Results 1 to 40 of 45
    Forum Moderator Four Rings biketsai's Avatar
    Jun 04 2007
    01' A4 1.8TQM;05 USP; Cannondale CAAD9
    Austin/DFW, TX
    DIY S4 sideskirt install
    Well I decided to make a separate thread in case someone wanted to refer to this...
    I did the S4 sideskirt conversion with sideskirts I got from a junkyard.
    I also utilized my stock door molding as well.
    Install time about 30-60 mins
    Ill try to make this a DIY/reference thread.
    What you do need...
    S4 skirts
    (2) S4 mounting brackets
    Razor blade ( to cut door molding)
    Flathead screw driver (to remove door molding)
    T25 Torx bit
    Industrial Strength Velcro, long enough to go cover most of the skirt.
    I started off with this.
    washed them and ripped the "clear bra" stuff off(it takes time, and DO take your time with this and slowly peel, paint thinner did help remove the goo)
    Then I painted them =].
    Then I went and got my razor blade and measured 1/2" on each door molding, traced the line then sliced through it like butter with teh razor blade.
    For the end pieces of the door molding that are not on the door itself, I used a hacksaw/dremel to cut them.
    I then cut these small tabs off.
    Then, remove the 2 Torx bits on the front of the skirt, and the 4 on the rear...then bolt the s4 brackets in.
    Clean off the side of the door sill that is now visible because you cut the door molding off, that is where the Velcro will go.
    Lay a long strip down on each side, and have it placed corresponding to the skirt.It helps to have it somewhere in between the middle of the skirt to the top.
    Then lay the skirt on and have a buddy help you.
    Use the old 2 bolts from front for the front of the skirt, and bolt the rear on with the extra Torx screw left over from removing the stock one.
    And basically, your done!
    Things will make sense as you go along.
    I didnt use any screws for the bottom because it felt strong enough, but if you want, just drill some holes into the bottom of the car.
    I will probably upgrade to the s4 door moldings here in the near future.
    But this will work for the next couple of weeks
    If you have any questions, PM me or post here.
    -chris
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Four Rings Overboostin's Avatar
    Mar 15 2007
    E-One HP 100 Ladder Truck, GMC Ambulance, F-350 Powerstroke
    New England
    Re: My S4 sideskirt install
    nice job!
    the homebrew'd s4
    Senior Member Two Rings NK2007's Avatar
    Mar 25 2008
    2000 Audi A4
    Ft. Collins & Colorado Springs
    looks good! bookmarked for when i get my s4 sides.
    |00 A4 TQM|K04|Revolver Cams|Greddy FMIC|Custom GIAC|Full Custom Exhaust|OEM RS4|S4 Rear|S4 Interior|HID|
    More to come!
    F.S. Rieger Side Skirts in Silver- will trade for S4
    Senior Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    nice install. how much did the whole setup cost?
    Sep 21 2007
    DeSoto, TX
    Man, that is a nice job.
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    very nice man
    1998 Audi A4 built 1.8t Quattro--Eurodyne Maestro---870cc tune---Custom Elim Gt3076---on E85 Gas---044 Bosch Drop in fuel pump---Street tuned by me---402awhp 387tq---12.2@118mph on 19" wheels
    2003 Audi Avant 1.8t Quattro 5speed--19" Staggered iForged Daytona Wheels
    Active Member Two Rings AudiLife's Avatar
    Nov 20 2005
    B5 A4 1.8T QM
    Nice Job! I'll be doing this in the near future and this helps alot. Do you have or can you get a picture of how the skirts match up with the existing door sill? Did you just put Velcro on top of the old sills?
    TIA!
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    01.5 A4 1.8T and 06 VW Passat 2.0T
    Orlando, FL
    nice job man! gonna try and get mine on next week
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HIDs|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Jun 04 2007
    Austin/DFW, TX
    It cost me about $200
    $30 paint, 15 velcro, 150 skirts with brackets.
    Audilife, i will try to get a picture soon
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Can that lower door molding be painted or do you have to buy the S4 lower door molding? I have a Satorin car and they need to be painted that color.
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    the rubber can be painted, there is a lot of prep work involved. and you need to use a flex agent.
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Veteran Member Three Rings Russell2686's Avatar
    Sep 17 2006
    07 cbr600
    nice work man
    50% off all clothing and accessories at www.true-feel.com Use promo code: SoGood
    Oct 20 2007
    Quote Originally Posted by goody6691 View Post
    Money wise do you think I would be better off painting the stock lowers moldings or get s4 moldings and paint those?
    Thanks for the help.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    2000 A4
    Beantown
    did you paint those sides urself? What did you use?
    2000 Audi A4 ** 4.2L 40v S6/S8 swap in progress
    2005 Audi A4 1.8T 6spd - K04'd -- *******FOR SALE http://forums.vwvortex.com/showthrea...p-K04-USP-mods******
    Oct 08 2005
    Orlando, FL
    I did the samething biketsai did for now, im gonna just shave the door molding.
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 03 2005
    Needs a heater
    530, California
    Quote Originally Posted by biketsai View Post
    Where did you get skirts and brackets for $150?
    02 A4 3.0Q, Sport, Eibach
    99 A6 Avant-Deer Fodder
    01.5 A4 TQMS, DV, K&N, Snub, exhaust, SB STG III, GIAC 1.3/1.5-SOLD
    Oct 08 2005
    Orlando, FL
    ^ Local junkyard
    Senior Member Two Rings jman8806's Avatar
    Jul 23 2007
    99.5 b5 1.8tm, 1986 nissan z31
    Vegas
    good job
    1999.5 audi b5 1.8tm
    [euroBREED]LV
    www.twitter.com/jman8806
    Jun 04 2007
    Austin/DFW, TX
    yea, i def cant wait to get the s4 door molding!
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Three Rings kevin12's Avatar
    Jun 20 2007
    2001.5 A4 1.8TQ
    South Jersey
    Quote Originally Posted by JumboBlack1.8 View Post
    Yeahhh I'm curious about this too. Did you use cans or do you have a spray gun?
    Old: 99.5 Laser Red A4 2.8Q Tip Totaled RIP
    Current: 01.5 Casa White A4 1.8TQ
    Uni 1+, Intake w/ Blinktek HS, ST Coilovers, Hyperboost DV
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by kevin12 View Post
    spray gun, booth, etc
    My 5-Speed Swap DIY
    - B6 USP
    Feb 23 2005
    Quote Originally Posted by VTAudiA4 View Post
    wait for the s4 parts. i never painted my stock parts and when i was getting work done the s4 parts were not in the budget. im kicking myself now for not doing it.
    Dave
    Jun 04 2007
    Austin/DFW, TX
    yea you def need to get some. although it gives your car a little bumble bee taste, lol jk.
    My 5-Speed Swap DIY
    - B6 USP
    Oct 20 2007
    Anyone ever buy lower door moldings from this site?
    http://www.blauparts.com/proddetail.asp?prod=B3B1204-B
    Active Member Two Rings audinutt's Avatar
    Jan 11 2007
    texas
    Can you mount the skirts without the brackets? i've got a pair my same color but have no brackets.
    -richard
    98.5 A4 1.8T
    Jun 04 2007
    Austin/DFW, TX
    yes you can Richard, but its a tight fit
    My 5-Speed Swap DIY
    - B6 USP
    Feb 23 2005
    i have lots of plans, none of wich will include any bumble beeism's. lots of things are in the works, body, paint, stereo, etc.
    Dave
    Jun 20 2007
    2001.5 A4 1.8TQ
    South Jersey
    Yeahhh that's what I figured looked way to good to be rattle cans ha
    But looks great man really turned out well can't wait til I get myself a set
    Senior Member Four Rings audiFUEGO's Avatar
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    chris do you have any pics of your doors open? like a closeup of the sills?
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by audiFUEGO View Post
    Sorry no pics ATM. I can take some tomorrow when I get home. They literally just sit and overlap the stock stuff.
    My 5-Speed Swap DIY
    - B6 USP
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    Ok so then you definitely didn't remove your sills like the writeup on AW.
    I feel like since I'm shaving the doors, I have to remove the sills to make the skirts more flush. Otherwise it looks like the skirts are stretched out and well look...
    Even with the door closed you can still see the 1mm lip that the skirt has over the sills. Maybe the shop can epoxy those for me or maybe I have to remove my sills?? I hope not.
    Registered Member Two Rings PuntA4's Avatar
    Apr 14 2010
    1989 Camaro
    Michigan
    biketsai, what kind of suspension do you have on there?
    1997 Audi A4 Quattro 1.8T
    GIAC Chip | 2.5" Borla Exhaust | RS4 Bumper | Front Mount Intercooler | Short Throw | Stage 2 Clutch | Boost Control | Crystal Clear Corner Mod
    Want to Buy: Rims (BBS RX8 Style), S4 Tail Lights (No Amber), Springs
    Jun 04 2007
    Austin/DFW, TX
    in that pic it was H&R PCS
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Two Rings audienthusiest's Avatar
    Apr 06 2008
    nada
    CALI
    off topic... wats the et on those rs4 reps....?? ps... your car looks AWSOME (im doin this as soon as im home from college =P)
    Apr 14 2010
    1989 Camaro
    Michigan
    how much of a drop is it? and about how much did that run?
    Jun 04 2007
    Austin/DFW, TX
    ET is 35 on the wheels. The drop, Im not sure, maybe 2.5 inches? I paid around $1000 for coilovers.
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Four Rings wesleyfbm's Avatar
    Aug 25 2008
    the 01 a4 tttt and my BMXer
    rhode island
    Back from the dead..and I have questions.
    So do I really need the S4 mounting brackets? And what about the bottom of the skirts, there are larger holes idk if anyone attached from the bottom at all?
    Jun 04 2007
    Austin/DFW, TX
    You really "dont" need them, however I highly recommend them for a nice finished look. What my friend recommended to do a long time ago was to just push the sideskirt over the rubber A4 bracket and screw it in with a wood screw (sounds a little ghetto though). On the bottom for a while I did not have them attached to any of those holes. Eventually I just removed the stock A4 rubber caps and fitted them over the holes on the sideskirts if that makes sense. Lmk if you have any more questions.
    Chris
    My 5-Speed Swap DIY
    - B6 USP
    Aug 25 2008
    rhode island
    Yah that helps. thanks Chris.
    Senior Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Facelift 1.8t
    Tampa
    You gots a PM Chris :)
