Post
    where are my cool boxes?!
    and you guys need to reproduce the smic's that are on my car for the b5s4 ppls!
