Page 1 of 3 123 LastLast
Results 1 to 40 of 95
    Stage 2 Banner Advertiser Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Putting the engine back together
    So after waiting a few weeks for the parts to come in it is finally time to put it all back together again.
    Here are the new custom JE 83.0mm JE pistons 8.75:1 CR with coated skirts and dome
    After rings were gapped and installed they were put into the block
    The new rebuilt head with Supertech valves, springs and retainers
    Powdercoated AGN cover
    And some bling hardware
    iPhone 4/4S Vapor aluminum case sale! $40 shipped! -> click here for details
    Senior Member Three Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    2004.5 B6 Audi A4 1.8tqm
    Torrington, CT
    Re: Putting the engine back together
    cant wait for the fire up
    Registered Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    wow, nice work!
    Winston, did you get my pm ?
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth
    E46 M3 TiAg/IR Moton/GC Track Ready
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed
    E39 540iA Aggressor
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package
    Porsche 944 NA
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Looks great!
    The few engines I have rebuilt I have SMOTHERED the camshaft(s) in Moly lube, lol
    -Sami-
    Senior Member Four Rings Overboostin's Avatar
    Mar 15 2007
    E-One HP 100 Ladder Truck, GMC Ambulance, F-350 Powerstroke
    New England
    well done good sir
    the homebrew'd s4
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    Fast Audi sedan, Slow Subie wagon
    SL,UT
    i was gone for a bit. but why is your engine apart? what happened?
    im searching
    alright, found that you had pretty bad pressure leakage. but what was the main problem of this? did you indeed bend a valve(s)? or was it your rings?
    Nov 03 2004
    2002 audi a4 1.8t
    va
    now thats how to build a motor!!!!!!
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    So you did go with head studs?
    Still the 86.4mm AMB crank?
    Looks good Winston!
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Jan 25 2006
    Audi S4 2.7T, A4 2.0T
    MD
    From bent exhaust valve to complete rebuild?
    Sep 17 2006
    SL,UT
    umm.... looks like it to me
    Dec 03 2005
    connecticut
    Quote Originally Posted by Don Supreme View Post
    I believe the valves damaged the tops of the pistons beyond repairable.
    Quote Originally Posted by sean1.8t View Post
    Thanks Sean. Maybe I did point out the obvious about the studs but I recall reading a few threads he made here and on vortex about studs. My consensus was you don't need 'em..
    -Doug
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Lets hope this one stays together! What exactly happened to the last one?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Supertech makes really good valvetrain parts. Had it in my Honda and i use to rev the piss out of that car never dropped a valve.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Senior Member Four Rings mtbrider's Avatar
    Oct 31 2005
    A4 GT2871R
    Virginia
    very nice
    BetaAlphaTau member #5
    Meth Injected Built Bottom Fun
    ~Josh~
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Correct, the stock head bolts are good for well over 800hp and even pushing 32psi on a 8.5:1 CR.
    Winston make sure to check your CR once your car is running, I would expect the pistons to have a dish being 83mm and 8.75:1 CR. Even my JE's have some dish and they are 83.5mm 8.5:1. Nearly everyone that got flat top JE's like that said they were 9.5:1.
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Quote Originally Posted by dirtybrd View Post
    OEM exhaust valves
    - Clint
    New Ride: White '04 S4 2.7T - Already Stage 2
    Mar 21 2006
    Lakeland, FL.
    Winston, I assume you fully built the head this time so it can be ran up to 8500rpm and take full advantage of the turbo? Please say you did!
    I'm back bitches!
    Registered Member Four Rings A4ringedONE8T's Avatar
    Feb 17 2005
    Sarasota, FL
    Is this build on the shops wallet or yours?
    Jun 11 2005
    Vancouver, BC
    im searching
    What happened? Well grab a seat and here we go...
    About 8 weeks ago we were tuning the car and adjusting the settings of the new Profec EBC I installed. We dialled the EBC to hit 26psi and the Avant was just flying down the highway. Did a few VAG logs to make sure everything looked good and it did, AFR was at 11.9 at max boost.
    When the car reached 26psi for the 3rd time it threw a CEL and an audible rattle started. When we VAG the car there was about 10 codes and one of them was for the cam chain tenstioner failing so we thought it was the chain itself rattling against the cover.
    So we replaced that with a spare unit from my old head and the rattle was still there. So we decided to replace the lifters but the noise was still there.
    We had a dyno day set the next week so we took the car to Rocket Rally and set it up but we didn't like what we were seeing and hearing. There was just monsterous venting from the catch can so we decided to shut it all down and limp the car back to the shop. That is when we did a leakdown test and found cylinder 4 to be losing 70% and there was hissing out of the exhaust side. So that pointed towards damaged valves... so I ordered the Supertech parts. When the parts arrived we pulled the head off and this is what we saw in cylinder 4
    This is how it looked new
    Now before anyone starts up with any conspiracy theories let me state that there were 3 of us in the car that day when we were doing the tuning. One person was on the VAG, one person was adjusting the EBC and monitoring the AFR and I was driving. The car pulled like a bat out of hell and there were no audible noises, no pinging, nothing heard by any of us that would have indicated that something like this was going to happen
    So what exactly caused that chunk of the piston to blast off? No idea. Could have been detonation, could have been a manufacturer defect, the piston might have been dropped by the person I bought them from. No idea.
    There was no damage at all to the cylinder #4 wall, a tiny bit of marking of the head and a bunch of burned exhaust valves. There was no damage to the other pistons or the turbo blades.
    So to fix the marks on the head Bob decided to smooth things out a bit
    So I ordered a new set of pistons made to the same size specifications as the old set but with a modified valve relief design, lower compression ratio and the dome coating as you see now.
    It's been 5 weeks of downtime now since dyno day with 4 weeks of that waiting for parts to arrive. Car will be back on the road next week and I start breaking the new rings in again.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    Cars being worked on
    Fort Collins, CO
    WORD WINSTON!!! I'm stoked for you. Hope all goes well. How are you gonna break it in?
    Jun 11 2005
    Vancouver, BC
    Looks good Winston!
    I went with the Raceware head studs the first time around.
    Still the 86.4mm crank. Decided to leave the setup at 1.9L as pulling out the engine to do all the work to go 2.0L just wasn't cost effective at this point in time.
    Jun 11 2005
    Vancouver, BC
    Well there is some dish to the dome, it is just hard to photograph with my crappy cell phone at the time.
    I'll have them check the CR when it is all buttoned up to confirm that everything is correct.
    Jun 11 2005
    Vancouver, BC
    Head is fully built at this time to take advantage of the 8500rpm file or upgraded CAMs in the future.
    I really shouldn't have called it a build but the part replacement is on my dollar.
    Feb 12 2004
    Fort Collins, CO
    Piston design is just one factor in determining true mechanical compression ratio.
    Jun 11 2005
    Vancouver, BC
    Quote Originally Posted by CO AVANT View Post
    How? Driving like a granny and keeping it out of high boost for 1000km to seat the rings.
    I have VAG logs of the old setup so I'm going to do the same runs with the new setup and see of any of the CF change due to the dome coating and smoothing out of the head.
    Feb 12 2004
    Fort Collins, CO
    Check this thread on engine break-in Winston...
    http://www.audigeeks.com/forums/index.php?topic=1785.0
    Jun 11 2005
    Vancouver, BC
    Thanks for the info and I read that thread when I broke the rings in the first time.
    I do plan to break it in the same way the second time, vary the RPM levels, blip it every so often to speed it up, use a bit of engine braking to slow the car down and I'm told this, etc. as advised in the writeup.
    Guess my version of Granny driving is different than yours.
    Mar 21 2006
    Lakeland, FL.
    What octane do you have up there, 98 correct? I'm thinking 26psi. on pump might be to much and burned the valves/piston. During tuning I've burned 2 spark plugs, that might have been valves if they weren't Ferrera's.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    The TT we just delivered today we setup for 25psi on pump gas, no meth, using Tapp software. Ran great CF's in the 5-6 range. On T4 or T5 26psi should have been fine with the REVO
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    That is sick MC nice job
    <<NO SIG>>
    Jun 11 2005
    Vancouver, BC
    We have 94 octane here but from what I am told it's crap compared to the gas on the East Coast.
    What happened at 26psi last time I do not know. I'm hoping to do better this second time around.
    Veteran Member Four Rings Issam@INA's Avatar
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Nice valve cover Winston.
    INA Engineering Inc.
    APR distributor FOR OTTAWA | HULL | GATINEAU | HULL | KINGSTON
    THE NEW VR6 B5/B6 FAQ
    Email US | Facebook US | Call US : +1.510.275.4775
    Mar 21 2006
    Lakeland, FL.
    I can only run 25psi on T5 on 93 w/WI. I was 22psi before the cams, so I think you're running to much boost.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    That doesnt make sense, I run 27 on T6 with 93 and meth everyday and dont get above 4-5 CF's
    Jul 07 2004
    socal
    Quote Originally Posted by A4ringedONE8T View Post
    IIRC you also run a 90% meth mix, correct? So why try to even compare that to people running a normal meth mix?
    Feb 17 2005
    Sarasota, FL
    Was for a bit but been back to the straight blue stuff for awhile now. The meth held up for about 3 weeks then I got sick of having to go pick it up. Ran the same shit with either though, the meth just dropped my CF's to 1-2's rather than 4-5's
    Messing with a C6 Z06 on the highway yesterday, about 92 degrees out, straight blue washer fluid 1.19/gallon from Walmart was peaking 27.8psi and running strong
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '02 A4 1.8TQT // '05 MV Agusta F4-1000
    Mo County, MD
    What were the results messing with that Z06. Just curious.
    Audizine's most powerful & most respected B6 Tip
    Previous: 283.4 awhp - 287.1 ft-lbs. | 93 octane
    UPDATE New build in progress
    Jul 07 2004
    socal
    What were you running at the track for those 14's?
    What does your CF's look like pushing that much boost without the meth?
    Mar 21 2006
    Lakeland, FL.
    I run straight water and at the track I ran 27psi and T6 and got audible detenation at the top end of the track. So I stay 25psi and T5 just to be safe.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    Blue stuff at the track too, the meth is always on so I couldnt tell you what it would do without it. Definitely wouldnt be able to run that much boost on straight 93 without high CF's and timing pull
