Page 1 of 5 123 ... LastLast
Results 1 to 40 of 168
    Senior Member Three Rings greene08's Avatar
    Mar 29 2008
    1996 Ford Bronco Eddie Bauer
    Bellevue, WA
    Cool RS4 Rear Sway Bar Install
    I just finished installing my RS4 rear sway bar with new brackets last night. I must have to say that it is quite the noticeable difference even when you don't push the car! The car doesn't lean as much in the corners, the steering feels more direct and has better turning weight. All in all the $125 I have into the project was well worth the cost. Oh, and it only took me 55 minutes start to finish. I am no professional but a hobby worker at best.
    Parts:
    - OEM RS4 Rear Sway Bar # 8E0-511-409-AL
    - OEM RS4 Rear Sway Bar Brackets # 8E0-511-439
    - OEM RS4 Rear Sway Bar Bracket Bushings # 8E0-511-327B
    *Audi updates its part numbers so they may be updated since the time of this guide. Please check with your Audi parts dealer if you think you have a discrepancy or PM me.*
    Tools:
    - Wheel Ramps
    - 13mm Socket
    - 15mm Socket
    - Safety Glasses!
    *It has come to my attention that some have had better luck with using a 16mm socket on the outside link bolts of the rear sway. They have also used 3" and 6" extensions for their sockets to get better access to some bolt locations. My assumption is that you will use whatever you deem necessary at the time. Make sure you have a complete metric socket set with you--it is always a good idea.*
    Step 1: I started by backing the car up on the wheel ramps. I used ramps so that I could apply the parking brake and keep the car in gear to prevent accidents.
    Step 2: Remove the 15mm bolt (one for each side) from the stock sway bar axle link.
    Step 3: Remove the (2) 13mm bolts from the stock sway bar brackets (4 bolts total--2 per side).
    Step 4: Remove the (2) 15mm bolts from the exhaust hangars to allow the exhaust to hang down (4 bolts--2 per side). CAUTION: Have a jack stand under the exhaust to prevent it from sagging too low--you can adjust as needed.
    Step 5: Remove the old sway bar. This will take some contortion on your part and some trial and error. I eventually brought one end out from in-between the exhaust near the gas tank and was then able to slide the other end out. How I got there is hard to explain, just try to get one end as far into the wheel well as possible and you'll be in good shape. CAUTION: DO NOT break the blue plastic link in the drivers side wheel well. You'll be sorry.
    Step 6: Install the new sway bar in the reverse fashion you removed the stock unit. This still takes some trail and error as it is bigger but it was twice as fast going in as the old was coming out.
    Step 7: Loosely install the left and right 15mm axle link bolts. We will tighten these later.
    Step 8: Loosely install the left and right 13mm sway bracket bolts. Make sure the brackets are properly seated over the bushings and not pinching in any place.
    Step 9: Once all bolts are loosely installed and all bushings are seating properly you can go through and tighten up your bolts. There are 6 bolts in total (2-15mm and 4-13mm). These do not need to be wrenched to the point of stripping, just a good snug fit is all that is necessary. A little blue locktite is never a bad idea either, however I didn't use any.
    Step 10: Install the exhaust hangar brackets with the (2) 15mm bolts per side. Before you cinch the bolts tight you may want to check the alignment of your exhaust to the rear bumper cutouts. You can adjust left/right as necessary before tightening the bolts completely.
    Step 11: Re-check your work and all bolts, clean up your tools, drive the car off the ramps and you're done!
    NOTE: This is the bar installed. The bar should be oriented in the shape of a "u" when installed properly. If the bar makes a "rainbow" shape when looking at the center you have it installed backwards.
    NOTE: The new brackets are larger than the stock brackets and fit exceptionally well. Anyone who says the stock brackets are OK with the larger bar is WRONG.
    The 18mm stock sport bar and the 22mm RS4 sway bar side-by-side.
    What a great improvement! Now I just need a suspension to compliment this. And wheels, tires, brakes, engine upgrades, seats... yikes!
    Mitchell Greenblatt - Real Estate
    The Greenblatt Group
    My Personal Blog
    2012 Audi S4 MT6 (CURRENT)
    2007 BMW Z4 M Roadster (SOLD)
    2007 Audi A4 2.0TQ MT6 (SOLD)
    Senior Member Two Rings ice cream man's Avatar
    Sep 14 2006
    quartz ,6 mt, S-Line, titanmum
    New York
    Re: RS4 Sway Bar Install Guide
    woah great write up.
    OOOO A4 2.0T 07 Q.G. 6 spd. S-Line Tit.
    Senior Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    interesting, the GB from Performance cafe says the old brackets fit fine???
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Mar 29 2008
    Bellevue, WA
    I bought all of the parts, including the new brackets from Performance Cafe. The GB assumed you would re-use the stock brackets. You can certainly get them on--with a lot of work. If something needs to be forced on it wasn't meant to be there.
    My Personal Blog
    New Member Two Rings Teddy M's Avatar
    Jun 25 2008
    2008 Audi B7 a4
    Miami, Florida
    looks good..hope it improves alot
    Black A4 b7 S-line
    -15% tints
    -Test pipe//downpipes
    -debaged
    -blacked out tail lights
    -exhaust with quad tips
    -S4 valence
    - hula dancer on the dashboard
    Registered User Four Rings PerfCafe's Avatar
    Nov 27 2007
    is where we work on cars!
    Monterey CA
    Quote Originally Posted by greene08 View Post
    nice install guide man! The brackets do fit fine ... maybe new brackets will fit easier because they are new and do not have any road/driving wear on them especially for b6 cars which some have seen higher mileage than later model cars. But the brackets for all b6/b7 cars be it a4, s4, rs4 for the rear sway bar is an identical part number.
    Sep 14 2006
    New York
    Quote Originally Posted by CZA420tAvant View Post
    they fit with some "elbow grease" literally
    Very nice write up.
    Cars, tech, FREE STUFF, funny videos, and more!
    http://barzknows.blogspot.com/
    Also:
    www.blackbadges.com
    Senior Member Two Rings toro's Avatar
    Mar 05 2006
    06 A4 Avant
    Bayarea, CA
    great, i will follow your instruction to install mine. really clear procedure. thanks a lot of write up.
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Nice write up
    Senior Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    do the bushing need to be greased? i havn't looked at my kit yet (in europe so i dont know)
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    LUBRICATION/GREASE IS NEEDED! If you don't have it you get this really annoying squeaking sound which will make you want to ripe out your own eardrums.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    New Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    does this sway bar tighten up the rear enough that you can break the rear end out in a turn.
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Active Member Two Rings CardNation's Avatar
    May 12 2008
    Louisville
    Damn it, now I have to do this!
    07 A4 2.0T Quattro Tip
    Light Silver Metallic
    | REVO 93 | Eibach | Koni FSD | 19" RS4s | RS4 sway |
    Apr 14 2008
    Milton VT
    cant wait to put on my setup pss9's + rs4 rear sway bar.....one more month !!!!!
    Senior Member Two Rings PolishPete's Avatar
    May 12 2008
    IL
    What part / where are you guys lubricating? At the bolts or on the rubber bushings?
    2008 A4 2.0T Quattro Special Edition / 35% Suntek Tints / APR Software / (Lease Ended)
    2007 RS4 / 35% Tints / APR Tune / More To Come
    Mar 29 2008
    Bellevue, WA
    Quote Originally Posted by PerfCafe View Post
    JB -- the bracket part numbers listed above in my guide are the larger brackets you sold me that I specified. That part number is NOT the same for the stock A4 sway bracket. This is evident in that the brackets are not the same size.
    Guys, you can see from the pictures that the new brackets I bought are LARGER than the stock brackets. The larger brackets fit perfectly while the smaller units would have needed excessive force to install over the RS4 bushings.
    I did not grease anything. The new RS4 sway bar already came with a thin layer of grease on the bushing bumper (the permanent rubber piece on the sway bar that the bushing sits on). The bushing does not sit directly on the bar. The bracket-to-bushing interface does not need grease. I have no noises and probably because I used the proper brackets.
    Point of my story... buy the larger brackets!
    My Personal Blog
    Mar 29 2008
    Bellevue, WA
    I have not tested the car fully but I would imagine it is stiff enough to kick the rear end out in a high speed tight radius turn, yes.
    My Personal Blog
    Mar 29 2008
    Bellevue, WA
    Quote Originally Posted by PolishPete View Post
    I didn't need to lubricate anywhere and have no noises what-so-ever. Definitely not at the bolts. There is already a thin film of grease between the bushings and the bushing mounts (permanent rubber stops) on the sway bar.
    If you don't use the smaller brackets you should be just fine.
    My Personal Blog
    Senior Member Three Rings B6QTRO's Avatar
    Nov 05 2005
    2007 A4Q S line 2006 A6 Avant
    Downers Grove, IL
    Damn, I need the larger brackets I was installing mine today and everything was fine until it was time to get the brackets on and it was a pain in the a$$! I hope my local dealer has them in stock if not I may need to order them from JB at Perf Cafe
    07 S line Titanium PKG
    Koni Coilovers | RS4 Grill | RS4 Recaros | Lamin X Fogs | Miltek Sport |OEM RS4 BBK | AWE Boost Gauge |
    APR | RNSE | 19" Champion Motorsport RF62's| Carbonio | Ultrac Sessanta | V1 Hardwired | RS4 Rear Sway |
    | Carbon Fiber Interior Trim | Blacked Out Front/Rear Rings | RS4 Pedals | Skid Plate | Phat Box | 35% Tint |
    Nov 05 2005
    Downers Grove, IL
    BTW the part # on the A4 bracket is 8A0-511-439
    Mar 29 2008
    Bellevue, WA
    Double check the number. That might be for the same size brackets you currently have... I'm not sure. The number off the brackets I used IS 8E0 as I just looked at them again.
    They worked perfect.
    My Personal Blog
    Nov 05 2005
    Downers Grove, IL
    I meant to say the 8A is the stock part # on the bracket for the 18mm bar
    Mar 29 2008
    Bellevue, WA
    Ah... yes... that would be true my friend!
    My Personal Blog
    Senior Member Four Rings IceMole's Avatar
    Oct 09 2007
    - E46 M3
    Kutztown, PA
    Nice writeup +rep
    -Kris
    Nov 05 2005
    Downers Grove, IL
    Picked up the brackets and it's installed, Thanks for the write up
    Senior Member Three Rings drexplode's Avatar
    Jul 19 2007
    1999 A4 2.8 (hooptie)
    Michigan
    someone make this a sticky, or put in the DIY list:
    http://audizine.com/forum/showthread.php?t=105668
    Great write up, I need to do this! :-)
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Senior Member Three Rings toothysaw2's Avatar
    Jun 05 2008
    '10 S5 6mt
    Austin, TX
    just want to second the need for the brackets... or at least second that they are different parts. took my car to get sway and coils installed and the guy who did it worked for audi for many years, first thing he asked was 'did you get the brackets for the sway bar?'.
    told him about how nobody can agree if they're needed or not. so, yeah... gotta find some now.
    2010 S5: Sprint Blue, 6MT, Premium Plus
    mods: 35% pinnacle tint, hoen xenonmatch fog, hoen license plate lights, rs4 pedals, vag-com, black-out grille and rear valence
    Mar 29 2008
    Bellevue, WA
    YES buy the brackets, they will make your life easier.
    Glad the write-up has worked for you all so far. I still have to finish my write-up of the LED tail light install.
    Maybe the mods will make this thread a sticky? It is just SO good how can you resist? Hell, I need to be an administrator. I'll just make write-ups and then sticky them myself.
    My Personal Blog
    Active Member Two Rings Scott Evil's Avatar
    May 20 2007
    2008 A4 2.0T QSE 2009 Tiguan 1987 944 Turbo 2006 MCS Cabrio
    Central Ohio
    "NOTE: The new brackets are larger than the stock brackets and fit exceptionally well. Anyone who says the stock brackets are OK with the larger bar is WRONG."
    Agreed. For a casual wrencher, it makes the install easier.
    It may exist somewhere, but an aftermarket bracket with a grease fitting would be a nice upgrade too.
    2008 2.0TQuattro Dolphin Gray S-Line (LOL weren't they all?)
    No Mods, yet, but I have a wish list. I have a kid now, so its a Tip.
    SOLD:
    2005.5 A4 2.0TQMS Fun car, but I don't miss it so much
    2004 S4. Hell of a motor. Not much soul and way shitty gas mileage
    2001 S4. Still miss it. H&Rs, Baileys, Twin-2, CHs, Short-shift, Bi-pipe, X-Chip. 96,000 trouble free miles.
    Nov 27 2007
    Monterey CA
    Just check w/my dealer haha correct part number for the brackets (RS4 only) are 8A0-511-439 please update! The one listed in your post is for the b6/b7 A4 etc which is where everyone is getting confused.
    Nov 05 2005
    Downers Grove, IL
    JB, The 8A part # is for the A4 not the RS4 sway. I double checked my old brackets and my receipt from the RS4 brackets that i purchased at the dealer.
    BTW, Thanks for the prompt shipping of my sway bar
    Nov 27 2007
    Monterey CA
    Quote Originally Posted by B6QTRO View Post
    Are you sure you got the right brackets then? Because my dealership (whom I just got off the phone with) told me the 8A0 is for the RS4 ...
    Nov 05 2005
    Downers Grove, IL
    Yez zir
    Mar 29 2008
    Bellevue, WA
    JB, the brackets you sold me are the 8E0 brackets and they worked perfectly for the RS4. They were larger than the stock brackets as shown in the picture from my install thread.
    I think the guy at your dealership is now giving you bad information!
    My Personal Blog
    Mar 29 2008
    Bellevue, WA
    See... 8E0 are the larger brackets...
    My Personal Blog
    Senior Member Two Rings akordboy's Avatar
    Feb 24 2008
    B6 A4 1.8tQ 6-sp
    York, Pa
    Great write up!! Glad I seen this before I installed mine.
    Senior Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    Someone wrote a DIY using the stock brackets but had to do some modding of them using pliers and vise grips... not really interested in messing around with them so for $22 bucks there a steal :)
    - [B] 2012 Ford Mustang GT 5.0 6spd
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Apr 14 2008
    Milton VT
    only difference between stock and rs4 bracket is your need to use force to get the stocks to fit over rs4 bushing
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Senior Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    I will be getting my Swaybar pretty soon...Looking forward to receiving it...
    What I ordered is:
    -1x 8E0 511 409 AL
    -2x 8E0 511 327 D
