Results 1 to 12 of 12
    Veteran Member Three Rings Fink_tha_Audi's Avatar
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Middletown, Delaware
    How to tell if you have turbo failure?
    Well went to the exhaust shop today to weld up where there were clamps and they told me that my car had some rattling sound coming down the downpipe, that it could be from the turbo. So is there any way to tell if there is any problem with my gt2871r. I will post up a sound clip or something for you guys to listen to. Any suggestion or comments would be great.
    Registered Member Two Rings GDT's Avatar
    Nov 05 2008
    08 A3 3.2 S LINE
    SAN MARCOS CA
    Re: How to tell if you have turbo failure?
    So I went to trade in my 2.0t and the sales manager said that i had a turbo failure. He said that he could hear it when i pulled in the lot. So the rattling you heard yeah thats a turbo prob. Better have it taken care of bro
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    just take the intake pipe off and see if the shaft has any play in it. most turbos sound like a dentist drill when they are on the way out and the sound normally gets worse as time goes on. a "rattle" could be anything.
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Quote Originally Posted by ghost6303 View Post
    Yea it definitely does not sound like a "dentist drill", I guess it when I rev it up and like rpm come down is when you will hear the most. But ill doing to do what you told, just see if the shaft wiggles right?
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    It's likely the wastegate assembly rattling.. That's what mine was like before I changed the turbo.
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Sep 15 2008
    97 A4 1.8T Quattro
    huntersville, NC
    my car has a rattle, had a guy from the dealer check it out and turns out to be my heat shield. but it does get kinda annoying
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Quote Originally Posted by erikas3 View Post
    Is there any way to check that without taking the whole thing apart.
    Senior Member Three Rings xraycer2012's Avatar
    May 28 2008
    An Audi
    Items for Sale
    Quote Originally Posted by price View Post
    I had a rattle too and it was a heatshield, that's probably what it is. and you could only really hear it when the revs dropped
    '14 S4
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Quote Originally Posted by xraycer2012 View Post
    I have no heatshield.
    Nov 07 2008
    '97 A4 2.8QM
    Mountains of Colorado
    Quote Originally Posted by Fink_tha_Audi View Post
    You should get one from Blink Tek Design, check em out at www.blinktekdesign.com
    Otherwise, rattles can be a number of things, you may have play in the turbo, could be metal klinking together elsewhere in the car, have you personally scoped the sound out?
    '97 Audi A4 Quattro, 2.8L 12V V-6, 5-Speed Manual. ~The Daily Driver
    '96 Chevy Camaro Z/28, 350(5.7L) LT-1 V-8, 3-Speed Auto. ~The Weekend Warrior
    "Take it Easy...And if its Easy, Take it Twice." -KajunAudillac
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    i have the blinktek shield and love it. my commute to work is 45min to 1.5hrs depending on traffic. its a mix of stop and go and 80+. when i get home the EM/Turbo are hot as balls (not glowing), and the filter is still ambient. the shield turns your HAI into a CAI.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Sadly, no there isn't.. You need to take the downpipe off of the turbo..
    Basically what happens is the flap that opens/closes the gate gets loose (like in my case) will break off and you will not be able to produce any boost.
    When I was researching this, I saw that it was fairly common with K03's..
    Soon to be BT...
