Results 1 to 13 of 13
    Senior Member Three Rings auditi's Avatar
    Nov 19 2007
    Martinez, CA
    Arrow blinkers not working, hazards and parking lights do...
    as the title states, my blinkers stopped working, but the lights are not out, as they work when the hazards are on and the parking lights work. the cruise control still works too. also, the blinker stock does hold still hold its position during turns and releases when it is supposed to, the blinkers front and rear just aren't working.... what could this be?
    -'05 B6 A4 1.8T Quattro USP - Arctic White/Black, 6MT, unk chip, S4 brakes/SS lines, S4 grille, tint, PODI gauge, forge dv, Bose w/ Aux & Sub
    --USP Club Member #212
    -'59 VW Bus
    -'69 VW Bug
    -'01.5 B5 A4 1.8TQMS - Silver/Black, tint, M3 lip spoiler, Bose+sub, 1.3 bar custom Neuspeed p-chip, Evo MS CAI, 710n, H&R sports, S4 shocks, short shift, 19mm Neuspeed RSB, poly snub, Blitz dtt w/ red led's - sold
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: blinkers not working, hazards and parking lights do...
    could be a fuse.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Back from the dead
    Nov 19 2007
    Martinez, CA
    i don't think it could be that cuz, as i forgot to mention above, when i hit the signal lever up or down, the appropriate signal on the dash (maybe on the outside too), lights up for one blink or less. its worth checking though....
    -'59 VW Bus
    -'69 VW Bug
    Active Member One Ring diode's Avatar
    Jan 14 2008
    98.5 A4
    Calgary
    hazard relay switch ftl.
    Nov 19 2007
    Martinez, CA
    could it still be the hazard relay if the hazards are working, just not the turn signals?
    -'59 VW Bus
    -'69 VW Bug
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by auditi View Post
    yes thats what it is. it was the first thing i had to fix when i got my car haha
    Apr 18 2008
    08 A4 2.0TQMS, 87 16v Scirocco, 01 NB TDI, 01 4Runner, 00 BMW K1200RS
    Palm Coast, FL
    Just bought my '01 a4 quattro a week ago... this is also one of the same problems I'm seeing... along with a bunch of much more expensive ones. (but the car was dirt cheap)
    I assume this relay is in the dash near the hazard switch, right?
    Jan 14 2008
    98.5 A4
    Calgary
    the hazard lights button is the relay switch, it's a rectangular box. Pop the whole thing out, it's not too tough.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    get a wiring diagram, throwing parts at it is just a waste of money. It could still be the turn signal switch(the lever assembly). Just b/c it resets after recentering the steering wheel doesn't mean the elctrical contacts are still functioning normally. There may also be wiring issue between point A and point B.
    Registered Member Two Rings AudiRepair4Less's Avatar
    Apr 10 2008
    Long Beach
    The hazard switch is also the Relay, and It is Bad. I'm a audi Mechanic, and i See those things go out all the time.... First thing to check is turn your blinker on with your left hand, and tough the triangle button with you right hang. If the triangle button clicks or makes a noise Right after using the Switch most likely the switch. Very Rarely as is been the turn signal stock.... So, you dont think were just throwing parts at it, but from replacing tons of them. I would just replace it.
    Nov 19 2007
    Martinez, CA
    thanks for the input guys, i'm gonna start with the relay, much cheaper than the stock, and i hadn't ever heard of one of those not working anyway... i had read about similar issues as mine stemming from the hazard relay, but couldn't find one where the hazards were still working... gonna pick up a new relay and go from there...
    -'59 VW Bus
    -'69 VW Bug
    Apr 18 2008
    Palm Coast, FL
    Hey auditi, as I mentioned, just got this A4 a couple weeks ago and I had the exact same issue as yours... ie hazards work, parking lights work, blinkers don't. I replaced the hazard switch for $31.00 ($38.00 retail) from the dealership and mine now work fine. HTH
    Nov 19 2007
    Martinez, CA
    oh yeah, i just didn't update, replaced that switch last week or so, and yup, that was it, problem solved. at least it was a quick easy and cheap fix....
    -'59 VW Bus
    -'69 VW Bug
