Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 601 to 640 of 679
  1. #601
    Active Member Two Rings OrangeDUB's Avatar
    Nov 01 2010
    German Cars & Jap Bikes
    City of 5 Smells, IA
    Quote Originally Posted by BARRY View Post
    as old guy stated...venting straight to the atmosphere is bad for our motors. when venting directly to the atmosphere, think of it this way...your engine once shut off is expelling hot air and fumes. once your engine cools down the air will compress slightly and suck outside air through your vent tube back into the engine. since outside air has more moisture than any air that has been in recirculation, you will essentially be adding water in small doses to your oil. water in small doses to your oil will cause sludge and froth. most people think oh my catch can caught all this nasty stuff. in actuality the catch can the first stop to and from the engine and outside air. all that nasty stuff you see in your catch can is water from the outside air being mixed with your engine oil.
    i ended up not removing much from my car when i worked on it recently. i had spent maybe 500 dollars in hoses and a catch can with plans to rebuild my entire system. i was planning to have "catched oil" reintroduce itself into the crankcase as an entirely closed system. to be upfront about things, there really is not a good place to drain back the oil aside from adding a secondary crankcase breather. eventually when i go big turbo i will be using the oil drain back tee'ed for my catch can drain back.
    another thing most of you don't realize is, adding negative pressure to your crank case is a good thing. negative pressure means less work your pistons and crankshaft have to output to spin. negative pressure promotes positive ring sealing. with a OEM type configuration you are getting close to a neutral environment. with venting to the atmosphere, you honestly need to vent quite more than one port to the atmosphere. at that point eventually you'll get to a situation where more oil is being lost than it is worth doing. my old race car would sign around 9,500rpm so much at the end of a track day, i would be 1 quart short of oil. eventually you learn, recirculating/filtering/whatever is definitely a good thing for your engine in the long run. for your pocket book as well.
    That's some awesome knowledge my friend. After reading this I am going to go from atmospheric to catch can -> vacuum. My pancake was bad- should I worry about replacing that, considering I'll be using a catch can or no?
  2. #602
    May 24 2010
    Sofia
    I saw this on the net -
    Should it work for blocking?
  3. #603
    Senior Member Four Rings
    Apr 03 2010
    houston, tx
    Quote Originally Posted by caspar View Post
    looks like my IE block off; pretty cool to see an Audi genuine part, does the other side have a spot for an O-ring? If so then just make sure it's flat/true, use a machinist straight edge.
    -Rich
    Don't take advice from me;Seriously, I'm a moron.
    2.0L 3071R w/5-6k budget(in Progress)
    DIY links: $40 Front O2 ** Qtr panel replacement(in Progress) ** Vac delete for stockish cars ** The Big 3(coming) ** Black headliner/pillars DIY(coming)
  4. #604
    Jul 18 2011
    Norway
    Today I went full retard and decided to take action. The car only got worse the last couple of weeks and was a nighmare to drive.
    the symphtoms was:
    -horrible cold start, missfired like a mofo
    -missfires when fully warmed
    -loud horror sound from the engine at idle/vacuum, like a cat slowly dying in the engine bay, screaming.
    -high fuel consumption
    -loss of oil, although no oil leak
    -temp guage working when it felt like
    -insane vacuum from oil dipstick tube/oil filler cap
    I had no codes stored in the ecu, so I narrowed it down to a bad pcv system and vac leaks. So after reading this thread
    next, I ordered some resistors and a block of plate from IE, along with billet block and valve cover adapter+ AN fittings to route it to the ground for now.
    So today was D-day and I took it all out, n112,n249,combi valve,PVC system,the vacum thing under the engine,SAI and ALL the old vacuum hoses.
    I hooked one new line to the bov and one to the brake booster+ new fresh lines to the n75 valve. I took the IM off and replaced the leaking Injector cups,
    changed the coolant sensor (super easy with the combi valve out of the way, did it in like 30 sec), put in a new O2 sensor, new IM gasket
    and cleaned the maf sensor, TB and IT sensor with brake cleaner. it all took me about 6 hr from start to end.
    at the end of the day, this was the result
    tried to fire her up, but it wouldnt start, and I was like "dear god, what have have i done" lol, but after about 10 sec, she fired up just fine.
    the result:
    -no vacuum storm in oil filler cap/dipstick tube
    -no missfire at cold start
    -no missfire when warmed up
    -no cat screaming sound from the engine
    -no cell
    -no codes
    -runs super smooth at idle
    -quicker boost response
    -temp gauge working for the first time in 1 year
    I scanned my ecu with the new Motoza software I got in the mail yesterday, and no codes.
    And last, the usual whoring:
    and dont mind my bad english writing skills;)
  5. #605
    Aug 26 2005
    The crankcase vent dump to ground will make a mess. I recommend installing a MANN ProVent crankcase ventilation catch can/oil mist coalescer to limit oil lost from the crankcase, and stop the emission of regulated hydrocarbons and CO from the crankcase. The ProVent returns trapped oil to the crankcase, and routes the crankcase blow by gasses to the intake between the MAF meter and the turbo compressor intake. Since the vented gasses are cleaned of all oil aerosols/mist, the intake will stay clean, unlike the stock setup that does not trap the oil and water in the crankcase gasses. Using the ProVent, eliminates most of the negative effects of removing all of the crankcase ventilation equipment that you described.
    Vorsprung durch Technik
  6. #606
    Jul 18 2011
    Norway
    Quote Originally Posted by diagnosticator View Post
    thanks for the info, the dump to ground was moore of a temp solution for today. The Man Provent is deff a nice buildt pcv breather :)
  7. #607
    Jul 28 2012
    Holland, MI
    Today, thanks to a broken breather tube, I'll be removing the PCV valve under the IM and replacing it with just the elbow to the crank and heater hose to the 3 way at the VC. Can I vent the crank and VC back to the TIP, similar to the stock setup? I'll keep the PRV on and dump the hardline back to the TIP. Or must I install a catchcan between the PRV and TIP? Or would I be better off venting to atmosphere under the car?
  8. #608
    Senior Member Three Rings 03AudiA41.8T's Avatar
    Nov 08 2008
    zx7r
    Pittsburgh,PA
    can we get a parts list of what all we need to complete this from start to finish. would love to get rid of everything possible and prob. fix many vacuum leaks in the process
  9. #609
    Veteran Member Four Rings nofearhawk's Avatar
    Aug 31 2007
    04 1.8TQ
    Chicago, IL 60601
    Parts list? Some rubber caps, clamps, zip ties and a 5mm hex tool? EGR/SAI blockoff plate.
    And some resistors if you don't have the ability to code it out.
    1.9L GT3071r 517 trans
    Mods: Eurodyne Maestro 7 / Stasis Alcon 355mm Mono6 / 034 Billet Fuel Pump 005 / Neuspeed snub mount / RS4 rear sway / Custom Magnaflow 14581 exhaust / INA adapters with FSI coilpacks / Thor Skidplate / CF S4 blades / DTH CF Roof Spoiler / RD led lp / Smoked sidemarkers / 3k HID fogs / 35% tint / Symphony II+
  10. #610
    Dec 19 2007
    2003 A4 1.8TQM, 2002 Beetle GLS 2.0M
    York, PA
    some info on that part listed above:
    http://www.passatworld.com/forums/76...5-front-3.html
    -Nate
    Please PM for items for sale:| Hofele Design 1 Piece Rear Trunk Spoiler/Lip | B6 A4 Brake Calipers | 4 OEMCoilPacks Rev. D | Arm Rest Cupholders - FREE | Washer Fluid Reservoir |
  11. #611
    Jul 18 2011
    Norway
    Quote Originally Posted by 03AudiA41.8T View Post
    Here you go bro:)
    http://forums.vwvortex.com/showthrea...-for-your-1.8T
  12. #612
    Nov 08 2008
    zx7r
    Pittsburgh,PA
    thanks everyone
  13. #613
    Active Member Four Rings CrazyCal's Avatar
    Sep 10 2011
    Oregon
    Have a couple quick questions....
    I plan on using the catch can method from the crankcase breather to the TIP. I know I need a check valve in between to prevent pressure travelling back through the breather and into the crankcase. I currently have the 034 Breather Kit. I'm planning on plugging the PCV outlet on the 034 crank breather hose. That means the billet PCV won't be used.
    My two questions:
    Am I wrong in assuming I could just use the Billet PCV (instead of a standard check valve) on the Catch Can side of Valve Cover "T" Hose as pictured below?
    Any issue with the placement along the line (before or after the catch can) or does it even make a difference?
    ~Calvin
    034Motorsport
    RogueEuro
    2004 Audi A4 1.8T /// 6-Speed /// quattro /// Moro Blue Pearl
    || uni stage 2 || symph ii+ || podi || ns sport w/ b5 seats || v718 sunken treasure
  14. #614
    Dec 28 2006
    '09 CC VR6 Sport
    The PCV valve serves no purpose if it isn't hooked to a vacuum source. Its primary function is to provide block vacuum and prevent boost. The line you show it installed in provides minimal vacuum at best and no boost. No need for any type of check valve in that line.
    Still have all my hoses and check valves and proud of it!
  15. #615
    Sep 10 2011
    Oregon
    Re: DIY - B6 1.8t - Vacuum line and Check Valve removal/simplification
    I was going by the information provided by greg@podi in post #357.
    Sent from the Wretched Hive of Scum and Villainy using tapatalk 2
    ~Calvin
    034Motorsport
    RogueEuro
  16. #616
    Dec 28 2006
    '09 CC VR6 Sport
    Quote Originally Posted by CrazyCal View Post
    And exactly where is this boost signal going to come from? Look at your diagram and think it through.
  17. #617
    Sep 10 2011
    Oregon
    You're right. There's no way for any sort of boost to travel through the TIP. If anything, it would be relieved by the gaping hole (ie the filter) anyway.
    There's a lot of misinformation in this thread.
    What would be the best vacuum source to use instead of just dumping it down by the tranny and using no vacuum source? It seems as if the block breather would benefit from a catch can and vacuum.
    ~Calvin
    034Motorsport
    RogueEuro
  18. #618
    Dec 28 2006
    '09 CC VR6 Sport
    Well if you read my sig it pretty much sums it up. The OEM set up works as long as it is properly maintained. Mine works fine after 9 years and 160k+ miles. Needless to say I have replaced a few components over the years. A boost/vacuum gauge and bi-annual pressure test will help you keep everything working properly. As long as your motor is healthy the amount of oil vapor blow-by recycling through the intake really isn't going to hurt anything. The 1.8T has manifold mounted injectors and consequently the intake wash-down keeps everything in the head clean. It's a different story for the direct inject motors and whenever I go to one of those I will definitely be looking at modifying the OEM system.
  19. #619
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    The FSI pcv system is a bit of a cluster that's for sure. Mine working just fine though with the newest revision stuff, but it's so failure prone its retarded.
    -CP
    2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
    2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
    SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
  20. #620
    Nov 01 2010
    Lol we need a new version of the 1.8t SAI/Evap/PCV thread written a little more clearly. No offense to the OP- it would be just nice to have a more cut and dry DIY that takes into account all the awesome info that has been brought forth in the discussion in this thread.
  21. #621
    Sep 10 2011
    Oregon
    Yeah, the thread does have a lot of constantly repeated information and when you get tired of reading the same thing over and over, you end up missing some single post in the middle of it that has pertinent information.
    ~Calvin
    034Motorsport
    RogueEuro
  22. #622
    Active Member Three Rings
    Jun 15 2011
    Aint nobody got time for that! * '08 A4 Q Stock, '58 Porsche 356
    BroCal
    If I did this down the road here in California, would they fail me at the emissions test? I assume they're in the engine bay snooping around?
    Solutions would be either reinstall the stock system or find a "down low" smog guy you can payoff with a hundo.
    Correct?
  23. #623
    Dec 19 2007
    York, PA
    yeah, i wouldnt do this if you lived in cali or dont understand whats going on.
    -Nate
  24. #624
    Senior Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    100$ always does the trick
  25. #625
    Sep 10 2011
    Oregon
    Slowly piecing together all the parts I need. Also waiting on my SAI Blockoff Plate. Can't wait to get this thing done.
    I'm going to create an updated DIY with a complete parts list when I do the install.
    Quote Originally Posted by B72011 View Post
    Correct?
    ^ This is exactly what sucks about this thread. This question has been hashed out at least 20 times already.
    ~Calvin
    034Motorsport
    RogueEuro
  26. #626
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by OrangeDUB View Post
    I did a decently detailed write up for the B5 1.8T (if I do say so myself):
    http://www.audizine.com/forum/showth...Simplification
    I approach the systems individually so people can pick and choose the deletes they want to do. This is pretty much directly applicable to the 2002 and early 2003 B6. The "mid" and "late" B6 1.8T vacuum/PCV systems do differ slightly, though.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, APR 93, Splitter, electronic oil pressure gauge, B6 Sport 17's, ST Coilovers,
    Need to borrow a Cam Chain Tensioner Tool? $4 for shipping. PM me. *Unavailabe*
  27. #627
    Dec 28 2006
    '09 CC VR6 Sport
    Damn Keith!! That's some nice work and outstanding documentation!!
  28. #628
    Jun 30 2008
    Erie, Pennsylvania
    4 (Four!) exclamation points from old guy? Well, it looks like life is all downhill from here.
  29. #629
    Feb 17 2004
    Round Rock, TX
    looks good, but I'm concerned that there's no longer a check valve between the manifold and brake booster. The booster isn't designed to see 15+ psi of boost, you should probably consider using a check valve instead of the brass coupler
    2002 A4 1.8TQ 5M. 197k+ miles
    FWD->AWD swap, FT F4H-L + Motoza, Valeo HD clutch, 034 HFC, Mototec exhaust, ER sport FMIC, custom bixenon e-codes, USP front lip, Zender trunk lip, Votex/DTM sideskirts, Stoptech 355mm front/B7 S4 rear brakes, Eibach ProStreet S coils, Neuspeed RSB, Sportec Mono 10s, B6 S4 front/rear seats, Euro shift knob, JHM short shifter, B7 console, RS4 pedals, oCarbon blue CF trim, RNS-E, TT-S MFSW, color instrument cluster, Alpine PDX-5, ID sub in LosLabs box
  30. #630
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    2005 allroad & 2004 B6 A4
    Penna
    I know (on the B6 at least) there is one built into the Brake Booster.
    Walky and/or Old Guy...
    Looking at this pic here:
    Any reason why 1 check valve would not suffice at the green "T" ? so it would go Manifold > check valve > T fitting ?
    -John
    "get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
  31. #631
    Sep 10 2011
    Oregon
    Thank you for linking to this. Lots of good, visual, information there! Great job!
    ~Calvin
    034Motorsport
    RogueEuro
  32. #632
    Dec 28 2006
    '09 CC VR6 Sport
    Quote Originally Posted by EErie B6 View Post
    I would recommend maintaining both check valves. The two lines see different conditions and could cause problems by essentially tying them together. For example: The LDP uses a vacuum source to operate the pump which in turn pressurizes the evap system. When the N80 bleeds down the pressure the line would be tied directly to the LDP line rather than separated by a check valve. I suspect that may cause you to pull some evap codes.
  33. #633
    May 30 2008
    Penna
    Thanks OG.
    -John
  34. #634
    Jun 30 2008
    Erie, Pennsylvania
    This is true, you definitely want a check valve in there. Here is the photo of the "real world" install I posted just below the diagram:
    You'll notice the factory check valve is still present at the firewall connection. It is part of that hose, basically. The vacuum diagram doesn't really show that check valve, hence the confusion. Reference the light blue colored line:
  35. #635
    New Member One Ring
    Oct 07 2012
    Atlanta, GA
    What a great write-up!
    2004 A4 Cab B6 1.8T FWD
    I am planning on giving this a whirl but not at his time - to many things going on.
    I do have a question I would like to ask about how the vacuum system works and get some possible direction.
    I had replaced valve cover gasket and made mistake of touching the breather tube - it disintegrated.
    At that point, I believe, I started getting low oil light intermittently. I could drive 3 or 4 miles and it would flash a few times and quit - mile or 2 later it would flash again and stop. So, the last thing I did was the breather tube replace.
    I read a blog that said if my engine was running and I couldn't remove my oil filler cap than there was a blockage.
    I would presume that it would be on the oil filter side but not sure what to look for or what would be logical target.
    Can yo help?
  36. #636
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    AE86 20v, UZZ30 LS2, 2002 A4 B6 1.8t
    Huntington Beach, Ca
    My two questions:
    my general comments to this without getting into the previously mentioned items...if you vent your catch can to your intake before your MAF you do not need a PCV valve. then again if you vent before your MAF lets hope your catch cant is not introducing ANY oil mist into the MAF which will cause it to fail. You do not want to introduce any unmetered air into your intake tract which is why we have a air suction valve.
    the OEM configuration is one amazingly perfect design if you think about it. it does exactly what it should do, but in practicality it is unreliable in the long run. The entire system should have been constructed probably as a contained box of some sort with minimal plastic/rubber used. external rubber hoses exempt from that analysis. and that junction box should have been serviceable.
    2002 Audi A4 1.8T: APR 1+ ECU, FMIC, Audi TT 225 Injectors, Hotchkis RS4 Sway Bars, KW Variant3, Porsche Cayenne BBK
    1986 Toyota Corolla GTS: AE101 20v, Toda 272, Haltech E8, Silkroad Highrise, TRD 2 way LSD, TRD Short Stroke Race, BattleVersion Lateral Rod, Cusco Strut Bar, 9500rpm
    1992 Lexus SC400: LS2 6.0, T56 Tremec, Kooks 1 7/8inch Header, BlackTrax Performance ECU, DGR Mounts, ACT TwinPlate, BattleVersion Arms, Daizen Front Lower Bushings, Tomei 2 way LSD, KW V3
  37. #637
    Active Member Two Rings TravisSavoie's Avatar
    Nov 06 2012
    Webster
    Help
    Quote Originally Posted by starfriend View Post
    wow, i've done this myself when i went bt, but man... this must be one of the best DIY on the forums! thanks for doing this!
    Can i pay someone near the Webster area to do this for me?
    If someone can do this and happens to live in the Houston, Tx area lmk asap VIA email
    TravisSavoie19@Yahoo.com
  38. #638
    Active Member Two Rings Jeff99gsx's Avatar
    Nov 03 2012
    2009 Audi A4 quattro 2.0t, 1996 Audi A4 quattro 2.8, 1997 Eagle Talon TSi AWD with a Holset HX35
    Cleveland
    I would like to keep all of my stock emmisions equipment on my 2002 a4, Is there any write ups on how to repair or replace the stock Crankcase vent system? I just bought the car and when i take the oil cap off there is pressure. What causes that? Bad suction pump? Clogged PCV?
    The car smells like oil when im at a redlight and its driving me nuts. Any help will be greatly appreciated
  39. #639
    Jun 27 2011
    Quote Originally Posted by Jeff99gsx View Post
    I would like to keep all of my stuff stock, Is there any write ups on how to repair or replace the stock Crankcase vent system? I just bought the car and when i take the oil cap off there is pressure. What causes that? Bad suction pump?
    Look up "a4darkness's engine strengthening thread". Should have everything you need. And more...
    -CP
  40. #640
    Nov 03 2012
    Cleveland
    Thank you...found it now!
