Page 9 of 10 FirstFirst ... 78910 LastLast
Results 321 to 360 of 380
  1. #321
    Registered Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    Terminator Cobra
    Chicago NW Burbs
    Squiddy, that's exactly why these things are dropping like flies at 100k+. Poor maintenance intervals, improper warm up/cool down, and shitty oil.
    Quote Originally Posted by marshall834 View Post
    How many miles did you have the cold rattle for? How many miles are on your car right now?
    It's always had the cold rattle, but I have only had the car since 83k. I have 98k now.
  2. #322
    Established Member Two Rings marshall834's Avatar
    Oct 16 2011
    Reno, NV
    Quote Originally Posted by SquiddyB6S4 View Post
    Audi didn't set a life expectancy for these parts anywhere. Their design engineers probably did the best they could to give it life, but with low production volume comes limited budgets for development as well, and since all of these parts are unique to this car, that's not good for us. The bean counters, advertisers, and lawyers who stretched the service intervals to 10k miles didn't do the car any favors. Also not helping are the previous owners who figured that because on other cars, they used to go 5k when told to go 3k and they were fine, then going 12k when told to go 10k must still be fine on their new car. People who don't understand how an engine works or at least appreciate the violent forces inside are much more likely to figure that their lunch date with their girlfriend is much more important than getting the oil change done this week. I told my girlfriend that just driving down the highway, each of my pistons undergoes acceleration equal to thousands of times the acceleration due to gravity on Earth, and that that acceleration changes direction 100 times per second. I said "that is why I'm fine with paying $170 for 10 quarts of ultra premium oil."
    In any case, Audi's original documentation remains legally unaltered, and states that the timing components are good for the life of the vehicle. As we know, this is not always true.
    Good point.
    Besides using a good oil and changing it within 5K miles, what else can we do (if anything) to help minimize the issue?
    2004 Brilliant Black Audi S4 MT | Black and White Alcantara | K&N Drop In | JHM 91 Octane Tune | JHM Piggie DP's
  3. #323
    Jun 05 2011
    Cambridge, ON
    I realise that this would require people to be near 200k mi, and the sample size might be rather small, but the new chain tensioners/guides have a new part #, right? Has anyone experienced a failure with the new ones? I ask this because I already have the new ones in my car, and I have no issues, (mine were done at 65k mi), and I'm curious if I should expect to do it again at 165k, or if these ones last longer?
    FWIW, the car I came from was a rather modest Toyota Matrix. I know those cars like the back of my hand, and have helped replace motors/supercharge/turbocharge/pretty much everything those econoboxes, and they use the same style of tensioner on their single chain, and I have never ever heard of one failing ever. I've seen a few even get up over 2-300k mi (even one guy who apparently has over 400k mi).
    Now, cracked piston lands, blown up oil pumps, and spun bearings galore. But no broken chain tensioners on motors with an 8500rpm redline. Surely the technology is out there.
  4. #324
    Mar 26 2007
    Colorado
    It will be 2015 before I hit 100,000 miles in my B6, So I have some time to not worry & keep up on my Oil changes.
    CURRENT:
    2011 B8 A4 Avant
    2011 Infiniti g37
    2008 4Runner
    2015 GMC sierra
  5. #325
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by vdubjetta02 View Post
    Got you beat.. buy my current mileage per yr. it will be around 2022..
    by then I most likely will have a used Audi space ship.
  6. #326
    Veteran Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    B6S4, CD5, Gen4 T4R, NA8 aka ugly track slut
    Teh!cks-us
    Quote Originally Posted by dnm View Post
    . . . they use the same style of tensioner on their single chain, and I have never ever heard of one failing ever. I've seen a few even get up over 2-300k mi (even one guy who apparently has over 400k mi).
    Tensioners fail on all cars if you wait long enough. High-strung Euro sports cars especially so. Small production number cars especially so. I bet your Toyota's timing chain was on the front of the motor, rather than sandwiched between the hot engine and the hot flywheel. It probably also had a small oil capacity, helping the oil warm up quickly and provide good protection more of the time. Besides, nobody said tensioner failure was a guarantee on this car. It's not unheard of, but it's not the norm.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist, Squid Rear LSD #01 20lb wheels + Michelin PSS
    2013 Veloster Turbo 6MT - For sale
    1996 Miata - DE car; every moving part new or rebuilt, almost stock
    1995 Accord Wagon - Beautiful, stock, DD Duty, trip-mobile, track day support wagon
    LifeWithSquid
  7. #327
    Jun 05 2011
    Cambridge, ON
    It was more a reference to the fact that the tensioners being made of plastic isn't a problem; many companies use that style, and they generally don't fail.
  8. #328
    Veteran Member Four Rings crabpot's Avatar
    Apr 16 2008
    2008 Chevy Silverado 1500
    Mill Creek, WA
    They generally don't fail on this car either, but it happens.
  9. #329
    Mar 26 2007
    Colorado
    there is an amazing thread on ******************* about why they fail....
    CURRENT:
    2011 B8 A4 Avant
    2011 Infiniti g37
    2008 4Runner
    2015 GMC sierra
  10. #330
    Mar 11 2012
    fond du lac WI
    Timing chain replacement
    Quote Originally Posted by Blackcoog View Post
    It's funny that the thread started out as a tensioner issue and then after an engine picture is posted people freak out about the plastic tensioners. As mentioned previously other manufacturers use plastic tensionsers as well. All the ford motors I've worked on (100+ motors) have had plastic tensioners and I've never had an issue with one of them. I've never had to swap guides because of a wear issue (even on high mileage motors). However, I have had to swap tensioners because they wouldn't pump up. Chances are you'll have a tensioner go bad before a guide would ever go bad. Stop worrying about the plastic guides!
    If you are quoted $5k+ to fix this issue then look for another mechanic. Even if it takes three full days to fix (24hrs total) at a crazy rate of $160/hr that is still under $4k. You could also look at getting a low mileage salvage yard motor with a warranty and selling the old motor off to recoup some costs.
    I just the entire timing chain replacement on my buddys S4 4.2l. He had a quote from an Audi dealer I am not sure which one but he was quoted at $3600 total. I did it for$2000 and he spent around $500 on parts. Wasnt so bad of a job took a few days but I took my time and he helped out also. It came apart and went together fairly easy enough. I would definately do it again for that price;)
  11. #331
    Sep 13 2008
    Terminator Cobra
    Chicago NW Burbs
    They're technically nylon. No plastic
  12. #332
    Veteran Member Three Rings noznab's Avatar
    Jul 08 2007
    Tri-State
    Quote Originally Posted by autoWItech81 View Post
    What parts did he replace for $500? The tensioners alone are nearly a grand a piece
    A few mods here and there
  13. #333
    Oct 03 2011
    2007 S46MT, 2011 S46MT,2009 R1
    Sacramento
    yeah can you elaborate on what exactly was replaced?
  14. #334
    Nov 11 2011
    Andover/Rockport MA & Shanghai
    Quote Originally Posted by B6JoeS4 View Post
    Err it's a weird universe in which nylon isn't called a plastic.
    Don't get me wrong - I've worked with a lot of different thermoform/thermoset polymers and I'm not saying plastic isn't perfectly OK for an application like this. What most people don't understand is these plastics are "filled" with various things - fibers, minerals, metals, etc. so it's not just like melted down nylon stockings... That's why it works fine in this applications in a lot of engines...
    The argument to be had with Audi is more sticking the stuff on the back of the engine and making it difficult to maintain
  15. #335
    Veteran Member Three Rings J0HN_R1's Avatar
    Jul 05 2010
    completes me...
    Calgary, Alberta
    Just got my car back today from the shop, tensioners (plural) went @ 155k KM (98k miles).
    $5000 ($4400 covered by warranty) and 6 weeks later (he's super back-logged), my car runs like a champ. George @ Tune Dub rocks.
    * rental car cost $600-$650, which warranty only covers $250 of... All said 'n' done, I still paid $1000 +/-...
  16. #336
    Established Member Two Rings maskinut's Avatar
    Nov 03 2006
    San Francisco
    Quote Originally Posted by nimski62 View Post
    TDI at warm idle??? that sucks.. these motors are made for 100k and thats it.
    you aint kidding
    @seanjregan
    2012 Audi S4 Titanium Red/Black DSG (VIM, Plate Filler, Streaming Audio, Valentine 1)
    2004 Audi S4 Red/Black 6 SPeed (RNS-E w/BT, DVD, TV, Zune Video, V1, K'nN, MilltekR, BBS SX18's, Kuda)
    1996 Audi A4 Red Black 5 Speed
  17. #337
    Jan 14 2008
    Calgary
    Quote Originally Posted by J0HN_R1 View Post
    Eff me. I always wondered what he'd charge for when/if the day comes. I'm sitting at 112K right now. What were your oil change intervals like?
  18. #338
    Veteran Member Three Rings Lornnn's Avatar
    May 01 2011
    Wisconsin
    looking at coming from a B5A4 to a B6 but this entire topic may be a deal breaker..
    i'm no stranger to DIY maintenance and repairs with the 2.8 which leaves little room to work in the engine bay
    but getting at the rear of this V8 sounds like an entirely different headache
  19. #339
    Mar 26 2007
    Colorado
    Quote Originally Posted by Lornnn View Post
    I like to tell people, Do NOT buy an S4 unless you have safety net of cash for maintnence repairs if/when they arrise.
    CURRENT:
    2011 B8 A4 Avant
    2011 Infiniti g37
    2008 4Runner
    2015 GMC sierra
  20. #340
    May 01 2011
    Wisconsin
    thats a given, i'm concerned about physically being able to carry out repairs
    but if an engine pull at 100k is necessary for this job then ehh.. might settle for another B5
  21. #341
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    People think that this happens in all B6/7 S4s. The fact is, it doesnt. You only hear about the ones that do. Main thing- maintain your car and it will treat you right.
    Dolphin S4 Cabriolet
    Misano RS4
    IG @dinuzzohyeah
  22. #342
    Established Member Two Rings mlittleton's Avatar
    Nov 21 2011
    2006 S4, 2002 E39
    Atlanta
    This still scares the crap out of me. I'm at about 73k now and worried if I should try to trade the car out at 80 to 85k or so. Which would suck becuase then it would be a waste to do anymore mods. Exhaust, tune etc.. Any reports of B6's or B7's hitting 150k+ without any timing chain issues?
    2006 Audi S4 / Black on Black / 18" S5 Reps / Akebono Euro Ceramic - R1Concepts drilled/slotted rotors
  23. #343
    Jan 29 2010
    north ga
    An engine pull is necessary to replace the turbo's on a B5 S4, so I see the timing service as being roughly equal to that. The cost would often be about the same depending on what turbo's the B5 guys put in
    Quote Originally Posted by mlittleton View Post
    This still scares the crap out of me. I'm at about 73k now and worried if I should try to trade the car out at 80 to 85k or so. Which would suck because then it would be a waste to do anymore mods. Exhaust, tune etc.. Any reports of B6's or B7's hitting 150k+ without any timing chain issues?
    Yes there have been several S4's to get above 100k miles with no problems (My car was at 130k when I sold it and had no timing problems). There are some B6'ers who have gotten to and above 150k miles but it is more rare. The timing components were redone for B7 so their longevity should be even better than B6's. The rebuild does cost a lot but it's part of being an S4 owner. You'd go through a very similar case if you owned a B5 and had to pull the engine to replace turbos. It's part of the game, you got to pay to play. Having to do this once every 120-200k miles seems pretty reasonable to me, even if the cost is high
  24. #344
    Nov 03 2006
    San Francisco
    I had my b6 for sale with 105k @ $14,900. Everything was running great and lots of interest. I got too busy to actively sell it and let the interested buyers stack up in email. @ 110k the cam adjusters went. My dealers gave me 8k for it.
    For some reason I just bought a 2012. Not logical. But, fun to drive.
    @seanjregan
  25. #345
    Nov 21 2011
    2006 S4, 2002 E39
    Atlanta
    Well said and makes me feel quite a bit better.
    Quote Originally Posted by maskinut View Post
    The new S4's are very sharp looking cars. I would certainly miss the v8 but I know the 6 S/C is comporable. What are your thoughts on it compared to your B6?
  26. #346
    Veteran Member Three Rings Kem's Avatar
    Aug 30 2004
    13 S6 4.0t, 10 A6 Avant 3.0T
    Oakland, CA
    As much as I love the sound of the V8, the 400whp the B8's are putting down with a tune/sc pulley are hard to argue with.
    '13 S6 4.0T : Estoril Blue : Black/Carbon Atlas : LED headlights : BBS CI-R 20x9 : APR : AWE Exhaust : Roc-euro intake : Eurocode sways & endlinks : Airmatic lowering links : 034 trans & diff mounts
    '10 A6 Avant 3.0T Prestige : Night Blue Pearl : Amaretto Interior : GIAC : H&R/Koni Suspension : Custom Exhaust : RS6 Grill
  27. #347
    Nov 21 2011
    2006 S4, 2002 E39
    Atlanta
    Quote Originally Posted by Kem View Post
    Oh wow I hadn't stopped to think about the SC'd 6 being much more tunable. Seems there is always much more performance to be squeezed out of a turbo or SC'd whip. 400hp is no joke!
  28. #348
    Mar 31 2012
    bavaria, germany
    2004 audi s4 b6....154000 miles. Slight rattle on cold start and regular maintenance...that's about it. no timing chain tensioner issues yet(knock on wood) lol
  29. #349
    Established Member Two Rings buck15's Avatar
    Aug 01 2011
    Twin Cities
    Quote Originally Posted by weah10 View Post
    When did your cold rattle start?
  30. #350
    Mar 31 2012
    bavaria, germany
    cold rattle started around 78k miles mark. Initially scared the heck out of me, but I was informed by both Audi dealership shop and by an independent mechanic that this is "normal" lol...I notice that the noise is less after oil changes and reappears at near the mid point/end of my oil change intervals( used to change every 5k, but since I hit the 100k mark, I do it every 3k). I pretty much resigned myself to not "if something happens" but "when"lol. Thus the necessity of my "emergency/unplanned" repair fund....
  31. #351
    Aug 30 2004
    Oakland, CA
    I get the cold rattle everyday, switching to Motul 8100 x-cess didn't change a thing. It's the standard 1 second rattle. Never rattles after that.
    Would a Blackstone labs oil analysis find anything if tensioners or guides were breaking down?
  32. #352
    Mar 06 2012
    Finland
    I have now 120k mil on my B6 and I get the cold rattle everyday and well it is how it is. If it would do the same noise when warm and all the time, I would worry about it, but on a cold engine when there is no oil pressure on the chain tensioner I think it is more or less normal on this engine. It just is noise making, oil eating beast and I just love it :)
  33. #353
    Active Member Two Rings Latosa's Avatar
    Jul 17 2011
    1986 scirroco 16v,1982 rabbit 16v turbo 543whp sold,s4 2004 6mt
    Aguadilla,P.R.
    well first you will see this is my first post ,second a lot of good info in this thread I read it all in one day , not new to audi,vw,porsche
    ect european cars ,let me introduce my self I'm licensed aircraft tech and automotive tech for 18 years now.I have been doing roadracing,drag racing ,motorcycles,custom tuning,and I do all my fabrication my since I'm certified TIG welder also .I just got a B6 S4 from a friend dirty cheap with 40k on it and yes mine rattles sometimes cold and hot ramdomly I 'm second owner of the car and the first owner took care of the oilservices always .So now not beat the dead horse any more !!!!!has some one has tried to create a way to PRIME THE OIL SYSTEM before any start up, reason I asking is because I know the way to do this . and that would prevent all the parts related to timming to wear out do to cavitation in the oil lubrication system ,that the parts would wear anyways yes ,will they last longer yes ,will this solve the problem don't know .if I'm going to try it yes ,just need to get all the sfuff i need .I hope this does not offend nobody and excuse my grammar since my first language is ESpanish.
  34. #354
    Veteran Member Four Rings ilko's Avatar
    Oct 20 2007
    997TT, 993, W211 E55 AMG Wagon
    Upstate Manhattan
    I've thought about priming the oil system as well. I do it in my air-cooled Porsche if I don't drive it for a few weeks. On the Porsche it's pretty easy - remove the fuel pump relay and then crank until the oil pressure gauge goes to the 4-5 bar mark. The Porsche also uses much thicker oil - 20W-50.
    I suppose you could pull the fuel pump fuse on the Audi as well and crank it to build oil pressure. But I don't think that's a very good solution on a car that's driven frequently. I'd also like to see when the oil pressure rises but unfortunately there is no way to do that on the Audi since the oil pressure sensor only has 2 readings - "yes or no" oil pressure.
    But if there is a way to prime the oil pump the same way you prime the fuel pump with the ignition on then we are in business
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
    Previous: 993 Carrera 4S / 964 RS America / 964 Carrera 4 / 944 Turbo / MK4 Golf R32 / C5 allroad / B6 USP Avant
  35. #355
    Jul 17 2011
    Aguadilla,P.R.
    By the way that is what I'm refering ,turn your ing on wait 2 to 5 sec and that's it .start your car build the pressure without cranking the engine .I have done it in all my racing cars.Fuel prime is another thing separate from the oil also can be integrated too but we have that already.is something that is been around for ever since world war II used in aircraft with radial engines.
  36. #356
    Oct 03 2011
    Sacramento
    correct me if i am wrong, but the oil pump is driven off the chain?? thus the only way is to somehow turn over the engine...
    I believe audi's latest software update makes the engine crank for an extra second or two to adress this problem...
  37. #357
    Oct 20 2007
    Upstate Manhattan
    I don't think you're wrong, the oil pump is chain driven. Same as on my 911, that's why it requires cranking to prime it.
    How would we know if we have the latest software update?
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
  38. #358
    Oct 03 2011
    Sacramento
    Quote Originally Posted by ilko View Post
    go to audi and pay them $180 to connect a cable to your car!
  39. #359
    Oct 20 2007
    Upstate Manhattan
    Heading over there first thing in the morning!
    /sarcasm
    B7 S4 Avant - sold
    997 turbo
    993 Carrera
  40. #360
    Jul 17 2011
    Aguadilla,P.R.
    the system I'm talking is not cranking the engine is just turning your ignition on waiting 2 to 5 sec. and starting your car ,its called sump prime as we called it in aviation it only consist of a reservoir with either a 1 quart extra , a head pressure,and a valve electrically controlled when you open your swicht or press your clucht to start your car.
