Results 1 to 13 of 13
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Items for Sale
    Question What does the Leak Detection Pump (LDP) V144 do?
    I just found a boost leak on my car. It was coming from the T under the intake manifold that attaches to the EVAP Canister Purge Regulator valve (N80), the Leak Detection Pump (V144), and a port below the intake manifold.
    I tried to just put new clamps on the plastic T but that didn't work out so well. It just continued to leak. Because of this I opted for the easier solution and I pulled the T out and plugged the line running to the intake manifold port and left the other two open (Evap and LDP). The car runs fine, builds boost a little bit quicker, and I am getting no CELs so I'm assuming I am in the clear but I wanted to make sure.
    I did a search but I'm not pulling up any information on the LDP or what it does.
    Recap:
    * What is the leak detection pump?
    * What is its purpose?
    For reference. The T I am referring to is located between 19 and 18:
    * Please note the above diagram is for an ATW engine I believe. In my Bentley manual, that intersection is marked as 16 and 15 from page C 21-2
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: What does the Leak Detection Pump (LDP) V144 do?
    I believe it detects leaks, im not exactly sure though ;)
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Apr 10 2007
    Eastern PA
    Items for Sale
    Quote Originally Posted by Rhinop21 View Post
    lol, I was thinking that but then I wasn't sure because it's name is so damn obvious that it couldn't be that simple.
    I know it detects leaks... what kind of leaks I have no clue. I'm assuming vacuum leaks although that's just my 2 cents and I have nothing to back that up.
    Apr 10 2007
    Eastern PA
    Items for Sale
    Ok, so the not having a code thing didn't last long. Got a EVAP low flow code today so I am going to reconnect it with some better clamps and a new Tee. Still not sure if the LDP is required though.
    Senior Member Three Rings fernando's Avatar
    Mar 06 2008
    01 A4 1.8T, 1998 Volvo S70 T5
    Maple, Onatrio
    a leak detection pump detects vaccum leaks in your EVAP system
    GT2871R *Kinetic Motorssports FMIC * VME 4300 HID lights * Turbosmart DV * Revo BT Tune * APR catback exhaust system * custom vent boost gauge * custom vent wideband gauge * zimmerman crossdrilled front rotors with Hawk HPS pads * SB Stage 4 clutch * Neuspeed shortshift kit
    Apr 10 2007
    Eastern PA
    Items for Sale
    Ahh, that makes sense. Guess it's required then :-(
    i wouldnt say required. your current ecu likes it there though. ;) hahaha.
    contact via email please.
    Apr 10 2007
    Eastern PA
    Items for Sale
    True true...
    k0mpresd, what's the word on the PES tune hack btw?
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    The LDP detects leaks in the evap system. however it does not detect vacuum leaks. fuel vapor builds in the tank and is sent to the charcoal canister for storage. under certain operating conditions, the canister is emptied via the n80 valve into the intake system so it can be burned rather than releasing raw fuel into the atmosphere. the leak detection pump is a checks the integrity of the system to ensure that the gas cap is tight, there are no cracked or broken hoses/lines (large/small evap leak faults), and that n80 isn't stuck open. i forget if it pressurizes the system or creates vacuum, but it does 1 of them, until a flap closes. then it counts how long until the flap re-opens due to re-equalized pressure. if it takes no time at all, large leak. takes longer = small or very small leak. does not re-open - no leaks. In terms of necessity, its not required for the engine to run properly, but it will set a mil, you most likely wont pass any emissions testing if applicable to your state (i love FL), and if you have an evap leak it will be detrimental to the environment.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Apr 10 2007
    Eastern PA
    Items for Sale
    Awesome. Thanks for the input guys. I'm going to re-install the tee splitter. I would prefer to keep that part of the car working.
    Senior Member Three Rings urban96's Avatar
    Aug 09 2007
    Syracuse, NY
    Items for Sale
    If im getting code: 17884 - EVAP Leak Detection Pump: Malfunction / Insufficient Vacuum
    What would that mean? I have a leak somewhere between N80 and LDP?
    -06 A4 2.0T
    -97 A4 1.8T
    Jun 30 2008
    Erie, Pennsylvania
    It would most likely mean that the LDP is no longer getting it's vacuum source. I believe that would be #19 in the above diagram.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Aug 16 2011
    89 BMW E30
    Fresno, CA
    your car finally ran the evap monitor that's why your cel light came on it has to run to monitor like 2 times I it sees the same problem turns on cel
    LDP is part of your evap system purpose to detect any leaks in your evap system..
