Page 3 of 3 FirstFirst 123
Results 81 to 109 of 109
  1. #81
    Account Terminated Four Rings
    Apr 16 2007
    New Jersey
    Re: Dp testing and results THIS IS LONG SUPER LONG
    Quote Originally Posted by todd1010 View Post
    Wondering what a Milltek non-resonated exhaust would sound like with straight pipes (no cats)? Would this be the best option for hp & tq?
    Does Milltek make straight pipes? If not, what are my options for this modification?
    milltek does not make straight piped and is one of the more conservative companies when it comes to exhaust design. they off a dp design that designed close to stock specs and the exhaust piping is about the same diameter with stock. They just eliminate one set of cats and use high flowing mufflers and your choice of a resonator or none.
    My old setup consisted of milltek dp's (gutted, ofcourse) and FI cat-back with spiral core mufflers and an x-pipe. I did this because the milltek dp's are 2.25" while the FI cb is 2.5" in diameter. this allowed me to maintain good low end torque while gaining gobs of power in the top end thanks to the 2.5" CB.
    since then i have sold my setup and alot of parts on my car because i was planning on selling it. instead, i am keeping it and more intent to experiment with different setups just like Justin has for the benefit of these forums. Next setup will be a full FI exhaust with once again, gutted cats, but this time i will be going with x-pipe NON RES with the spiral core mufflers in search of more horsepower without the care of losing some low end torque. ill keep you all updated on that.
    oh and as for the sound, think Aston Martin
  2. #82
    Active Member Two Rings notachance's Avatar
    Sep 08 2007
    2005 B6 Audi S4
    North Jersey
    I know this has been asked a bunch of times but concerning the sound, is there a big difference? If I remove the precats and have that with my non resonated milltek exhaust, would it be extremely loud and overbearing? I definitely wouldn't mind being a little louder but I wouldn't want it to sound like a rice rocket.
  3. #83
    Apr 16 2007
    New Jersey
    Quote Originally Posted by notachance View Post
    It's loud and you will get people breaking their necks to see what flew by but from inside the cabin, you don't hear much. There is so much sound deadening in these cars that with the windows up, you can still hold a conversation without having to raise your voice at all
  4. #84
    Sep 08 2007
    2005 B6 Audi S4
    North Jersey
    See I'm worried about it being too loud. Has anyone who removed the pre cats have some kind of comparison to the loudness of it? And what about the resonance? I have the milltek non resonated catback and there is that slight drone if you want to call it that at around 1800 rpms where you kind of have to raise your voice to talk. Is there a much larger range of this with the piggies?
  5. #85
    Apr 16 2007
    New Jersey
    with the windows up you can talk on the phone just fine. its not even that loud at idle. above 5k its very loud. when cruising though, its not bad at all. with a catback like a resonated milltek, with the gutted dp's it should be as loud as a FI full back with the cats
  6. #86
    Senior Member Three Rings UnstableOS's Avatar
    Jul 23 2009
    80 Series TLC
    Wisconsin
    Excellent article..
  7. #87
    Veteran Member Three Rings duvinclunk's Avatar
    Nov 11 2006
    SLC, UT
    Word. Nice write up. I may just go around to a few shops to see if I can get my pre-cats removed. I'd go with vast but can't be without my car for longer than a day and don't wanna hassle with the core charge...
  8. #88
    Senior Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    Def some real great info. Nice to see this exposed. Comming from domestics I can tell you the pre cat thing had me baffled for the longest as this is one of the major things you ditch first in the exhaust system.
    The fact that the perfomance companys for the audi seemed to completly drop the ball on this one is kinda upsetting. Then only to have everyone carbon copy the same bad idea.. ha ha well thats biz I guess.
    I have said before that Im doing the headers but Im going to see if I can't get vast to do my Dp's here in the next few weeks and do a stock, to piggie to headers run threw
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
  9. #89
    Senior Member Two Rings cbdsm95gst's Avatar
    Mar 15 2006
    2004 S4 ARCTIC WHITE YEAH!!!!!
    oxnard, ca 93030
    Quote Originally Posted by mioStile View Post
    This writeup is awesome. But just to be clear, if you take out the stock pre-cat and leave in the main one, you most likely will not pass emissions, right?
    I gutted my precat and kept my main cat and was able to pass emissions with my B5 S4 in California. I was running the 02 sensor spacers and my check engine light would pop on and off because of it. I was still able to pass in california and the emissions were still way lower than the state limit.
    My White B6 S4... SOLD!!!
    CUrrent: 1976 Porsche 911 POS, but fun!!!!
  10. #90
    Senior Member Two Rings wva s4's Avatar
    Jan 19 2008
    09 GTR Premium, 08 Q 7, 96 Cobra
    Charleston,WV
    Justin, thanks for this and the motor research, its one of the things I missed about the 2.7. ( all the tuning and people trying anything to make power) Can you tell us where Vast relocated the o2 bung to avoid the cell. I am thinking of doing it myself, but only if I can avoid any cell issues. TIA
    SOLD 2007 S4 Sprint Blue DTM
    19" VMR's, Vogtland GT's,RS4 brakes, Hotchkis RS 4sways, Strat intake,Strat SS,Corsa Exhaust
  11. #91
    Senior Member Three Rings SpeedETC's Avatar
    Oct 29 2007
    2004 Audi S4, 2004 VW Touareg
    Poquonock
    ^ Information on the VAST setup is included in the following thread...
    http://www.audizine.com/forum/showthread.php?t=301828
  12. #92
    Jan 19 2008
    Charleston,WV
    thanks......
  13. #93
    Jan 26 2009
    2007 Audi S4 DTM, 2007 Audi A4
    Michigan
    I am getting my Vast piggie pipes installed on Monday directly from Vast, along with F.I. resonated exhaust. I am also going with the JHM/Vast tune to tie it all together. I will let you guys know what kind of difference I feel in terms of sound and performance from stock. I drive the piss out of my car (not on a track) so I will be able to notice even the slightest increase in torque/horsepower.
    JHM/Vast Tune- Vast Piggies- F.I. res-exhaust- K&N- Matte Black 19'' V710's- 20% tint
    Sorry but an avant is still a "Station Wagon" to me...
  14. #94
    04 Audi A4 USP,05 S4 Cabriolet
    Memphis, TN
    i couldnt find these on the vast website, im going to shoot them an email. $450 for a few hp would help
    justin, what are your thoughts on just vast DPs (precat removed) with stock exhaust for a little while?
    2004 A4 UltraSport
    APR 2+, Racetech FMIC, APR TIP, Southbend FE SS, Stasis 4:1 Center Diff, Neuspeed Exhaust/test pipe, Podi/VEI boost gauge, Stasis StreetSports, JHM Solid Short Shifter -1" Stern ACAs
    2005 S4 Sprint Blue Cabriolet
    Stock but 1 of 150
  15. #95
    Senior Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    Quote Originally Posted by Papachristou View Post
    I rocked that setup for a few months. When I got my catback I didn't notice any extra performance gains. The piggies will hint at a more aggressive sound that your stock catback will muffle. I had no plans to get a catback until I HAD to hear more of that v8 grunt.
    05
    JHM SM/LW Flywheel + Stg3 clutch | JHM Piggy's | Milltek nonres | JHM Tune | JHM 4:1 Center Diff | Neuspeed 25mm Rear Sway | APR snub | Apikol Rear Diff | JHM SSTS | Vogtland GT's
    SomeGuyInAChair - "I'll be honest about why I signed up for a car forum without thorough knowledge of cars. I merely did a Google search with the following key words: "milf cougar forum advice help tips"
  16. #96
    Memphis, TN
    Quote Originally Posted by ZachPDX View Post
    you said you didnt notice any MORE power when you added the catback later.. did you notice a little more top end with the precats removed/piggies and stock exhaust? its on my wifes cabriolet lol, i would LOVE the v8 rumble but she isnt wanting me to mod it any ... i told her she could scare off other drivers with the DPs and and a catback!
    2004 A4 UltraSport
    Stock but 1 of 150
  17. #97
    Mar 15 2006
    oxnard, ca 93030
    my setup is quiet untill about 3000rpm. past that its a beast.
  18. #98
    Forum Moderator Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Ya try E mailing vast or if your on the west coast try JHM. I think they do it now.
    You can do the modified Dp's on stock cat back. It will have a not super great sound but it will work.
    The Dp's are more power the Cat back is more sound. ZachPDX touched on the fact. There is going to be power in the cat back depending on what one you get the results are going to vairy.
    Ive said it several times and its true. The best chip for your car is a good set of Dp's. The cat back really will help tie it all in and make it sound real nice. But the sound Vs. performance is what you will have to decide
    If you don't have haters, then you're not kicking enough ass.
    AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
  19. #99
    Senior Member Three Rings charliemike's Avatar
    Jul 24 2008
    Quote Originally Posted by cbdsm95gst View Post
    I think those tests are such bullshit. My buddy's 1993 Ford Ranger passed a recent emissions test at half the max for the state of Maryland. Half ... And that truck is a 4-cyl POS.
    I'm not surprised your car passed to be honest. I wouldn't be surprised if the machines really were just blinking lights on an empty box to take everyone's $14 a year or whatever.
  20. #100
    Memphis, TN
    well, im going to add the catback at some point but im kinda low on funds with my engine build and the damn AC going out in this thing! Ill email vast, id rather them do it and put in the spacers or o2 relocate, im in memphis, no WC for me :(
    2004 A4 UltraSport
    Stock but 1 of 150
  21. #101
    Jan 21 2009
    Best to just have them do it and consider it taken care of. in some cases its worth the money you save but in this case best to just have it done right and call it a day.
    AMA member
  22. #102
    Registered Member One Ring mightyb28's Avatar
    Jul 01 2009
    denver, co
    Question What about the B6 DP??????
    Now you have been talking about a dual header system, what about the models that have single header and downpipe. What is the DP setup ( -p----m--)?? I thought it was ( -m------)??? Can we just move the cat south if my second diagram is correct? It is bolt on replaceable. If so i am going to remove the DP and put the cat at the bottom as the DP, or is that to far out of the 12-24" range?
    Brain boiling.... Confusion setting in...
  23. #103
    Jul 24 2008
    chicago
    Re: What about the B6 DP??????
    Quote Originally Posted by mightyb28 View Post
    Lots of variables. Is this is a V8 your talking about?
  24. #104
    Active Member Two Rings sp0da's Avatar
    Sep 08 2008
    2008 B7 RS4 - Daytona/Titanium
    Socal - Redondo Bch
    Quote Originally Posted by b00st View Post
    yeah been there done that. pay the lousy $450. save yourself hours of frustration. time is money. i've tried to use a crowbar in there and all sorts of things. not on my car...but others who wanted to do the piggies themselves. even on the b5 s4s. PITA!!!!!
    I just finished this project this weekend on my car, and PITA doesn't even begin to describe it. Torture! Unless you have access to an incredible arsenal of tools, do not attempt!
    $450 sounds like a smoking deal.
    Great write-up, thanks OP! I can honestly say it feels like a significant difference with the new piggies.
    2008 RS4 - DG/Ti -SOLD
  25. #105
    Jul 24 2008
    chicago
    Quote Originally Posted by sp0da View Post
    It can be an adventure getting the cats out. I have to agree with you, for the 450$ best go get the OEM gutted drop in ones.
    Its hard to make sure you get all the cat bits out from your main cat to. Several bits that fall down there while your pounding them out can be a hassle.
    I liked the idea on mine where I just put a pipe in place of the cat section. But for most people its not going to help with the visual inspection at the dealer or at the emissions area. Not only that but I don't like the idea of metal shavings falling into the main cat when your cutting off the pipe for your pre cat.
  26. #106
    New Member One Ring
    Feb 09 2010
    Europe, Slovakia
    Great thread Justin! Thanks! This is something you donīt find any information about here in Europe.
    Does anyone of you have any soundclips, I would like to go for the piggies, but would like to hear the sound of them with any catback. I couldnīt find any good clips on youtube:-(
    Regarding the Vast piggies - is it possible to get them shipped without sending them my system back? So I would keep my system as well and get the one with piggies shipped from them. Any idea of the cost then? Maybe Iīm blind, but I didnīt find that option on their web.
    Jul 24 2008
    chicago
    Quote Originally Posted by pavukS4 View Post
    I think you might have to call, or E mail them direct. Also try JHM
  28. #108
    Registered Member Three Rings tylerS's Avatar
    Aug 02 2009
    sea
    justin when are you going to update the teardown thread :(
  29. #109
    Veteran Member Three Rings brad65ford's Avatar
    May 30 2005
    03 Cobra
    Finially gutted the stock dp (only pre-cats). Wasn't bad at all to do with a air chisel (about 20 mins to gut) the pain in the ass is the removel of the dp as expected. Sorry if I'm writing like crap I'm tired as hell. I also did snub mount, Magnaflow cat back, and front rotors and pads today. All and all its hard to say how much the performance difference I feel since I did the catback also, but I don't feel that much of big difference even with both cat back and dp's gutted. Will report back when I have some time on her and the Stage 2 flash. Also no cel light ........ yet.
    2012 B8S4 S Tronic Black on Black
