Page 14 of 17 FirstFirst ... 41213141516 ... LastLast
Results 521 to 560 of 679
  1. #521
    Aug 05 2008
    Boston
    OK.... Not trying to be a smart ass but from the questions you are asking I think you need to read up a little more on how the block breather and SAI system works before you start pulling everything off. If you are content to stare at a CEL all the time by all means proceed;-). Code P0507 on a 1.8T isn't necessarily indicative of a faulty PCV valve. It can be caused by a vacuum leak anywhere that leaks enough air to cause a high idle. It can even be a dirty throttle valve. Find your problem before potentially creating more problems.
    Thanks for the feedback. I read up a little about how the system works, in terms of ventilating fumes back to be burned back in the engine. I am by no means any expert in this, but I got the just of it...if you have some suggested reading please let me know...
    You already have an external waste gate and no you do not need an EBC to remove everything. Just use the N75 that is already there. And oil in the crankcase breather hose is normal.
    I am sure the oil inside the hose is ok, but what about if the breather hose and the T-section which holds the PCV valve, and the two hoses leading from that are soaked in oil on the outside...that's my concern, could it be oil leaking around the junction between the engine and the breather hose?
  2. #522
    Dec 28 2006
    '09 CC VR6 Sport
    Quote Originally Posted by dantm View Post
    Might help a little: Clicky click
    You probably need to replace a few components. Here is a wonderful resource: Clicky click
    Cheers!
    Still have all my hoses and check valves and proud of it!
  3. #523
    Aug 05 2008
    Boston
    Thanks ** I've gone through the readings and the more I read the more I shake my head ** how can a manufacturer do something like this and expect it to last long...
    The more I've read the more I want to remove everything except for the min required to run the engine properly with no CEL and with good power/gas mileage.
    I looked under the hood some more and realized that all the hoses that go from the crankcase breather opening up (to the PCV) and beyond to the back of the manifold, are all covered in oil/soot. Should they not be dry/drier? I'm thinking there's a leak in one of them which is causing these issues and codes that I'm pulling and which is also spilling oil on the rest of the system.
    Today I checked the codes and my original P0507 now includes the P0171 and all of the engine misfire codes:
    P0300
    P0301
    P0302
    P0303
    P0304
    So the problem isn't getting any better. The car drives ok, although I do not push it hard. I've noticed on the highway it's a lot more sluggish and gas mileage is generally more crappy.
  4. #524
    Aug 05 2008
    Boston
    Here's the diagram illustrating what I'm seeing...
  5. #525
    Dec 28 2006
    '09 CC VR6 Sport
    You have a leak somewhere. Thus the lean code, high idle code and multiple misfires. Run a pressure test and you should be able to find the problem. for what it's worth I have ~140K miles on my '03 and all systems function as they should. I have replaced a few check valves here and there but overall maintenance has been minimal.
  6. #526
    Dec 19 2007
    2003 A4 1.8TQM, 2002 Beetle GLS 2.0M
    York, PA
    you have a major vacuum leak somewhere with those misfire codes
    -Nate
    Please PM for items for sale:| Hofele Design 1 Piece Rear Trunk Spoiler/Lip | B6 A4 Brake Calipers | 4 OEMCoilPacks Rev. D | Arm Rest Cupholders - FREE | Washer Fluid Reservoir |
  7. #527
    Aug 05 2008
    Boston
    Quote Originally Posted by n7plus1 View Post
    Guys how do I test for it? I saw an A4 mods post where they showed using a compressor to pressurize the MAF with the engine off (is this correct?). Any other suggestions?
    Thanks!~
  8. #528
    Mar 21 2011
    Ohio
    I'm not sure the best place to post this... but i'm having some trouble too. I have fault codes P0300, P0301, and P0302. cylinders 1 and 2 misfires. I looked at the car today and i see that Part #9 in the quoted post's diagram is cracked. could anyone supply me with the part number, and/ or where to find it?
    Also, could that be the only reason for my 3 fault codes?, or should I also be looking elsewhere?
  9. #529
    Aug 05 2008
    Boston
    Quote Originally Posted by quiljw01 View Post
    You are definitely suffering from similar symptoms from what I'm seeing...what year is the car? There are different part numbers based on the years...
    By the way, in order to replace that hose, you have to take the whole assembly out from under the manifold; it's not that hard but it's better if you have smaller hands. When you do take that off you run a chance to break #2 which is very brittle (I did, it crumbled in my hands).
    I've gone through the whole thing in the last week so it's fresh in my mind; keep asking questions and I'll tell you everything I've learned...
  10. #530
    Dec 19 2007
    York, PA
    #2 in that diagram usually fails more so than all the others....as does #13.
    -Nate
  11. #531
    Dec 19 2007
    York, PA
    Thanks!~
    smoke test
    -Nate
  12. #532
    Dec 05 2007
    I am not really trying to read 14 pages of this thread, but not sure if this question has been asked yet. Here is a pic of the rerouting from the first post.
    Would there be an issue if I removed what I highlighted in green (pic below), route the BOV to that nipple that the green one is going, plug the one under the throttle body (assuming that is where the BOV line is going, but I remember that nipple being larger than the others), and get readings for my boost gauge from my FPR to IM line? I have a Precision PW39 that wil be installed. And the instructions state to T-off the boost pressure source of the turbo with the side nipple of the WG, then route that line into the boost pressure side of the MBC (Turbo XS BC-HPBC). Then the wastegate nipple on the mbc goes to the top nipple of the WG (Referr to pg 7/9 of the PDF to see Precision's install instructions). That is what I would do for the external WG scenerio.
    Also, would it be ok to get the billet crank case breather adapter, place a barb fitting onto the 1/2"npt (I think that's the size of the female threads on the adapter), run a heater hose to the 3 way valve cover breather port hose (barb adapter), and run the other side to a vented catch can (which orginally leads to pancake valve and turbo inlet pipe)? This is the route I want to take, and just wanted confirmation that is won't cause an issue. The diagram (from original post) says that it goes to a vacuum generator from the exhaust, but can I do it the way I just stated? I know a vacuum source is more preferred, but will anything get messed up if I go this route? Thanks!
    I hate it when my car acts like a little bitch, treating me like the bitch
  13. #533
    Senior Member Three Rings Papa_Dios's Avatar
    Jul 01 2010
    fl
    I did this not to long ago. Haven't had any issues aside from the evap code and sai code (to be expected).
    Finally off jackstands!!!!!!!!!!!!!!!!!!!!
    My 5 speed swap thread
    Parts I have for sale!!!
  14. #534
    Senior Member Three Rings pape's Avatar
    Nov 30 2008
    MIA
    I have read mixed opinions about MPG and evap removal. Does your MPG drop if you remove the EVAP?
  15. #535
    May 10 2011
    Mass
    nope.
  16. #536
    Jul 01 2010
    fl
    Quote Originally Posted by pape View Post
    I haven't noticed any yet I'll let you know if that changes though. Hey you going to the GTG in Orlando in September?
  17. #537
    Dec 19 2007
    York, PA
    Quote Originally Posted by hummvee2134 View Post
    nope.
    x4, nope
    -Nate
  18. #538
    Dec 05 2007
    Can anyone answer my question in post #532? Thanks!
  19. #539
    Senior Member Four Rings walky_talky20's Avatar
    Jun 30 2008
    Erie, Pennsylvania
    Seerlah, what you said for the breather stuff is fine. That is how a lot of people do it, just tie the 2 breather outlets (block and VC) to a vented catch can. Just make sure you lines are large enough.
    As for your pressure line routing, nothing from your wastegate should ever connect to the intake manifold. Both lines will be "boost only", so they will come from the compressor housing. One direct, and the other passes through your MBC. Your DV/BOV connects to the manifold directly using that front port.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, APR 93, Splitter, electronic oil pressure gauge, B6 Sport 17's, ST Coilovers,
    Need to borrow a Cam Chain Tensioner Tool? $4 for shipping. PM me. *Unavailabe*
  20. #540
    Dec 05 2007
    That's what I thought (about the WG), but the diagram in the OP says otherwise. And thanks for clarification on the engine ventilation setup. My VC to catch can is 1" ID, and the crank case to 3 way hose will be either 3/4" or 1" ID. Need to measure the ID of the 3 way hose leading to the crankcase before I decide.
  21. #541
    Nov 30 2008
    MIA
    Quote Originally Posted by Papa_Dios View Post
    I am not in Miami any more so no. Any way were is it?
  22. #542
    Nov 30 2008
    MIA
    I wanted to ask to any one with a catch can that has it conected like so (block to valve cover "T" and one hose to the pancake valve on the tip)
    Does it generate vacumm at idle inside the block? when you take the oil cap of does it get sucked meaning there is vacumm?
  23. #543
    Active Member Two Rings 04dolphin's Avatar
    Feb 21 2005
    2004 A4 1.8T
    So Cal
    Does anyone have the part number for #2 of the diagram for 2004 1.8t? I ordered the Breather Hose Kit from 034 motorsports and doesn't look like this is included. Thanks!
    04 1.8T 5-spd
  24. #544
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    Quote Originally Posted by 04dolphin View Post
    Part No.: 1C0906517A
    http://www.ecstuning.com/Audi-B6_A4-...mission/Valve/
    They are the Vent/Purge Valves.
    -CP
    2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
    2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
    SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
  25. #545
    Jun 30 2008
    Erie, Pennsylvania
    Charles, I believe he was referring to the block ventilation diagram from post #524. The breather pipe which is very common to break:
    http://www.ecstuning.com/Search/06A_103_213AM/ES7938/
    @04dolphin: That part is definitely replaced as part of the 034 silicone breather hose kit for AMB ("late" AMB in your case). In fact the 034 kit would be replacing items #2 as well as #5-13 (and 2x of #14 I would assume - not sure how many clamps they throw in, but I'm assuming all of them). It basically replaces that entire diagram save items #15, 16, 17, and #4.
  26. #546
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Cant believe this thread is still going strong after all these years!
    Anyways, IIRC 034 offers a cheaper alternative than installing the $53 OEM part that will eventally fail and crack again. They should offer an aluminum piece which you can slip into the housing and the top portion is threaded so you can use stainless steel braided fitted lines.
    -Sami-
  27. #547
    Senior Member Three Rings Crispy222's Avatar
    Mar 15 2008
    Syracuse, NY
    You talking about this VC piece from IE?
    http://www.intengineering.com/Integr...91699-1-2.html
  28. #548
    Jun 27 2011
    My bad, I just referred to the first diagram I saw.
    -CP
  29. #549
    Mar 12 2010
    my
    Quote Originally Posted by Crispy222 View Post
    I am in the process of doing all of this myself. ABSOLUTEGTR 034 Makes a billet piece that you are talking about (http://www.034motorsport.com/engine-...18t-p-392.html) I am considering going this route myself. The red aluminum part CRISPY222 posted is for the back of the valve cover.
    Therefore all you would need would be a stainless line and some type of aluminum T-flange for the back of the valve cover? (so you can add a catch can/connect to breather)
    You guys are eliminating the other vac line that is seen in the 034 breather kit right? (between old breather hose and oil filter housing)
  30. #550
    Senior Member Three Rings Abuck35's Avatar
    Sep 11 2009
    PA
    Quote Originally Posted by AudiHere04 View Post
    I too messed broke one of my nipples..
    ahahaha LOL
    REVO2** AWE FMIC** Genesis 380's** Carbonio** ER tip** EVO MS DV** Magnaflow** gutted cat** N249 bypass**
  31. #551
    Sep 11 2009
    PA
    14 pages and still the same questions....really??? Why are people still posting hereeeeee!!!???? CAREFULLY READ PAGE ONE WITH ASSOCIATED LINK. DO WORK. DONE.
  32. #552
    Senior Member Three Rings davkav's Avatar
    Dec 04 2008
    Dublin, Ireland
    Quote Originally Posted by Abuck35 View Post
    Why are you still subscribed to it, if it bothers you so much?
    -Dave
    B6 A4 USP Avant 1.9 TQ 6M (01E) - 71r - Revo 550 File
  33. #553
    Dec 19 2007
    York, PA
    bc London has issues.
    -Nate
  34. #554
    Sep 11 2009
    PA
    LOL ^yes. everyone here will come to learn that with time. hahaah
  35. #555
    Feb 21 2005
    2004 A4 1.8T
    So Cal
    Thanks! My car is running like new after replacing the hose with the 034 kit, valve cover gasket, spark plugs, coolant flange and oil pressure sensor switch!
    04 1.8T 5-spd
  36. #556
    Active Member Two Rings Sam091990's Avatar
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    I'm planning on doing this sometime in the near future. I'm a bit confused about the 'dump line below the transmission' part of the illustration. I've read through numerous posts that you can hook that up directly to the exhaust to have vacuum present. So basically, run a steel line from that T to the exhaust? When you do this, do you just simply have a piece welded onto the exhaust so you can connect the steel line? If so, which part of the exhaust system would be the best place (stock exhaust system)?
    || Slow A4..
  37. #557
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    || Slow A4..
  38. #558
    New Member One Ring
    Jan 25 2012
    Athens, GA
    Ok, so I am probably going to get ripped a new one, but I'll try anyways.
    First off, mine isn't an Audi, its a 2002 B5.5 Passat, but from what I have read, it is pretty much the same setup.
    I have read all 14 pages, I know what I want to do, but I have a question and I don't think I have seen the issue posted.
    On the B5.5 Passats with the Automatic Tranny right next to the Power Steering Reservoir there is an electric vacuum pump for the Brake Booster.
    I don't currently have a picture of how it ties in, I can get one tomorrow when its daylight.
    But I was wondering if anyone has dealt with this pump in performing the mods on this thread.
    Any and all help is greatly appreciated.
  39. #559
    Jan 04 2012
    mk1 r5 turbo
    Chester UK
    Thanks man
  40. #560
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    AE86 20v, UZZ30 LS2, 2002 A4 B6 1.8t
    Huntington Beach, Ca
    i attempted this a few weekends ago and gave up. reason being i couldn't easily reroute my aftermarket oil catch can drain back valve to return to the engine. bought the 034 breather hose adapter and realized i should have went AN fitting with 90degree elbow. no way i can fit a reducer and 90 degree in there. decided to do this after i go turbo upgrade. also didn't want a check engine for SAI insufficient flow.
    great write up btw. took me a while to figure a lot out. basically once you start ripping things out you figure it out. also so much roomier if i did complete the entire procedure. couldn't have even thought to start this without this write up.
    one question i have though is, off my suction jet pump Y fitting, there is a hose with a thick all rubber PCV valve type thing that is all chewed up. it can be removed. what does it look like when its new? i read postings that state it is only a dump hose, but there is obviously a PCV check valve in mine. if anybody is willing to trade 034 breather adapter nipple for IE AN fitting type let me know.
