Results 1 to 11 of 11
    Established Member Two Rings EOD-5's Avatar
    Apr 20 2008
    98 A4 1.8tQ, 1990 Miata
    Newark, Delaware
    ripped tie rod end boot - replacement options
    arite, so ive been slowly losing PS fluid for a few days, never saw any leak at all so i thought maybe it was just low and kept filling it up a bit
    but today was a big leak under my pass side wheel and oil all over the fender lining and my pass side of my car
    jacked it up and the boot on the tie rod is split open....
    question:
    can i just replace the boot or does the whole tie rod have to be changed? ive checked ECS and they dont have just boots and the tie rod itself appears to be fine....
    i used about a roll of duct tape for now to "seal it"
    thanks
    1998 Audi A4 1.8tQ 5 Speed
    VVME 4300k, RS4 Grille, GIAC, Piper Cams, APR TIP, Blinktek Heatshield, Forge FMIC, Catch Can, TurboXS BOV, PowerGasket, ECS FP Gauge, VDO Boost Gauge, ATE Slotted Rotors, PBR Pads, RubberTite Floor Mats, 034 Coil Cover
    1990 Mazda Miata
    not stock
    Veteran Member Four Rings Nebone's Avatar
    B6 & B7 A4
    Cumberland, RI
    Items for Sale
    Re: ripped tie rod end boot - replacement options
    If the rest of the tie rod is good, as in no plat in it, then just replace the end.
    I have one I can sell you cheap.
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Apr 20 2008
    Newark, Delaware
    Quote Originally Posted by nebone22 View Post
    the tie rod is fine, the boot is ripped
    i just called a local audi repair shop and they said that the boot wont be the problem , b/c it wouldnt leak anything
    they said that it sounds like the seal on the steering rack is bad and the whole thing needs replacing
    is this correct?
    1990 Mazda Miata
    not stock
    Jan 06 2005
    1998 A4 1.8TQM
    Norristown PA
    dude, I think your looking at the Axle. If the boot on the Axle ripped, then, yes, you'd have grease all over your wheel area. And I mean grease, gnasty stuff that you're not just going to wipe off with one paper towel. You can replace just the boot, but it's the same job to just replace the whole axle and a lot less headache. Look for the write up on Audiworld on how to do it. I'd recommend using lock-tite for your inner bolts that mate up to the trans.
    p.s. tie rods don't leak anything and if you take your wheel off, your tie rod should be right near your head near the upper control arms
    Good luck.....its an easy yet slightly messy job.
    B6 & B7 A4
    Cumberland, RI
    Items for Sale
    When the seal on the steering rack goes, the rack goes. Does your leak come from the large bendable boot on the steering rack?
    Have the shop inspect this.
    Apr 20 2008
    Newark, Delaware
    Quote Originally Posted by A4euro View Post
    nope im looking at the tie rods
    the boot is ripped on it
    im guessing the steering rack seal blew, thus letting PS fluid leak into the boot, thus flooding the boot, and it then burst...and now its leaking everywhere
    i think the rack needs replacing
    1990 Mazda Miata
    not stock
    Stage 2 Banner Advertiser Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Are you referring to the Steering Rack boot (long accordian looking piece) or the Tie Rod end Boot (small rubber cover on the the very end of the ball joint of the tie rod end)?
    Steering rack boots are sold separately and available.
    Tie rod end boots are not sold separately, and can only be replaced with a new tie rod end.
    We've got updated Febi-Bilstein tie rod ends at a great price here.
    Febi TRE
    www.purems.com
    San Diego, CA | mike@purems.com | Twitter! | Facebook
    Your Source for everything APR, HRE Wheels, Brembo, TSW, Rotiform, VMR Wheels, Stern, Evolution Racewerks, Clutchmasters, South Bend, Carbonio, VWR, Gruppe M, OSIR, and much more!
    Apr 20 2008
    Newark, Delaware
    Quote Originally Posted by Mike@PureMS View Post
    Febi TRE
    im talking about the long accordion piece
    however ive been told the whole rack is shot because it shouldnt be leaking fluid (of course)
    1990 Mazda Miata
    not stock
    Active Member Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Sounds like the rack seal is gone.
    Jim
    I Do Werk.
    99.5 A4 28RS 1.8TQS VolcanoBlk
    Vancouver, BC Canada
    I just replaced my steering rack with new tie rod ends, the passenger side seal worn out.
    Pics&Detail
    Footworks-CCW Classic/OZ Ultraleggera/VMR V710/BilsteinPSS9/034/Stern/ASP/APR
    B6 & B7 A4
    Cumberland, RI
    Items for Sale
    He must mean the accordian boot. It will start squeeling soon so get ready to shell out some cash.
