Page 7 of 7 FirstFirst ... 567
Results 241 to 248 of 248
  1. #241
    Account Terminated Four Rings
    Apr 16 2007
    New Jersey
    get those iridium plugs out of there and get either oem ngk or bosh's, your losing around 40-50 rpms/sec with those and that carbonio logs over 20 degrees higher IAT over stock airbox. put your stock box on there with a K&N and delete your cats and you should easily accomplish your goal
  2. #242
    Senior Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    2005 B6 S4 DG
    a canyon road in SoCal
    Quote Originally Posted by 91gl View Post
    the intake is complete sealed from the engine bay with dynamat and foam strips. Cats will be deleted once the new smog testing goes in effect in California (early 2013) but how could the plugs be a problem?
    Power: JHM Supercharger Stage I, JHM Custom Tune, Intake Manifold Spacers, Carbonio-JHM hybrid Intake, 034 MAF Hose, FI Downpipes & Cat Back, Carbon Fiber Vented Hood
    Power supporting: APR Snub, 034 Engine & Trans Mounts, Apikol Rear Diff Mount, JHM Oil,Power Steering & Trans coolers
    Handling: PSS9 Coilovers, Hotchkis Front & Rear sway bars
    Brakes: B7 RS4 Front & Rear Brakes, StopTech SS lines
    Slips: 12.7@110, 0-60mph in 3.9s : LIKE A BOSS
  3. #243
    Forum Moderator Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Quote Originally Posted by CHECKERED View Post
    Checkered. I got your E mail and the new list will go up in the next month or so. I try to update it every quarter.
    The plugs can be a big power drain if there not 4 post. Ive seen other cars really suffer power wise if they don't have 4 post plugs..
    If you don't have haters, then you're not kicking enough ass.
    AMA and YES! Together we can all defeat 2.0t and 2.7t crime...
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
  4. #244
    Aug 17 2008
    2005 B6 S4 DG
    Quote Originally Posted by Justincredible View Post
    From a thermodynamic point of view the spark will jump to the post with the lowest resistance, in air this will be the one closes to the tip if one post is 0.0003” closer then the rest the spark will jump to that one.
    In an engine environment it will jump to the post where the fuel/air mixture is thinnest, creating a small flame front point, while with a one tip spark plug it will consistently jump at the same spot creating a better flame front rather then start at the thinnest point.
    Am I missing something here, do I want a small flame front rather then a consistence one in the middle of the cylinder?
  5. #245
    Jul 24 2008
    chicago
    In theory that all sounds good but there is much more to it then that. While I understand the concept Im not well versed enough to explain fully and to be able to state facts. I can say that some plugs will effect the power out put of the car to a very noticeable extent
  6. #246
    Senior Member Four Rings boravr6's Avatar
    Aug 14 2008
    06 B7 S4 6MT // 06 B7 A4 2.0T 6MT
    Ontario
    13.36 @ 104.16 mph. 1.911 60 footer.
    2006 S4 6MT // JHM 93 tune (94 gas) FI 2.5 catback // Miltek 2.5 catless DP's // LWCP // LW front rotors // intake spacers // baby seat
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2006 TD1 Imola B7 S4 sedan 6MT
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
  7. #247
    Stage 3 Forum Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 23 2005
    B6 S4 and B5 S4
    Lathrop, CA
    Quote Originally Posted by boravr6 View Post
    Baby seat FTW.
    Have Saki show you how to rake that sucker on the launch and you can get closer to the 12s. What RPM are you shifting at? 6500rpm has been optimal for us in ALL Motor configurations, with or without headers, even with or without the intake manifold. Without a blower it just slows down if you shift past 6500rpm. We shift our blower kit at 6800 to 6900rpm since it loves RPM.
    Keep us updated with any return visits.
    BTW. It was nice to meet you during my last trip to Detroit.
    JHMotorsports.com - 209-968-0077
    What is JHM doing? Find out! Follow us on Facebook
    2005 Audi S4 - JHM Stage 1 Supercharger (ET: 11.96 @ 116mph)
    2005 Audi S4 - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph)
    2005 Audi S4 - JHM Nitrous (ET: 12.29 @ 117mph)
    2001.5 Audi S4 - JHM Stage 3+ (ET: 11.1 @ 130.7mph)
  8. #248
    Sep 27 2008
    Hobart IN
    ^^^^^^^ It must be the baby seat mod thats working all the magic. I have two in there now so it should really help the next time i hit the track.
