Page 15 of 15 FirstFirst ... 5131415
Results 561 to 569 of 569
  1. #561
    Registered Member One Ring jpk774's Avatar
    Sep 22 2007
    2004 A4 USP/640 HP 1999 Mustang GT/BMW 335i Xdrive 2009
    Leesburg, Virginia
    Re: The beans...
    Quote Originally Posted by 400HPA4 View Post
    Car is still running, pretty much got everything dialed in on MS109, car is much faster than it ever has been before.
    I may take it to the dyno tomorrow, depends on how I feel today, I keep pushing a flight back to go back to work and it is costing me $$$.
    Hey,
    Impressive numbers. I am looking to do a Project on my 04 ultrasport. I have the APR exhaust, I also have sitting around a Biagio .50 A\R turbo and a cast hiflow manifold from a vendor I cant remember with a T25 flange.
    I want to run without the MAF. I had this setup on my 99 Passat. It ran great I had a www.fueltech.com standalone which is still in my possesion. LOVE the sound of the turbo during spool up with no filter. Like a 747 taking off. Plus the open BOV is great for making small animals and people jump on polls as I drive by and blow off.
    Anyway since the A4 is pretty similar what would you suggest I change? Should I use the 034 motorsport cable gas pedal and TB? I think I still have the intake and TB from the passat. Will that work? I didnt want to run forged right away although I do have the parts from the other car. Let me know what your feed back is.
    Tks,
    JP
    http://i114.photobucket.com/albums/n...ch_slapped.jpg
    -2004 A4 Ultrasport K03 GIAC stage 1/APR exhast/Drop in filter
  2. #562
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Re: The beans...
    Quote Originally Posted by jpk774 View Post
    Hey,
    Tks,
    JP
    Wrong thread, this is about Ultrasports... Here goes
    A. Good work on having the standalone, IMO its the way to go when really doing an intense setup.
    B. I would get the 034 gas pedal setup with the cable.
    If your running MAFless you shouldnt need an intake? Leave the intake manifold for now, you can make power without it, and the TBs are the same
    I would do rods at a minimum for the future, but I don't know what kind of power that turbo puts down so I can't tell you for sure, but anything over ~320whp you need rods
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
  3. #563
    Veteran Member Four Rings itsdarrow's Avatar
    Jan 27 2006
    Nyc
    Re: The beans...(475BHP on a 71R Eliminator, stock block)
    hey did gregs car ever hit the Strip with the new 30+psi file??
    black B6 a4, 18x8.5 anthracite bbs ch, Full frame gt28rs kit, 'OG' revo/ecode 440 file, high on meth.
  4. #564
    Nope, need a clutch to hold to torque...
    Maybe I will get around to it this month, Clutchmasters is supposed to make me a 10.5" twin plate setup
  5. #565
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    What is the normal size.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
  6. #566
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by Greg@DTH View Post
    Maybe I will get around to it this month, Clutchmasters is supposed to make me a 8.5" twin plate setup
    Corrected
    Quote Originally Posted by dirtybrd View Post
    FX600/700 is a 7.25" while the 850 series is 8.5". The S4 2.7 guys have already been using the 8.5" for a while.
    When it comes to making big power, Clutch Masters has the solution to get that power to the ground with the least compromise to drivability. Their new 8.5 in. “850 Series” twin disc units are rated at a range of 600 -1200 hp, and with the option of two different friction disc combinations, the units will fill the needs of a daily driver to the most extreme racer!
    Features include a billet aluminum cover, heat-treated diaphragm spring, billet aluminum flywheel complete with a replaceable steel friction insert. Kit includes the throw out bearing along with all the necessary hardware for an easy bolt up installation. All components are interchangeable, making it easy and affordable to maintain and extend the life of the unit.
    I dropped off one of my spare 01a transmissons for them to use for measurements and test fitting since they are only 40 minutes from my house.
  7. #567
    Active Member Two Rings techniq's Avatar
    Nov 27 2007
    Raleigh, NC
    Re: The beans...
    If you want to call David Sarabi, he has all of the data needed for APR cars and what can be done.
    Those Engineers in Auburn, AL are smart!!! They will get you hooked up!!!
    How far from reality is this? Does it require someone or an authorized dealer to push the envelope with APR? And does anyone know if this may be work in progress? When I contact APR I just hear NOPE.
    [ 05 A4 1.8TQ :: APR Stg1+ :: SB Stg2 :: 3" Exhaust :: K&N :: FMIC :: Forge DV :: 18" Kyalami :: RS4 Sway :: STS Coils ]
  8. #568
    New Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    Is this available to buy yet?
    ReVO BT and a bunch of other stuff
  9. #569
    Veteran Member Four Rings 400HPA4's Avatar
    Jul 04 2004
    2002 Audi A4, 2002 GTI 337
    OC
    Yes, contact Sarkis at Eurocode Tuning (310-379-3876) and he will hook you up.
