Ok I realized some of my pic's I guess that gives me more room for Zine storage.
So these pic's will help out but if not let me know I can get some more. I just thought this might be better then some of the pic's I have.
There are 3 spots for Air to get in the Box
1 from the front of the car threw the main air scoop (on the front of the car and then connects to the top of the air box.
2 on the Back side of the air box there is a adapter that dead ends at the front of the passenger door (this is labeled in green)
3 the flap controled by vacuum in the bottom of the Air box. (this is in red)
As you can see I have two colors.
Red. This is going around the flap in the bottom of your air box this is what you want to remove. There is a flap and if you look in the second pic. you will see I have removed the Valve from mine. If you remove your Air box you will see there is a Valve that's there. This valve is restrictive below 5k It is restrictive due to the fact that it is shut.
You want to remove this. To remove the valve you need to remove the air box. That is kinda straightforward im sure there are several wright ups on this but I can post how to do that if needed.
OK so you have your Air box removed. Take off the top and take out the Air filter. Throw away the pre filter if you still have it as this is just one more thing that can clog. After the removal of the filter you will expose the bottom of the air box and doing so you will see the Valve in the bottom of the box.
The goal is to remove the Valve and not damage the mouth to the Bumper ram air intake. Removing the Valve is easy. Take off the Vac line and cap it off with a screw in the line or with a proper vac tap. There is a lot of extra Vac line that you can trim back if you wish. The vac line runs from the Valve to the front of the intake manifold. So trim it back as far as you feel comfortable.
Now that the Vac line is dealt with lets remove the Valve. To do this Look at my sec pic here you see there are 2 ph screws on the side. These are holding the Valve and the mouth to the ram air connection together in the Air box. Remove these 2 screws. Don't loose them as you will need them. Now that the 2 screws are out the mouth and the valve can be removed. With the mouth and valve being one unit you will remove them and separate them. After you have the Valve separated reinstall the Mouth in the air box
Now you can either just reinstall all the parts or you can go to step 2 and remove the tube (circled in Green) from the inner fender wall. To do this remove the passenger side tire. Then remove the inner fender liner. There are like 15 torx screws for this (not sure the exact #) but they are all easy to get to. After you remove the inner fender liner. Pull out the tube and throw it at something because at this point you have 10,000 scratches on your hands. After that just button it all back up and you are good to go.
Disclaimer /////////////////////////////////////////////////////////////////////
I never said this is going to be the biggest Hp gain but for free it is definitely one of the best for the money. As I said the car will get more air from this I and a few other people have Verified this threw the MAF value increase.
For free there is no reason why not to do it.
Feel free to let me know if you have any other questions or if I didn't do a good enough job with the pic's and explanation
