If you try bleeding the lines with the car off, it will not open the ABS module and you will not get all of the old fluid out. The trick is to put the key in and turn it to the accessory position, and that will open the abs module.
I run HPS's for street (plus's in front for track), ECS SS lines, motul 600 fluid, and adams drilled rotors. The combo of this works awesome.
Make sure you get the power bleeder off of ECS and do not exceed more than 15-17 PSI, it makes the process much easier. Also wear eye protection. I was in a hurry and got a bunch of brake fluid in my eye when the hose slipped off the nipple on the caliper and got a bunch of that crap in my eye. Couldn't see straight for several days.
