Results 1 to 26 of 26
    Senior Member Two Rings starfriend's Avatar
    Oct 17 2007
    A4 GTRS
    Norway
    Replacing the N75 with a MBC? no?
    Hi,
    Can i replace my N75 with a MBC by simply removing it, and clogging the hole in the TIP with a bolt or something? will the n75 need to remain connected in a loop system or what? How will this work with my Revo software? (default settings right now, and i dont have a sps).
    My guess is that i can just hook the MBC, and leave the n75 connected in the tip open as it is without limp or anything? but how will this affect my boost? if i set the MBC wide open so it charges to like 20psi?
    - star
    Dec 28 2006
    2003 A4. 2018 MB GLA250
    Western Maryland
    Items for Sale
    Re: Replacing the N75 with a MBC? no?
    Run it in parallel. See post #9: Clicky click
    A4 Motoza tuned Frankenturbo F21L mixed flow turbo / Bosch 550's / 3" MAF / TyrolSport SMIC / 034 HFC / TT 2.5" DP / Borla Exhaust / Eibach ProKit Springs / Koni Yellows / H-Sport Sway Bars / TyrolSport Brake Stiffeners / HyperShift Short Shifter / Podi
    A5 Mods to come: Little stuff so far. 20/25mm spacers / H&R OE Sport springs / 35% tint / Neuspeed Power Module / black window trim / RS grille.
    Oct 17 2007
    A4 GTRS
    Norway
    Well, yeah, but still using the N75, wont that kind of kill some of the point with MBC? to have it spool and respond a bit faster? thanks for the link btw!
    Dec 28 2006
    Western Maryland
    Items for Sale
    give it a try and see if you like it. I think you will find that it becomes "all or none" with the boost and the car will be harder to modulate. It may also throw it into limp mode quicker.
    Edit: to answer your original question: Leave the N75 hooked up electrically. Leave the line from the N75 to the TIP intact. Remove the other two lines in and out of the N75 and insert the MBC there. Run a loop to connect the in/out ports on the N75 (keeps dirt out for when you hook it back up after you decide the MBC sucks!)
    Have fun!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    Have fun!
    Correct. I have my N75 plugged in but no lines running to it. This avoids a CEL and allows me to run my EBC.
    -Doug
    '02 A4 Avant 2.7T 6spd
    Oct 17 2007
    A4 GTRS
    Norway
    thank you for your reply old guy, one more thing, what happens if the MBC is wide open and the boost is at full? will the fuel adjust somehow or will my car be runnig lean as hell? if so, im not even gonna try.. fine adjusting it will probably be a PITA
    Dec 28 2006
    Western Maryland
    Items for Sale
    Quote Originally Posted by starfriend View Post
    Your fueling should be OK.
    Oct 17 2007
    A4 GTRS
    Norway
    what? really? like, i can use this to run high boost (like 20psi) till i get my SPS? (loading about 12now from factory, REVO tune GTRS) if so, this could not have been cooler. I thought that stuff was "fixed" tho. (preset)
    Jun 08 2007
    GLI
    Orlando, Fl
    Items for Sale
    Be advised, the N75 regulates boost more conservatively and gives it to you more linear; smoother I should say. The MBC is does away with this, the way boost comes will come on is very sudden and strong. I prefer the N75 but everybody is different.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Jun 08 2007
    GLI
    Orlando, Fl
    Items for Sale
    The Revo tuner preset your car to run 12psi when he tuned it? You can run 20psi w/o any problems.
    Oct 17 2007
    A4 GTRS
    Norway
    Quote Originally Posted by A4Dit View Post
    yeah, thats default from tuner afaik (12psi var roughly calculated from 0.7BAR), isnt it T3 and B5 when i get it? i have been waiting so long for the SPS to get the boost going and i can just use the MBC.. god damnit;) 1hour til im off work, guess what im gonna do today? :D
    Apr 01 2007
    2017 Mustang GT Performance Package, 1983 Chevy Silverado
    houston texas
    just leave it plugged in the hole in the tip and place the lines onto the mbc, thatll work great
    barrett
    2005.5 6 speed with the Premium, Lighting, Sport, and Cold Weather packages
    Pag Parts EFR 6758 kit, Pag Parts intake/FMIC/manifold/downpipe, Eurodyne Boost Manager Plus, Eurodyne Maestro, StopTech 332mm BBK, Stasis Touring suspension
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    OG B6 A4, B8.5 S5, C7 S6
    OC
    leave the N75 in the TIP and just remove the boost signal lines, loop the input and output with a 6mm vacuum line.
    If you run a MBC without being on boost 9 with the SPS your requested boost will be lower than your actaul boost, the car will not run on the sweet spot of the MAP but it will run fine. You will not see maximum power potential.
    On boost 9 with the SPS the requested will be 2540 at all times, this is the maximum the software allows (constraints of ME7)
    I run a EBC set at 20psi for pump gas and 22 or 25 for race gas, it took a bit to tune the duty cycle but my boost is very smooth and linear.
    Oct 17 2007
    A4 GTRS
    Norway
    im not after full potential ofc, i just want more juice till i get the SPS.. but i dont quite ge ti,
    you want me to leave the outlet on the turbo, and the wastegate niple left wide open? and most of all, is the thing i was planning to in the last post dangerous to my car?
    Oct 17 2007
    A4 GTRS
    Norway
    and how does it NOT matter if i boost 2psi or 20psi, when it comes to the fueling? what measures that?
    Jul 04 2004
    OC
    No, you need to have an actual boost controller or you will peg boost and cause issues
    Oct 17 2007
    A4 GTRS
    Norway
    What i've figured, but is the fueling only depending on the MAF? hmm.. always thought there where more balls in the air ;-)
    Oh well, ill try looping the N75 tomorrow, and using a MBC for the rest, to try it out:)
    Thanks for your help and replies.
    Oct 17 2007
    A4 GTRS
    Norway
    tried to install the MBC today, by leaving the N75 plugged in the tip, and running a hose in loop "inlets\outlets" on the n75.
    The mbc seemed to not have any effect (i take it turn it against "-" is less boost? a forge unos).. first i thought it was because i plugged the wg\pressure wrong, so i swapped pos, but that didnt change anything.. unless i actually plugged them back where them was.. which would be embarrasing... ideas? is "+" less boost? what am i missing?
    btw, is this mbc reliable? and what will happen if it "breaks" and i overboost without noticing it? (i have a gauge tho:p)
    A4/B6-2001 [Eurospec]
    430cc Genesis //GTRS// REVO //ATP// CUSTOM 3" EXHAUST w/ Magnaflow Mufflers //BSR OPTIFLOW INTAKE// FORGE SPLIT-R //Neuspeed Xtreme TIP// Racetec FMIC //Hitachi E//
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Items for Sale
    + is more boost. not certain and probably way off, but i think 4 clicks is 1 psi...again i'm probably wrong
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Oct 17 2007
    A4 GTRS
    Norway
    that sounds just about right, cause there is a million clicks;) well, then i dont know what the hell i did wrong.. it boosts +1bar ( i lay off there ) and its turned all the way on "-"...
    Oct 17 2007
    A4 GTRS
    Norway
    tried swapping the hoses, and having it to "-" all the way, nothing works, so it must be broken.. damnit the f...
    Feb 24 2007
    Burlington, Vermont
    Items for Sale
    what psi are you trying to obtain? youre talking about setting it all the way to "-" but why? Didn't it come with a print out for the orientation on install? I have the same mbc, no problems with it.
    - Scott
    Das Build Thread
    Oct 17 2007
    A4 GTRS
    Norway
    im trying it all the way "-" to insure that it works before i start tuning, i cant just put it in the middle and floor it, that would blow the shit off the turbo. And all the way turned on "-" should not surpass 1.2bar (like 15ish psi). So thats why. I want to use it so i can run 20psi (n75 only does 10psi now, due to the chip, waiting for my SPS).
    Print out or not, i have tried it both ways, so it shouldnt matter.
    Jan 01 2010
    74 VW Bus
    Orlando, Florida
    So wait does your chip not let you go over 10psi or is your N75 bad or possibly are you running stock software? I realize me asking the stock software part maybe a little foolish but that is about what a stock setup does also IF you are chipped to only run x amount of boost and you decide to go to +x with a MBC then how does fuel keep up?
    Dec 25 2004
    Earth
    Items for Sale
    I get 21 psi all the time with an N75 "J" and APR K04 tune
    034906283J.
    Apr 01 2007
    houston texas
    You need a better boost controller of you want to run it independent of the N75. Our cars need a ball and spring/bleed valve combo style mbc, like the TurboXS HPBC.
    http://turboxs.com/shop/boost-contro...ontroller.html
    You will also need to log your car in all sorts of boost situations (low speed/RPM cruising, WOT through various gears, etc.) to have a solid understand of your current boost onset. Your MBC will have to mimic those boost threasholds by + or - 300mbar, because if there is any more variance than that you will hit limp mod, your fueling will go to shit, and you will run lean as hell until your engine blows.
    Now, all that said, your REVO tune should most definitely boost more than 10PSI. You either 1. have something wrong with your car that needs to be address; slapping on a MBC is literally the worst thing you can do or 2. need to go back to your REVO tuner and have they adjust your tune's setting bc they did not set it correctly.
    Get our car all buttoned up, and/or your revo tune issue addressed, then think about the MBC.
