Results 1 to 10 of 10
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    How to tell if you have bad check valve
    How do you know if you have a bad check valve, I've looked at all my check valves that I could see and they all look ok, no cracks or anything of that sort. Is there another way to tell. Same question goes for the gas cap as well. How would I know if I have a bad one.
    WTB K04 turbo ASAP
    http://etektuning.com
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: How to tell if you have bad check valve
    You can blow thru one way but not the other, it's good.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Do a boost leak test and that should tell you as well. Gas cap, not sure.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    Orlando, FL
    If you have a bad gas cap you should throw a cel.
    05 blk A4 1.8tQ 6spd
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 452's 235/35
    In Central FL, need B6/B7 suspension work/timing belt(1.8t) done? PM me.
    Sep 03 2007
    henderson, nv
    cool thanks
    WTB K04 turbo ASAP
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    the thermoset plastic will be crumbling away. this in turn gets stuck in say your N80 valve which then costs you a new check valve and n80 valve.
    I've got USP plastics $1.66 check valves all over my engine. works great.
    when i pulled the check valve off before the N80 purge valve you could see the end of the nipple facing the valve had a small chunk missing. of course i could never get it out of the n80 valve :(
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Dec 06 2007
    Items for Sale
    sorry for the thread jack, but how would u know ur n80 is bad??
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    Quote Originally Posted by A4TL View Post
    sorry to jack thread but where did you find that?
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Which of the following is the appropriate size?
    http://www.usplastic.com/catalog/pro...uct%5Fid=15641
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Nov 06 2006
    335is
    atlanta
    well there are actually a few different sizes :) and at lease one is a multi-function valve which would require two check valves .
    I just bought a handful of them because they come in handy.
    n80 is easy to check..
    i used a 9.6 to 12V power supply with the bare wire (cut the end off) .
    when there is no power you can not blow/suck anything through the. tight seal.
    then you apply the power (don't worry about neg/positive you'll get it right). and it shold flow smoothly in both directions.
    there's even a screwdriver to adjust it but i strongly suggest you don't do that unless you know what you are doing.
    feel free to clean it. i tried everything on the planet but mine was jammed open a little and no matter what it was leaking air with no power; thus evap leak , mushy brakes, poor mpg, hard starts,etc.
    there's a big pump in the back of the car that creates alot of vacuum. if you have the desire, replace the N80 with a straw (cut it down) and you'll see misfires galore and a sputtering engine. There's enough vacuum coming from the back of the car to stall the motor if the n80 malfunctioned and flowed 100%.
    the n80 goes down the wheel well then back the rear of the car where this vacuum pump is located.
    automatic cars have another pump of course in the engine bay. i assumed it was for brake assist or something like that.
