Page 3 of 3 FirstFirst 123
Results 81 to 93 of 93
  1. #81
    Senior Member Three Rings xileh's Avatar
    Nov 06 2008
    Audi A4 B8 and Audi 100 20vt q
    Norway
    Those who hate fake splits now, may just say what they want. I don't want to use more money on wheels than the car is worth.
    Also hadd to see how they will look on the car.
    Front
    Rear
  2. #82
    Nov 06 2008
    Norway
    Managed to fix the rear damper. Made a hole in the trunk, and then I was able to use a new bolt and nut :) Anyone knows if this is bad to cut in the trunk like this? It is a very thin metal plate, so I don't think it will weak the car any?
    A few more pictures from the test fitting:
    Front:
    Needs a smal spacer here, to get room for the brakes. They are very close to the wheels, due the high offset, and that the wheels got a lip.
    Rear
    Maybe I have to mod the rear fender a bit. Think there will be a very tight fit. But I will make it work :)
  3. #83
    Nov 06 2008
    Norway
    Picked up a front splitter from Renault Espace today. Will try to fit this to se how it looks instead of the original black splitter on the front bumper.
  4. #84
    Nov 06 2008
    Norway
    Testmounted the front splitter some days ago. Think it might be good, when I get a front that is in good shape. Will swap the front with one that is not damaged.
    And also fit the splitter better. This is just "bolted-on" without modifications.
    And a couple pictures of the car. Don't mind the rusty spots and things like that. hope to have this fixed before the summer, with some new paint :)
  5. #85
    Nov 06 2008
    Norway
    Got tires on the wheels, and hadd to test fit them. Tight fit on the rear fenders. Guess I have to roll out just a few mm. :roll:
  6. #86
    Active Member Two Rings m2giorav's Avatar
    Nov 06 2009
    Viljandi/Viljandimaa/Estonia
    Sweeeet
  7. #87
    Nov 06 2008
    Norway
    Thank you :)
    New project car that I will rebuild like the tricolor:
    The V8 is in place in the garage :)
    Not that nice with extra lights, but very nice to have during the winter. Theese will be removed again when the summer is here.
    As you can see, I also have replace the bumper with one that have foglights that are not broken.
  8. #88
    Nov 06 2008
    Norway
    Engine and transmission out :)
  9. #89
    Nov 06 2008
    Norway
    Startet removing the interior:
  10. #90
    Nov 06 2008
    Norway
    Removed dashboard and inner roof/sunroof:
  11. #91
    Nov 06 2008
    Norway
    More wireing removal:
    Finally outside of the car:
    Ready for removal of the noisekiller in the floor
    Started in the trunk:
    Now it is time to look at rollcage and stuff like that :)
  12. #92
    Nov 06 2008
    Norway
    Not that exiting update. But the removing of the asphalt plates are done. Just need some stuff to wash the rest of with. Hera someone recommend gas, so guess I will try that.
  13. #93
    Nov 06 2008
    Norway
    Some pics with the summer tires on.
    Also, still working on the V8. Just not that fast due to much snowmobile riding lately. But now the season is over soon, and my time will be spent on the tricolor project
