Friday night Greg (actlsub9) and I logged the Avant extensively with some 110 in the tank and my 93file on the ECu. We did a baseline pull with no timing adjustments and the gas in the tank (after driving it a bit). Then slowly increased timing advance via Lemmiwinks. Did 3 to 4 WOT pulls in 3rd gear of each setting after driving it a bit in each setting. Over 20 pulls in total and we used up all 5gallons of 110 I put in the tank (guess I like data
I was looking at the absolute timing curve and the correction factors associated. Figured CFs in the 4-5 range were acceptable as long as the timing curve looked good. The goal was to get the curve as high as possible from 5rpm up to redline. My thoughts here was that this would ensure the most amount of power possible given what I had to work with (file on ECu and gas in tank).
Here is an overlay of all the settings we tested including baseline. We chose what seemed to be the best curve from each setting. Each pull within each setting was very close to each other. The pulls were done with a minute or two inbetween. Factors such as road, traffic, how long it took me to copy and paste, look-out for police, etc... played a role as to the time between pulls.
We settled on the +8.25deg curve.
Why? That seemed to net the best amount of timing advance with what I had to work with. CFs were in the 4-5 range. It also holds more timing from 4.5krpm on up when compared to the +10.5deg curve. The +10.5deg curve also netted CFs in the 9-10 range which was a little too risky for me. Esp knowing the ambient temps during our pulls was around 27F and the dyno room on Saturday would be in the mid-30s (estimated).
Asleep sometime after 2am. Wake up around 6:30-7 to take care of the dog and put another 5gallons of 110 into the Avant. Off to caravan down to EPL in Stratford.
Black B5 S4 sedan w/ K04s.. EPL tuned
Casa White
B5 S4 avant w/ K04s... homebrew tune
Dolphin Gray B6 A4 sedan w/ MTM K04
Denim Blue B6 A4 avant w/ 2.0L stroker
On the way home we had another Black B5 S4 sedan with us.
The best part of the trip was the short tunnel on the Merritt parkway. All four of us got on it in that tunnel. Sounded like a racetrack. It was music to my ears.
I was the 3rd car since a few people weren't there yet. All three pulls were within a 5min span and they overlay right on top of each other (repeatable!). I didn't log the car while on the dyno
and am kicking myself for it. Would have loved to overlay the timing curve from the dyno with my logs from the previous night.
Right about where I expected to be. The power curve is the same as my 93file but offset given the fuel and timing tweaks. Holds pretty steady out to redline
. We did not continue up to 7400rpm since it was somewhat steady and tapering off. Torque curve is huge but dies rather quickly and at a faster rate than my 93file with 93oct.
Now this isn't a direct comparison with the ASP dyno since I tweaked my file a bit but you can definitely tell both dynos read about the same. Makes sense since they are the same brand and are running the same software.
dyno pull #1:
http://www.youtube.com/watch?v=1XYZwzctn4E
dyno pull #2:
http://www.youtube.com/watch?v=5mwpiZvppxo
some more photos:
http://smeraglinolo.com/dynoday08/
and ones I took:
(3.6L swap!)
late day R32 tweaking...
I got to meet both Tony@EPL and Jeff@C2Motorsports. Both guys are extremely knowledgeable with Motronic. I recall having a great conversation with Jeff about his latest gen (turboed) R32 that he's tweaking and writing software for. Pretty impressive the stuff he's doing.
