Page 2 of 2 FirstFirst 12
Results 41 to 66 of 66
  1. #41
    Jul 14 2008
    Audi A5 3.0TDI Q, Nissan Navara -08
    Skellefteċ - Sweden
    Re: People With OEM Navigation
    Quote Originally Posted by winston@podi.ca View Post
    What DVD and media interface did you get?
    I'm thinking of putting one in so my passenger has something to watch during long roadtrips.
    Dont know the modelname its like a No-name-brand but it gets the job done, and it have a USB port and its Xvid compatible so you can fill an USB-stick up with friends, plug it in and drive all night long!
    But i think its the one that http://www.kufatec.de sells. But i bought mine from a guy in the UK.
    Cheers
    Audi A5 3.0 TDI Quattro S-line, Audi Exclusive Misano Red, 19" Audi Exclusive line wheels, MMI+, Audi Bluetooth System+, AMI, Tint...
  2. #42
    Senior Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by F.An View Post
    Its so much more simple to put the gpsantenna behind the speedo instead of pulling two doorsil, backseat, c-pillar and to find the connecting fakra cable. it takes like 30 sec to mount the antenna. Ive done it my self. I hade a Concert II+ (thats the same unit as he has but his have a CD changer built in.
    The DVD slot works for CD but you cant get the mapscreen or navigate with the DVD out. The SD-cards have some limit in folders and in songs. The color DIS works flawlessly with the RNS-e. But if you have the red one youll need to turn off the RNS-e and back on again to see the instructions. I made the swap myself and everything you can have to the regular radio, such as: BT, Ipod, sirius. will still work and will plug right in the back of the headunit.
    I Bought a DVD-player and mounted it in the top of the glovbox and i bought a media-controle-interface so i can control the DVD-player with the butons of the steeringwheel and on the HU. Everything that worked before the swap will work afterwords. Its just plug n' play.
    But... (theres always a but...)
    Youll need to connect a VAG-Com cable and recode the DIS so it knows that you have a nav now. And you will have to get the RNS-e coded so it knows what options you have on the car, suchas BT-kit, Ipod, sirius, dvd exc...
    The radio reception will not be as good after the retrofit due to an missing antenna. But you can solve this with a VW golf divercity antenna module.
    I made the swap and i will do it tomorrow again if i get a new car.
    And oh! Bose or no-bose makes no diffrance!
    if you want more info visit http://www.navplus.us
    Cheers and good luck!
    wow, great info. thanks!
    -Jay
    2006 Brilliant Red 2.0T Quattro
    http://quattrokings.com/
  3. #43
    Active Member Two Rings vedran's Avatar
    Jun 25 2008
    Norway
    What Garmin can replace this OEM look. It's ugly to see some small screens glued on windshields and wire hanging below. You will not see that on expensive cars.
  4. #44
    Senior Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Quote Originally Posted by Audi Juice View Post
    Bose pin placement relocates from B5 to B7 slot.
    Dont worry, its not that hard. JK
    ROFL
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
  5. #45
    Senior Member Four Rings 'mk4-turbo's Avatar
    Oct 02 2007
    B7 Audi A4 S Line Titanium Pac
    Montreal
    "Youll need to connect a VAG-Com cable and recode the DIS so it knows that you have a nav now. And you will have to get the RNS-e coded so it knows what options you have on the car, suchas BT-kit, Ipod, sirius, dvd exc...
    will the dealer be able to do this?
    2008 Ibis White A4 Sline / Titaniuam Package 6MT : H&R Springs | Ziza Licence Plate LEDS | De-Badge
  6. #46
    Oct 02 2007
    Montreal
    HUH???? What do you think that cool little shark fin antenna on our roof is for? Yes, you guessed it, its a gps antenna. Why in the hell would you pull the cluster out and put the antenna there?
    Anyway, the link below is for those who understand pictures better than written words.
    http://forums.audiworld.com/s4b6/msgs/255474.phtml
    when you ordered your navi did it come with all these parts? or did you have to buy more part?
  7. #47
    Jul 14 2008
    Skellefteċ - Sweden
    Also, the problem with an antenna mounted behind the cluster is that it will not have the same reception as the roof antenna. It has been tested and proven on some other threads. Both methods will work, I'm just a fan of getting as close to oem as possible.
    I dont have a sharkfin and im not a fan of drilling in my car. And i get 6-8 satelites all the time. And you need atleast 3 to get a altitude possition. I dont think you can get more than 8. So if you have 6-8 or 7-8 all the time doesnt matter at all.
    As far as the golf diversity antenna mod. I think that is mainly a European thing. I havent had much trouble with am/fm reception, but I know many people overseas have.
    This might be true. Im not able of testing this thoo.. But i know its just the FM reseption. So if youre using AM or sirius it should be fine!
  8. #48
    Jul 14 2008
    Skellefteċ - Sweden
    Quote Originally Posted by 'mk4-turbo View Post
    If you ask politely. But they might say no. I got a cabel with my unit. My dealer had no qlue what to do. but its realy realy simple.
  9. #49
    Jul 14 2008
    Skellefteċ - Sweden
    Thats not a A4 B7? Thats like a Golf MK4 or Audi A3 maby? :P Acctully... Aint it a Beatle?
  10. #50
    Oct 02 2007
    Montreal
    ttt
  11. #51
    Jul 14 2008
    Skellefteċ - Sweden
    ttt
    que?
  12. #52
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    I don't know why the bumped it either...
    Anyways, OP I wouldn't go with anything but OEM now that I have it. Before I got my car I was going to go with a Kenwood DNX-8120, but I would never now. You can't get the same integration with the Kenwood but you can get all the features it has in different ways.
    i.e. I'm going to use an aftermarket sound processor (most likely an RF 3sixty.2 or the new ArcAudio one) to get the tuning capabilities I will need/want.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
  13. #53
    Senior Member Four Rings Sharkfin's Avatar
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    If anyone wants a RNS-E unit with euro specs I have one for sale for $600 plus shipping and paypal fees. No cables included. It can be reflashed to US specs/Canada specs.
    Past: DTM 2005.5 B7 A4 2.0TQT
    Current: 2008 Infiniti G37s Coupe
    Future (2012-13): A5, S5, S4
  14. #54
    Oct 02 2007
    Montreal
    why are you selling it
    does anyone know how to reflash the unit to us specs?
    is it complicated?
  15. #55
    Senior Member Four Rings AudiWxGuy's Avatar
    Nov 12 2007
    Quartz Gray 2007 A42.0TQ 6MT
    Grand Junction, CO
    See this is the mistake most people make. Nothing needs to be removed except one roof panel that pops off. The gps extension cable is so thin it tucks under the door sills without needing to remove them. I did it at night and it took 40 minutes. Im sure it would have been much easier with light.
    I have never once had a problem receiving a GPS signal and mine in mounted behind the RNS-E. I always receive between 5-7 sats.
    As far as the antenna in the shark fin goes, I was informed there wasn't one in there. Oops. Thanks for the info.
    2007 A4 2.0T 6MT Quattro ** Quartz Gray
    Mods:
    RNS-E/STaSIS Exhaust/GIAC-X/STaSIS Street Sport Coil Overs/15mm Rear/Umnitza LED Angel Eyes/Ziza LED Citylights/CC Mod/Hoen Fogs/Ashtray iPhone Dock/
    RS4 Rear Sway/Blackout Grill with Black Filler/Clear Bra/18" OZ Superturismo & 225/40/ZR18 FK452's....(0-60 in 5.85s)
  16. #56
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    is it complicated?
    I'm working on that now, it would be a little extra but I'm waiting for an email back from a local guy who does it professionally. That's where audiwxguy got his from. I am selling because in case you didn't see my thread, I ripped off my bumper and have to get a whole new setup which is 1000 bucks I wasn't planning on spending. PM me if your interested!
  17. #57
    Oct 02 2007
    Montreal
    well im currently bidding on 1..if it doesn't go through i'll let you know
    unfortunaltey i'm in the same boat as you...if you've seen my other thread, someone decided to re model my car with $4000 of damage to the front!
  18. #58
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    oh ok, well are you interested? I'm offering one hell of a price.
  19. #59
    Oct 02 2007
    Montreal
    i know its a good price....i can't say yes cause i'm winning the bid right now...dont want to be stuck with 2 units
  20. #60
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    oh ok nvm then
  21. #61
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    you can retract your bid lol
  22. #62
    Veteran Member Four Rings TurbousMaximus's Avatar
    Aug 25 2004
    Whitehall, PA
    thats a hell of a price. put it in the fs section, it'll go quick!
    2011 S5 Sprint Blue w/ Silver Alcantara, B&O, Carbon Atlas, Nav, and Rear Differential (ETA: Aug 16th)
    2006 A4 S-Line Brilliant Red 6spd - Sold
    2000 1.8tqms Ko4'd Brilliant Black - Sold
  23. #63
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    just did for $700 shipped including paypal fees, here is the link: http://www.audizine.com/classifieds/...p?product=4493
    it is also very well packaged with full styrofoam covers
  24. #64
    Oct 02 2007
    Montreal
    pm'ed you
  25. #65
    Veteran Member Three Rings Audi Juice's Avatar
    Feb 11 2005
    08 Titanium
    Huntington Beach
    Anyone who wants the conversion files, I can email them to you. Burn the 5 files to cd and rns-e automatically updates to US spec.
  26. #66
    Nov 01 2007
    B7 A4 2.0TQT
    NC
    hell yeah, nsmith024@gmail.com right now lol
