Results 1 to 14 of 14
    Active Member Three Rings
    Sep 08 2008
    2005 A4 1.8QTip
    Williamsburg, Brooklyn
    License plate / plate cover screw size?
    My new vanity plates came in the mail today, and I'm going to order the AZ plate covers, my only question is, what size screws do I need for both the front and back covers?
    The ones on my car now are some rusty ones from god know's where.
    -Andrew
    Veteran Member Four Rings 400HPA4's Avatar
    Jul 04 2004
    2002 Audi A4, 2002 GTI 337
    OC
    Re: License plate / plate cover screw size?
    M6 x 1.0 6mm long
    Sep 08 2008
    2005 A4 1.8QTip
    Sadly I am now more confused
    Active Member Two Rings stephengraham's Avatar
    Aug 27 2008
    Fredericksburg, Virginia
    You need a short metric screw. The size is called M6.
    You can also order them from ECS Tuning. Bottom of page, "license plate hardware."
    I bought black socket cap M6's at Lowes and Dremmeled them down to the length I needed.
    Sep 08 2008
    2005 A4 1.8QTip
    You guys are life savers!
    Would it be a safe bet to buy
    ECS - Slim / Flush License Plate Bolt - 6x8mm
    or
    ECS - Slim / Flush License Plate Bolt-6x12mm
    New Member One Ring
    Feb 21 2008
    Brooklyn, NY
    Im Also interested in getting these. Anyone have a link?
    New Member Two Rings OhioA41.8T's Avatar
    Feb 22 2009
    03 Audi A4 1.8T Quattro
    Columbus, Ohio
    Thank you! Going to the hardware store tomorrow!
    Senior Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    03 Audi A4
    Columbus, Ohio
    My new plate is on the car now! I just got some M6 1.0 10mm that worked great from Lowe's today. I still plan on ordering some nicer ones soon. I'm just glad to know the size of them now. Thanks.
    Senior Member Three Rings doogie891's Avatar
    Apr 30 2009
    2003 Audi A4 1.8T Quattro
    Miami, Florida
    i know i know thread revival time but just wondering what the answer to this question was...
    or
    ECS - Slim / Flush License Plate Bolt-6x12mm ???
    do i get the 8mm or 12mm?
    TIA
    Senior Member Three Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    I would think the 8mm would be enough, unless you have an extra thick plate cover....
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Reviving again.... This thread helped get me started, but FWIW, after two trips to the hardware store, I'll share my experience in case it helps anyone prevent that second trip.
    My car... new-to-me B7 - '08 A4 Avant 3.2.
    Rear license plate bolts: M6-1.0x12mm
    Front license plate bolts: M4-.7x12mm
    I used socket cap bolts. So you can have your wrenches ready, the M6 (rear) screws will take a 5mm wrench. The M4 (front) ones require a 3mm wrench.
    Small bummer for me. My hardware store carried black zinc plated bolts, but not matching washers. The frame & plate mounting holes were fine for the M6 screw heads, but were too big for the M4 ones. Worse, the 'matching' M4 washers were also too small. So, I've got some ugly 1/4" SS washers against my black plate frame up front. Sigh. In any case, 12mm-length screws were long for both, and I now have extra 16mm bolts that I'm too lazy to return. All said, even with the extra bolts and washers, total cost was just over $6.
    Pics...
    Rear:
    Front:
    -Jerry
    '08 A4 Avant 3.2/Tip, Convenience, Technology, Cold Weather. Sonic Tuning ST5 18's.
    (Formerly) '06 A4 Avant, 3.2/Tiptronic, Convenience, Premium, Technology/BT, RNS-E. STaSIS Street Sport, RS4 rear anti-sway, 18" VM RS4 Reps, painted front insert, roof spoiler and S4 rear valance, dual tips, 3M exterior film & 35% tint.
    Senior Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    A4 USP Avant
    West Coast of Michigan
    If there is a choice of stainless, go that route. If you don't, be prepared to drill out your screws in a few years.
    FS: Lots of 18" tires and OEM Xenon - http://www.audizine.com/classifieds/...0&ppuser=24138
    Stage 3 Forum Advertiser Four Rings ECS Tuning-Audi's Avatar
    Oct 02 2006
    Wadsworth,OH
    You'll want to use the 12mm bolts. They are available below.
    Click HERE to order or for more information.
    Let me know if you have any other questions.
    Jason
    Jan 03 2007
    SF Bay Area, CA
    ^ Those are sweet! I know I'm intruding here since I'm a B7 owner, but I sure wish you had those in an M4-.7x12mm size for the front of my car.
    -Jerry
