Page 2 of 20 FirstFirst 123412 ... LastLast
Results 41 to 80 of 765
  1. #41
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Re: Let It Begin...........2.0 Build.
    Quote Originally Posted by A4natomical View Post
    i probably will just end up keeping the 28r when it gets replaced with the 3071 just to have, plus its worth maybe a dollar.
    I'll give you 2 dollars. Final Offer.
    LoL, on a more serious note, This looks good! One of these days ill try and 2.0 my car.
  2. #42
    New Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    looks like a fun build good luck
  3. #43
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Looking good! From an OCD clean freak, I gotta say your block and hoses looks pretty clean!
    If you run across anything that is weird in what you've done so far, or what you do down the line, post it up. In weird, I mean anything that is out of the norm of what you'd think in doing this.
    Mine is coming out once the winter hits. Same thing being done.
    My 2004.5 APR Stage 3+ is SOLD
  4. #44
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    The actual clutch doesn't look too bad to me, all of the fingers are in tact, nothing bent or gone... I don't know that much though, so I could be way off.
  5. #45
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    Quote Originally Posted by Kamin View Post
    its almost down to those stud things on the plate. another few millimeters and it'll be scraping them.
    USP CLUB MEMBER #71 BetaAlphaTau Member #16
    tumblr
  6. #46
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    Quote Originally Posted by rxrep View Post
    clean, but not as clean as me and you like though ;)
    before the engine goes back in, the bay and motor are going to have a THOROUGH cleaning.
    will do. from what I can say now. we havent had any real hang-ups.(knock on wood).
    One out of the norm thing is when you have everything from the engine removed that is connected to the engine bay and you are ready to pull and all you have left holding the engine in place are the bolts from the block to the trans. you'll have the bottom 3 or so bolts that are "somewhat" difficult bolts to get to, because the frame is directly in from of them. so what you want to do is: remove the bolts from the 2 engine mounts, jack up the engine and trans with two jacks until the bolts from the block to the trans are just above the frame and you'll have a clear shot to get those. and also a swivel and a bunch of extensions will be imperative. you'll need two jacks also. one supporting the trans and one to lift the engine to get the bolts.
    Another thing that stumbled us for about 10 minutes was the power steering cooler. When you are about to pull the radiator/front end away. Instead of feeding the OEM power steering cooler through the hole that it runs through on the front end (it wont fit). Just cut the rubber hoses behind the radiator where they connect to the metal cooler. And you'll need some new power steering fluid, unless you recycle it back in.
    As I said, there hasn't been any hangups...............yet. (knocks on wood again)
    tumblr
  7. #47
    Jul 29 2008
    2003 A4 1.8TQM5
    PA
    Ah, ok. Thanks. Still learning here.
  8. #48
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    LEE. to give you a better idea of what i was referring to. here is a pic showing where the threads are situated. (right in front of the frame).
    this is also a good idea. name EVERY cable that gets unplugged.
    organize your hardware.
    so you dont get energized. (you might need it tho)
    tumblr
  9. #49
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    very nice job
    Aren't you supposed to undo the negative terminalll tho? LOL
    -Sami-
  10. #50
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    very nice job
    not sure. the main man did it.
    tumblr
  11. #51
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    i always disconnect the negative ground vs the positive
  12. #52
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    your still killing the current through the battery, why does it matter?
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
  13. #53
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    It doesn't.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
  14. #54
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    i asked the engineer about it and he said if the negative ground is the one you choose to pull, if by ANY chance the negative touches the body of the car, it will give the battery charge.
    so i played devils advocate and asked, well what if you wrap it up.
    him= then you wouldnt have to worry.
    tumblr
  15. #55
    Senior Member Four Rings 317ssayzarc's Avatar
    Oct 27 2007
    98.5 A4 2.0T 2001 Golf 1.8T
    Westerly RI
    Undo the ground...
    #1 you risk touching something grounded with your metal tool when you are taking the positive off
    #2 if anything grounds that cable while its laying there, you WILL see unexpected welding...
    -Jake and my shop is DoWerk Garage
    01' Golf 1.8T - The daily, GT2871R .64 externally gated, Tapp 630cc mafless tune, SB stage 3, Brute rods, ported AEB, 1mm over valves, CAT gold springs, Vmaxx, and countless other tidbits
    Send
    me a pm if you need work done in New England... Fabrication, engine builds, timing belts, brakes, ect
  16. #56
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    bagging parts (check)
    labeling wires (check)
    did that. highly recommend it. i learned that in high school when i restored my Chevelle.
    removing engine without trans (nah) I found it easier to crawl under the car and disconnect the rear trans mount and rear driveshaft and shifter linkage. then pull the whole engine and trans out as one. just my personal preference.
    Lee. His engine is pristine because he's in southern california.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
  17. #57
    Mar 21 2006
    Lakeland, FL.
    I pulled the head and then the block, I didn't have the luxury of a hoist...other than my back. I did the assembly the same way. Shit, I didn't even have a jack and stands back then.
    I'm back bitches!
  18. #58
    Oct 27 2007
    Westerly RI
    Quote Originally Posted by dirtybrd View Post
    Thats beastly
    Send
  19. #59
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    wow. when we work, we say "imagine trying to do that with the engine still in" Noooo way. hats off to you, thats amazing.
    tumblr
  20. #60
    Oct 29 2005
    Ft. Lauderdale, FL
    Chris, your a monster lol
    - Clint
  21. #61
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    update for tonight. we did a little more work.
    under the valve cover was VERY clean. im very happy about that.
    the engine is dinky once its naked.
    pile of laundry
    tumblr
  22. #62
    Registered Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    nice progressive work
    good luck
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth
    E46 M3 TiAg/IR Moton/GC Track Ready
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed
    E39 540iA Aggressor
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package
    Porsche 944 NA
  23. #63
    Stage 2 Banner Advertiser Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Just caught up on your build thread here and it looks like it is going well.
    In regards to the software I'm with Doug on this one too... without a custom tune you will have to log and tweak your setup to get your car to be in a 'safe' zone when pushing the boost.
    You won't make max power but you won't be taking your engine apart a couple of times to replace broken parts like I had to.
    I'd also suggest getting the face of the JE Pistons coated with the heat reflective coating since you haven't installed them yet. You can use all the tech you can get with these builds.
    iPhone 4/4S Vapor aluminum case sale! $40 shipped! -> click here for details
  24. #64
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    Quote Originally Posted by winston@podi.ca View Post
    yea. ive decided im not gonna touch anything thing with boost and the ecu until i get the 3071 in. i was planning on running the 28r a little harder after the engine was broken in, but now i dont want to hassle with tweaking boost and fuel then when the 3071 comes having to do MORE tweaking.
    tumblr
  25. #65
    Jun 11 2005
    Vancouver, BC
    IMO the thing that bothers me about the tweaks is that they are just a quick fix and it is uncertain how long it lasts until the ME7 adapts the tweak out. It is that smart of an ECU.
    The REVO software was made for a GT28xx turbo and when you up the turbo size, injectors and other characteristics you can make changes so that the software works but I hated the fact that I was always wondering if I was in a safe zone when I wanted to hammer the throttle.
    My BAT build, while using relatively standard parts, is out of the norm of the software parameters. So adjusting software when the hardware is so far out of its playing field just made no sense to me.
  26. #66
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    you have a point. so far no one who is running a turbo larger than gt28xx has kaboomed (except clint) if they do everything right. just because i'll have a 3071 and a built motor doesnt mean im gonna push it really hard. With conservative boost on a 3071 will still yield very good numbers (if not better) without straining the ecu, than a gtrs/gt2871 would running aggressively.
    tumblr
  27. #67
    Jun 11 2005
    Vancouver, BC
    I hear ya... I just lacked the willpower to 'just keep the boost at 18psi' when I got used to the power
    According to my dyno runs that would be ~ 265awhp/230ftlb tq
  28. #68
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    haha. yea, maybe not that conservative. maybe 24? we'll see once its running and logged.
    tumblr
  29. #69
    Jun 11 2005
    Vancouver, BC
    I forgot you are building the engine.
    18psi was where we had it set with a stock engine.
    It just occurred to me that was still less than one year ago.
  30. #70
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    are you talking about your engine being set at 18psi on a stock motor?
    what turbo? gt3076?
    tumblr
  31. #71
    Jun 11 2005
    Vancouver, BC
    With the original 3076 build the boost was set to 18psi on the stock motor so I wouldn't throw a rod.
    The car ran great and the power delivery super smooth but the car wasn't 'fast'
    So I chose to build the bottom end to a 1.9L setup to handle the power and the rest is history
  32. #72
    Oct 27 2007
    Westerly RI
    Breaker bar on the oil filter housing bolt?!?!?!? Thats only M8 thread man!
    Send
  33. #73
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    Quote Originally Posted by 317ssayzarc View Post
    haha i knowww. maybe we were getting weak late into the night.
    you didnt NEED a breaker bar, a socket wrench would have been fine.
    but the 10M wrench was too hard.
    tumblr
  34. #74
    Oct 27 2007
    Westerly RI
    Oh I gotcha... I thought you needed it lol...
    Ive taken apart enough of these motors to where I now take them apart with an impact and throw everything into a bin... Lol, so I cant really hate on your breaker bar ... But please tell me you didnt have a 3' bar with a 1/2" to 3/8" drive adapter haha
    Send
  35. #75
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    nah. its only a 3/8 drive breaker.
    tumblr
  36. #76
    Dec 03 2005
    connecticut
    I sent you a PM
    -Doug
  37. #77
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    2003 2.0 PTE 5857 B6 A4 quattro 5spd, 05 E55 AMG
    Jacksonville, Florida
    I undid that bolt with the oil fitler still on with a little wrench. I must be strong
    Think I am gonna take that assembly off again with the engin in the car now since I have a leak over there and I reused the metal gasket which got a little bent when the engine was apart. I hope that is my problem.
    ~David~
    I can help you with your 1.8t work (timing belts, etc)
    2.0 Billet PTE 5857 A4
    Those who say it can't be done should get out of the way of those who are doing it.
    119mph traps w/ 437whp/392wtq dyno jet power on 93 octane and washer fluid injection
    527whp/576wtq White Pano E55 AMG 11.69@120mph on street tires
  38. #78
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    does anyone know what the size torx the head bolts are? its somewhere between T50 and T55.
    tumblr
  39. #79
    May 24 2007
    A4 USP 2.0L GTRS
    Southern California
    I sent you a PM
    replied.
    tumblr
  40. #80
    Dec 03 2005
    connecticut
    6point poly drive
    http://germanautoparts.com/tools/Aud...20valvetrain#3
    -Doug
