Page 4 of 4 FirstFirst ... 234
Results 121 to 159 of 159
  1. #121
    Feb 27 2005
    North Wales, PA
    self necro bump
    still have to tig up the waste gate dump and the FMIC tubes. Getting closer. haha
    2001 A4 Avant 1.8t - Gt30r coming soon
    2002 TT 225 6spd. - Daily Driver
  2. #122
    Senior Member Four Rings Seerlah's Avatar
    Dec 05 2007
    Just re-read this thread. So, engine is already built and you recently picked up the ME7 Suite? Didn't you say you had 225 TT pistons (can't recall engine code)? Or did you mean you had those in an actual 225 TT?
    And 2008? lol
    I hate it when my car acts like a little bitch, treating me like the bitch
    FS:Brand New K&N Air Filter RU-3700 (3" inlet, 5" base, 4" tall, 4 5/8" top), Brand New 3" Injen (Amsoil) Dry Filter Setup with Heat Shield, Brand New OEM 06A Oil Pump, Used Greddy Intercooler...throw me some offers
  3. #123
    Feb 27 2005
    North Wales, PA
    Hahaha yeah well I don't have a garage in Philly so I only work on it when I go back to my parents. Running 8.5:1 je pistons now. I built the engine after my sedan was totaled and I couldnt settle on a tune. At first I was going back to a standard tapp ots tune but I really wanted to squeeze the most out of the setup so I began inquiring about local Dyno tunes. Then people started getting into maestro and the support for it grew. I also bought a tig welder so I started fabbing my own things then all of a sudden it's 3 years later. I also had an e30 somewhere in between.
  4. #124
    Dec 05 2007
    You wouldn't happen to still have those old TT pistions laying around, would you?
  5. #125
    Feb 27 2005
    North Wales, PA
    nope don't have them anymore. i got them off ebay. in reality after you spend money on new rings and refurbing the pistons, you are better of just getting some mahle's
  6. #126
    Dec 05 2007
    I picked up AEB pistons and Brute rods for $500 shipped. But if you had the TT pistons, I would have resold these AEBs and used yours with the 9:1 CR. Trying to keep my build on a budget, and can't afford fancy pistons .
    And what do you mean by refurbishing the pistons? I was just planning on throwing them in a bucket of degreaser dilluted with water, and going at them with a brush. Is this not a good idea?
  7. #127
    Feb 27 2005
    North Wales, PA
    I would be careful of what solvent you use cause I had a set of awm pistons sitting in degreaser and the coating on the skirt fell apart. You should be fine though if you don't leave degreaser on them too long. I had mine diluted 1:1. Just clean the gunk off and out of the ring grooves. They are gonna get dirty in the motor anyways.
  8. #128
    Dec 05 2007
    Thanks for that. I would have never gave it one thought. And since you gave me a fair warning, did a little Google searching. What's your opinion on Piston Kleen? Sorry if my questions are bothersome .
    http://www.orisonmarketing.com/clean...on/carbon.html
    And to keep the thread on topic: Do you plan to tune yourself or have a professional do it?
  9. #129
    Feb 27 2005
    North Wales, PA
    I used oil eater for a lot of stuff. I used this industrial engine degreaser on the pistons. It's potent stuff.
    I plan on getting the car running on the base file from tapp and tweaking from there. I'll be playing with maf and mafless set ups. I'm just wondering if I can run a bov on the maf set up. I'm not sure how it will react losing metered air. I'll have to see what the b6 guys are doing.
  10. #130
    Dec 05 2007
    Why not just recirculate it, if running a MAF? If you feel the Forge units are not large enough, Tial makes a recirculating valve. And I think the Synapse one can be changed from vent to recirculating.
  11. #131
    Feb 27 2005
    North Wales, PA
    I just don't want to fab the intake and have plumbing running all over the place. It's tight with the atp manifold.
  12. #132
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;05 USP; Cannondale CAAD9
    Austin/DFW, TX
    Id love to hear how a Mafless tune works out for you, and how much different it is tuning the AWM vs. the AEB (which seems to be the majority of the B5 Maestro users).
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
  13. #133
    Feb 27 2005
    North Wales, PA
    awm gets to enjoy quick tune where you can make quick adjustments to idle, rev, etc. does the aeb get 2step launch control? I'm not sure
    anyway, i made my oil feed line at work since i lost mine/gave it away. 38" of 200 series -4an stainless braid line with 200 series A-1 -4an hose ends. I should do a write up on how to assemble these guys.
  14. #134
    Dec 05 2007
    A tip to avoid getting poked would also be helpfull!
  15. #135
    Feb 27 2005
    North Wales, PA
    haha well there is a technique to cutting the hose. You can try cutting the braids very slow with a cutoff wheel. Or you can zip it as fast as possible and cooling it down in cool water. This prevents the inner layer of stainless braid to lift off the rubber. You can also use a sharp chisel and a hammer to slice through it over an aluminum block. This method sucks cause you oval the hose and its difficult to squeeze into the sleeve end of the fitting. Then just be careful or wear gloves.
  16. #136
    Feb 27 2005
    North Wales, PA
    i'm not sure if chris can get my ecyu registered on the weekend, so i'm gonna crank it over on the stock ecu to see if she fires up tomorrow.
  17. #137
    Feb 27 2005
    North Wales, PA
    no start =( could be back coilpacks or my cams are not timed up.
  18. #138
    Active Member Two Rings bmx_a4's Avatar
    Aug 19 2008
    Sheridan, WY
    Damn, that's disappoint!
    2000 Santorin A4 1.8TQM,
    Test pipe/turbo back exhaust/Eibach springs/clear corners/Single mass flywheel/APR Turbo Inlet Pipe
    Soon to come : IE Rods/JE pistons/FMIC/maybe even a turbo/wheels/get some head....work done
    I own a camera
  19. #139
    Feb 27 2005
    North Wales, PA
    i got my maestro base file. i think my cams our out of time. Gonna pull the valve cover off and readjust next weekend. I also need to replace my coilpack harness. I have many frayed wires. =(
  20. #140
    Dec 05 2007
    Sucks to hear. Is there any off the shelf solution for frayed injector harness wire repair?
  21. #141
    Feb 27 2005
    North Wales, PA
    i'm just gonna replace the entire coilpack harness. they are only about $50 bucks. I figured i would have tear into the harness anyways to find the issue.
  22. #142
    Dec 05 2007
    I was actually asking if there is a replacement injector harness repair kit
    But your way does sound easier. Just take a good one from an engine harness and solder the wires?
  23. #143
    Feb 27 2005
    North Wales, PA
    haha oh whoops. i completely skipped over that. The harness you can buy gets repinned into the factor harness. No soldering required. You just have to disassemble the whole thing. haha.
  24. #144
    Feb 27 2005
    North Wales, PA
    anyone have a cam tensioner tool?
  25. #145
    Active Member Three Rings SS92's Avatar
    Jul 11 2011
    Charlotte, NC
    Quote Originally Posted by Poopie View Post
    PM Me
    2000 B5 A4 1.8T ATW GT2871r, Unitronic/Maestro tune, RaceTec FMIC, etc... - > Stockpiling for BAT
  26. #146
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by SS92 View Post
    PM Me
    you inbox is full. pm me a price shipped you are looking for when you get it cleared out
  27. #147
    Feb 27 2005
    North Wales, PA
    pulled the valve cover and compared my cam positions and my intake cam is 180* off. EFF ME IN THE A
    think my valves are bent? They are revolver cams so the are a little bit higher lift.
  28. #148
    Senior Member Three Rings redline380's Avatar
    Oct 30 2008
    2000 Chevy 3500 454 w/9'2" boss vplow
    St. Cloud, Minnesota
    180 off? holy shit! who the hell timed that them? i could try to think abotu the motion in my head to see if your valves are bent but i dont wanna think that hard right now. im just gonna say im sure they are. if you dont wanna take the head off just re time them and compression test. but im sure they are bent to shit. when the piston wanted to compress, your cam was exhausting. not good.
    Thats the biggest black ass I've ever seen. And I like it
  29. #149
    Veteran Member Three Rings Aliel's Avatar
    Feb 26 2005
    '99 Audi A4 1.8TQM
    Tirana, Albania
    There could be a small chance that the valves are not bent. I've seen it before. I hope you get lucky.
  30. #150
    Feb 27 2005
    North Wales, PA
    i timed them. revolver cams did not come with timing marks. I must have fudged lining them up. ugh head is coming off next week.
  31. #151
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    Damn Poopie... I can't believe you haven't finished this thing yet.
  32. #152
    Feb 27 2005
    North Wales, PA
    you and me both. haha. i was busy with other projects. When you have a daily. these things take a lot longer. When my b5 sedan was my only ride, i had not choice but to bang out projects.
  33. #153
    Feb 27 2005
    North Wales, PA
    Pull my head after a failed compression check. 20 bent valves :(. Just ordered another set and gonna try again. I also think I found the cause of why I don't have spark to cylinder 1. I took apart the wiring harness and the blue signal pulled right out of the connector. Gonna replace the broken connector and crimp on a new connection. I also have to smooth out the little nicks from the valves kissing the pistons. I hope to be running next weekend!!
  34. #154
    Dec 05 2007
    How are your piston hats looking?
  35. #155
    Feb 27 2005
    North Wales, PA
    2 nicks on the tops from the exhaust valves and barely anything from the intake. some light sanding will take like 90% of it away.
    i just wanna hear the motor start and have the car move. i'm already planning to go 83mm pistons and stroke it next year.
    if the blue signal is really the culprit i'm ordering this kit right away.
    http://www.audizine.com/forum/showth...-Great-Product
  36. #156
    Dec 05 2007
    Wish they had a repair kit for the injectors.
  37. #157
    Feb 27 2005
    North Wales, PA
    Got my new valves today. Took a half day to tear apart the head. Assembled with new valves, fixed my coil pack wire and fired her up. She started for a brief 5 seconds! It stalled out but the battery is dead and possibly the starter has issues. I'll try and address them this weekend
  38. #158
    Feb 27 2005
    North Wales, PA
    I just had a thought. I think I mad have poor grounding to the engine mount. I cleaned it up and sprayed them silver and I don't think I sanded the grounding point making my starter seem to struggle. I'll give it a try tomorrow and see what happens. I'm so close!
  39. #159
    Feb 27 2005
    North Wales, PA
    turns out to be coil bind in my valvetrain. I had 034 valve springs that were made by Eurospec but they are only meant for stock cams. My revolver cams have too much lift. =( gonna throw on a stock AEB while the fancy one gets rebuilt correctly this time. Inching closer i guess. I'm gonna try and install new aeb head tomorrow night.
