Results 1 to 33 of 33
    Senior Member Two Rings ekaufman's Avatar
    Jul 02 2007
    2008 Black A4 S-line
    Santa Monica
    18" vs. 19" VMR wheels: structural strength?
    I am about to order Velocity RS4 reps and Im deciding between 18s and 19s. I realize this question has been posted many times before, but Im looking for some feedback on the structural integrity of the 19s vs. the 18s.
    Ive read quite a few posts where users say, "I went with 18s since I drive on bad roads".
    I do have to drive on beat up city/downtown roads on a regular basis. They arent North East bad, but still beat up and I definitely feel them on my stock 17s and sport suspension.
    Are 18s just the safe bet from a drive and durability stand point?
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    Re: 18" vs. 19" VMR wheels: structural strength?
    well with 19s, your tyre will have a lower profile, which will mean more feedback (less absorption) from bumps & potholes. However, the wheels will all have undergone the same testing processes, so an extra inch shouldn't make any difference to the structural strength of the wheel, though they will be a fraction easier to curb as there isn't as much rubber around them.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    New Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    Dude you still haven't made a choice?You asked like 74 questions on which ones to get lol. I have the 19's with coilovers. The roads are pretty crappy and although I feel every bump in the road, it isn't that uncomfortable to the extent that I would want to get 18's or a thicker tire. The difference isn't that bad, I think you are putting too much thought into it.If you keep your sport suspension, no matter what size you get, the ride will still be bearable. Where the size comes to play is when you drop it. As far as structural integrity, VMR wheels in general are pretty durable, I have yet to see anyone on this forum with a cracked rim. There are issues with the quality of the rim as most of us have flaking problems. As a owner of the product you are getting I suggest you either get a different set of wheels other then from VMR or if you do be prepared to have to refinish them in less then 6 months.My 0.02
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    - E46 M3
    Kutztown, PA
    Go 19 with a 40 sidewall and you'll be fine.
    -Kris
    Jul 02 2007
    Santa Monica
    Quote Originally Posted by 3.2some View Post
    Yeah man, no decision yet....I know. Those wheels have actually been out of stock everywhere for the last month, so Ive just been doing research trying to decide on whether to get 19s and lower it, get 18s and leave the sport suspension, get 19s and leave the sport suspension, etc.
    I saw 19s on the stock sport suspension with 245/35/19 tires and it looked pretty good. I think IceMole sent me that link a while back. The 40 profile tires in 19" are hard to come by and are very expensive comparatively, so I probably wont go that route.
    Dec 19 2007
    Escondido, CA
    Quote Originally Posted by ekaufman View Post
    Either way you should lower it bro, it makes the car look 100 times better. No matter what size you get, that wheel gap is still gonna be there, and that's what hinders the overall apearance of the car the most imo.
    V/R -Phil
    Oct 09 2007
    - E46 M3
    Kutztown, PA
    yep 245/35/19 on sport
    -Kris
    Jul 02 2007
    Santa Monica
    I think that looks pretty good being on the stock sport suspension. The gap looks good. It has a clean sporty-stock look to it.
    Looks like he has those Eagle DS3 or what ever they are called, which have a pretty curved side wall as well.
    Senior Member Four Rings AudiWxGuy's Avatar
    Nov 12 2007
    Quartz Gray 2007 A42.0TQ 6MT
    Grand Junction, CO
    It doesn't look as bad on the sport suspension, but if you want it to really stand out, you need to lower it. I have the stock 17's on street sport coils and let me tell you, the car looks 100x's better. From the front, it looks soo much more aggresive and awesome.
    2007 A4 2.0T 6MT Quattro -- Quartz Gray
    Mods:
    RNS-E/STaSIS Exhaust/GIAC-X/STaSIS Street Sport Coil Overs/15mm Rear/Umnitza LED Angel Eyes/Ziza LED Citylights/CC Mod/Hoen Fogs/Ashtray iPhone Dock/
    RS4 Rear Sway/Blackout Grill with Black Filler/Clear Bra/18" OZ Superturismo & 225/40/ZR18 FK452's....(0-60 in 5.85s)
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Quote Originally Posted by IceMole View Post
    That's a bad advice, because in order to keep the same overall diameter on the 19" combo (wheel+tire), you need the 35 aspect ratio, which means 35% of the 245 section width. If you go with 40 aspect ratio, your overall diameter will be larger than the car was designed for, resulting in decreased performance (acceleration) and speedometer/odometer inaccuracy.
    eleven S4 prestige • ibis white/black nappa/cf • drive select • side assist • alu-optic
    Oct 09 2007
    - E46 M3
    Kutztown, PA
    KDW2
    -Kris
    Oct 09 2007
    - E46 M3
    Kutztown, PA
    Quote Originally Posted by ibiski View Post
    He would run a 235/40/19....resulting in a .3" higher sidewall (which he is looking for) 2.5% difference making his speedo 1mph off @ 60mph which can be vaged.
    -Kris
    May 21 2008
    The difference would be half an inch (overall increase of 1" in diameter over stock), which I think is significant, but best bet would be to consult a tire tech.
    May 21 2008
    BTW, that sport suspension doesn't look bad
    Jul 02 2007
    Santa Monica
    Here are some pics of 18" RS4 reps on the stock sport suspension, which I think looks pretty good:
    Oct 09 2007
    - E46 M3
    Kutztown, PA
    It's 2.5% which is perfectly fine and has been done... you need to go talk to the slammed guys about running rubberband tires, stretch, and poke and how that's not factory either.
    Eric: take the safer/cheaper way and go 18s
    -Kris
    Jun 14 2005
    Irvine, CA
    All of our VMR Wheels have been strength tested and have met/exceeded the their test results of JWL & VIA. We WILL NOT release any wheels to the public if they have a possibility of injuring someone. Our wheels have also been track tested not just daily driven!
    Comparing sidewall height w/ 235/40/18 to a 235/35/19:
    18"
    Sidewall Height: 3.70 in 93.98 mm
    19"
    Sidewall Height: 3.23 in 82.042 mm
    Sidewall height is 11.93 mm shorter on a 235/35/19 from a 235/40/18 tire.
    -Charles@VMRWheels
    www.vmrwheels.com
    JB @ VMR | Wheels
    (714) 442-7916 ext. 108 | jb@velocitymotoring.com
    www.velocitymotoring.com | | | Blog
    Jul 02 2007
    Santa Monica
    Going with a 245/35/19 tire the side wall = 3.38" (85.75mm)
    Thats only 0.32" (8.23mm) different than the 18" side wall. I cant imagine thats much of a ride difference.
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    I agree, i have had my onyx black for about a year or less and every wheel is peeling badly. I have yet to get any help from vmr about the problem. Very disapointed
    Hot Photos<--Click Here
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG
    2012 S4, Monsoon Gray, 6MT
    www.AskMy2Cents.com
    Jul 02 2007
    Santa Monica
    Is there any sort of finish warranty from Velocity on these wheels?
    Jan 16 2008
    Ohio and GTA
    im honestly not sure, but i know that they know about this problem. It would be nice if they helped out previous buyers, to get (at a large discount) another set of wheels and ship our defective ones back. The main problem I am having is that no one here can match the finish, they have already tried on one spoke and it sticks out like a sore thumb. I would recommend getting gunmetal to avoid this problem
    www.AskMy2Cents.com
    Oct 09 2007
    - E46 M3
    Kutztown, PA
    I think there are 2 versions of this wheel, do you have v1?
    -Kris
    Jun 14 2005
    Irvine, CA
    Our V708 v.1's are discontinued. We opted for a better concavity in our wheel design on our v.2's
    -Charles@VMRWheels
    www.vmrwheels.com
    JB @ VMR | Wheels
    Active Member Two Rings FLAudiMotion's Avatar
    Apr 11 2008
    2006 A4 2.0TQ
    Melbourne, FL
    **WHAT?!!** OMG a hot chick that knows something about cars!!
    **Ring!!** Hell just called...something about ski slopes opening up...
    Senior Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by nick71692 View Post
    the gunmetal wheels are also painted. how would this alleviate the problem? wouldn't they also flake? I'm also surprised that these wheels are painted, and not powder coated.
    can anyone confirm if their hyper silver wheels are also painted?
    -Jay
    2006 Brilliant Red 2.0T Quattro
    Is your B7 2.0T giving you issues? Have you checked your cam follower recently?
    This happened to me after only 20,000 miles:
    http://www.audizine.com/forum/showth...ry-and-no-CELs
    Jun 14 2005
    Irvine, CA
    Hi,
    Our wheels have painted finishes, not powder coated. Our painted finishes are still VERY durable compared to powder coat. We have had customers daily driving on our wheels for over 2+ years without a problem.
    -Charles@VMRWheels
    www.vmrwheels.com
    JB @ VMR | Wheels
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by VMRWheels View Post
    Hi,
    -Charles@VMRWheels
    www.vmrwheels.com
    Thanks for the info. Is the "hyper silver" an alloy finish? or is it painted?
    -Jay
    May 18 2008
    tn
    Jun 14 2005
    Irvine, CA
    Quote Originally Posted by p1nk50ck View Post
    Painted finish.
    -Charles@VMRWheels
    www.vmrwheels.com
    JB @ VMR | Wheels
    Senior Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Quote Originally Posted by FLAudiMotion View Post
    WHAT?!?!?!?!?!?
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Jun 02 2009
    Santiago, Chile
    Sorry to bring this old post back....
    What happens after those two years.....??
    Hi,
    -Charles@VMRWheels
    www.vmrwheels.com
    Thanks and regards!
    MO
    Senior Member Four Rings pw211's Avatar
    Dec 14 2008
    C55 AMG, 90 Passat
    Louisville
    wait I thought icemole's avatar was just a picture of a hot chick and he was a guy.. .Is it a picture of icemole???!?!?
    Pat
    ///AMG
    F.T.W.L.T.B.D.W.I.C.T.W
    "Stop being so butt hurt" -eskimopunk
    "Gary Coleman's brain cells have more stretch than that set up" -Checho
    "I have a carriage drawn by 780 horses, Clydesdale's to be exact. yeah it boogies." - Dangler
    "i wish my cat could drive my audi" - Mc Suly
    "put a quattro badge back on it.....you have awd drive now....or maybe you have fwd...idk" - mr shickadancei
    Senior Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    I live in socal and I've got the 18's. Roads are pretty bad in some places but still, I like having a safer peace of mind.
    Here's how they look on Bilstein PSS9's:
    Tires are 235 40ZR18. I'm pretty low but I don't rub one bit. Ran over a few LA potholes before and I didn't die. Reason why I didn't want the 19's is because of the extra weight, cost of tires, and rotational mass.
    I even got hit in my passenger side front, and it still held up well.
    pic of the hit & run damage:
    18's will be better if you ever go on any track events or auto-x.
