The build (built winter '07-'08):
-2.0L bored and stroked ATW block
-stroker clearance w/ shimmed 3rd oil squirter
-ABA crank (with ABA trigger wheel NOT ATW trigger wheel)
-144mm Carrillo rods
-83mm JE pistons 8.5:1 C/R from 034 w/ altered deck height for new crank-034 coated rod & main bearings
-OEM oil pump
-Full-Race manifold & Down pipe
-44mm Tial Wastegate
-Garrett GT3076 .63 a/r turbo w/ polished compressor housing
-euro-spec 268/260 cams
-QTP 3" electronic dump valve on DP for tracking
-southbend stage 5 clutch w/ spring hub and AASCO 9lbs LWFW (single mass)
-Milltek 2.75" resonated exhaust w/ modded midpipe to connect 3" DP
-SPP electric fan kit
-MRC Tuning
-034 Street Density motor mounts
-Evolution Racewerks Competition FMIC
-Walbro 255LPH Fuel Pump
-630cc Siemens Injectors
-PLX Devices Wideband Air/Fuel sensor and controller
-VEI digital boost and A/F gauge
things I skimped on:
-knife edge my crank
-high rate valve springs
-fuel pump that fit the basket (so what?)
-the head (stock ports, not port 'n polish for me)
-Suspension and brakes...but thats not really related
notes:
-stock headgasket works on 83mm bore
-leave ABA trigger wheel on crank
-Intermediate Shaft will need stroker clearance as well as the crank case and 3rd oil squirter
-tap into compressor housing to use stock N-75 valve (no EBC w/ MRC tune)
-MAFless tune (will go with 3.5" RS4 MAF next summer)
-I had my engine work done by R&L Engines in Dover, NH. I did all the work myself except for the block work, and assembling the internals.
-when installing cams, be sure to not lose the tension on the tensioner or you'll be in for a new one...and they run abuot $350 ea. from the stealership
-use locktite on the crank bolt or you'll regret it!
My Bible (thanks Jake)
Misc. parts:
Turbo, WG, & Manifold:
In the midst of the build:
After I got the engine back:
ABA Crank & Carrillo Rods:
Euro-Spec cams w/ stock springs (High-rate springs added later):
Southbend clutch:
no numbers yet, but Minhea is expecting 400AWHP on pump, and next summer I'm going to go for a meth & C16 dyno tune, those numbers should put close to 500 wheel (but dont jump on the estimations, thats just what they are)
I went for a night at the track and I couldnt hook up off the line, but my best trap was 119.xx MPH, so with some good wheels I should have a good run.
Please post questions or anything I missed
...thanks for looking
edit:
here is my order from ATP so you guys can custom order your oil lines instead of getting ripped.
GRT-GSK-005 T3 Inlet Gasket (1) $8.00
ATP-GSK-012 4 Bolt Turbine Discharge Gasket 2.5" (1) $8.00
ATP-OIL-021 -4 size Oil inlet fitting for GT28/30/35R with built-in restrictor (1) $12.00
ATP-OIL-028 1.8T Oil Feed adapter, Stock port to -4 Male AN (1) $12.00
ATP-FTG-016 Fitting, Swivel, #4AN Flare, Male to Female, 90D (1) $7.95
GRT-GSK-008 Oil Return Gasket - GT Series (2) $3.00
ATP-VVW-107 Lower Adapter Flange - 18T Oil Pan Drain (1) $26.00
ATP-OIL-004 90 Degree 1/2" NPT to -10 AN (1) $9.00
ATP-FTG-004 14mm Banjo Fitting Set for coolant lines - 3/8" Barb (2) $18.00
MIA-FST-032 10mm (1.5 pitch) Stud (4) $1.05
MIA-FST-033 10mm (1.5 pitch) Nut Locking Head (4) $1.05
ATP-OIL-015 Oil Feed Line -4 - SS Braid 4 Ft. (1) $39.00
ATP-FLA-019 Oil Return Flange with integrated -10 Flare (1) $29.00
DRAIN Custom Oil Return Line (1) $12.00
END1: STRAIGHT $8.00
END2: STRAIGHT $8.00
LENGTH: 22 $16.50
Shipping: UPS Ground: $20.36
Sales Tax: $0.00
LENGTH: 22 $16.50
Sales Tax: $0.00
