Page 1 of 8 123 ... LastLast
Results 1 to 40 of 284
    Dec 03 2005
    audi, chevy, jeep, lots and lots of bicycles
    connecticut
    2.0L here we go!
    Let the fun begin folks!
    I picked up a 2001 Audi TT 225HP complete 1.8L the other month for a good price . I am going to use this block to build up a new motor to put into my AVant. Still unsure which head I'm going to use but we'll figure that out later.
    Here's the plan:
    AMU block (06A casting) out of a 2001 TT 225HP. Its native environment is transverse so I will be needing a few items off my AMB when I put it back together. That detail will be documented as we go. Since our B6 A4's 1.8L are an 06A block casting and this engine is the same casting then it'll fit!
    I was originally planning on using the TT's pistons and connecting rods (9.0:1 compression ratio and forged) but have since decided to go bigger...
    Overbore to 82.5mm from 81mm.
    New (used) crank from an AEG, 92.8mm stroke (1.8L stroke is 86.4mm)
    What does that yield? 2.0L my friends! This will be coupled with the ASP GT28RS turbo system and a custom ME7 tune. Motronic FTW!
    By the time the bottom end is built I'll have my new Jeep to drive so I can take my AVant's engine out (remember, I need all the externals and some other parts off the AMB to get the AMU completed for a longitudinal orientation). In the meantime the AVant is still my daily driver. Hence why I'm building on a different block.
    Today I spent the afternoon (maybe 4hours?) getting the AMU engine onto my new engine stand (sorry, no red wagons in this build) and disassembled. Scored the engine stand from Harbor Freight for $40.00.
    Notice some differences? For starters how about the intake manifold? Yup. that's not getting reused. The valve cover is also different. Only from using different coil packs. Everything else on the valve cover is the same. The accessories are similar (alternator, a/c pump, power steering pump). I think the pulleys for the accessories are different too. The serpentine belt had ribs on both sides and I think our B6s only have ribs on one side. Notice the engine mount in the center infront of the timing belt? How about the secondary air injection pump next to the oil filter? Again, transverse.
    Proof:
    I want to thank Clint (AudiA4_20T) for finding me this engine. I also want to thank him for the input and his photos I will be using to compare and contrast. I also want to thank Jake (317ssayzarc) for answering my questions in finding the right crankshaft and confirming block casting info. He's got a good thread here: http://audizine.com/forum/showthread.php?t=188078
    What tools are needed for engine disassembly?
    Basic 3/8" and 1/2" drive metric sockets ranging from 10mm up to 19mm
    Metric allen keys (preferably sockets)
    torx bits (preferably sockets)
    poly drive socket (10mm) for the cylinder head bolts
    triple square 12mm socket for the flywheel bolts (found 'em at Napa, p/n SER2306)
    twelve point 19mm socket for the crank bolt on the front of the engine
    air compressor (if you're lucky)
    engine stand (if you're lucky)
    Who's do the machining and build? Where am I getting the new parts from? I'm not sure yet. Still working that. I wanted to get the AMU engine apart first to figure out what I'm dealing with.
    -Doug
    2002 A4 2008cc GT-3076R turbocharged Avant
    397awhp/371awtq on straight 93oct and 96*F ambient
    Tuned by Autospeed Performance
    I am selling an Authentic B6 Sportec Front Bumper. PM me for info.
    Dec 03 2005
    connecticut
    Re: 2.0L here we go!
    Accessories are gone! (as you can tell from my tray of bolts in the background)
    That big 'hole' is for the thermostat
    No more oil cooler / oil filter
    That hole in the lower right is for the crankshaft position sensor.
    I couldn't get that damn crankshaft bolt off! So, I pulled the cylinder head off and then put the shortblock into the back of the AVant for a road trip. 30mins later I'm at Bernardsville VW (ironically, where I bought my AVant four years ago) and had the technician pop it loose with their impact gun. He made it look effortless. Now that its off I can finish pulling the block apart.
    Dinner, walk the dog and some other stuff.
    Back to work: No more crank pulley. I also removed the oil pan and the front main seal. Check out the oil pump and notice the oil pump pick up. Its different than the B6 AMB. (I'll compare in later posts) The oil looks funny because some water got into it.
    no more oil pump. That hole in the upper right is for the water pump.
    What's left? rear main seal, pistons, connecting rods, crankshaft.
    moved indoors (next to my mom's yarn 'warehouse' aka: the garage):
    Some photos of the shortblock. The engine was upside down so I rotated the photos so they are oriented as how the engine sits normally.
    intake manifold side
    exhaust manifold side
    Pistons out!
    cylinder 1 is on the far left (FWD of engine)
    cylinder 4 is on the far right (flywheel side)
    time for the rear main seal the the crankshaft and we're done!
    Crankshaft is out!
    Now to figure out who's doing the machine work and what parts I need to order..
    -Doug
    Veteran Member Four Rings k0mpresd's Avatar
    Sep 03 2004
    greensboro, nc
    im not sure if that transverse block has holes in the correct spots for the longitudinal engine mounts to attach to...
    Registered Member Four Rings A4ringedONE8T's Avatar
    Feb 17 2005
    Sarasota, FL
    Congrats on getting started!
    Looks like its missing the mounting points for the snub mount bracket or am I imagining things?
    Dec 03 2005
    connecticut
    I'm not sure. Now that its apart I'm going to go back through Clint's photo documentation and compare the AMU block to his photos of the AMB block. If all checks out then I'll be able to use this AMU block.
    I think the differences are all in the accessories and some of the covers (oil pan, valve cover, snub mount, etc...)
    We will see. If it fails then I'll wait until I get the Jeep and disassemble my AMB block for machining and rebuild rather than this AMU block (another month or two).
    -Doug
    Senior Member Three Rings Four Play's Avatar
    Mar 15 2007
    is full of shit!
    Texas
    Subscribed!
    Sounds like a fun project, can't to see it progress
    The inside of your motor looks like my mustangs after it blew a headgasket!
    V8 Touareg - 1G TSI AWD - WRB WRX
    Dec 03 2005
    connecticut
    Quote Originally Posted by Four Play View Post
    Yeah. Its been sitting outside for quite a while (covered and, I though, sealed). I think water got into the crankcase. I saw water ontop of the #4 piston which is why that piston looks nasty.
    Don't know the history on this engine so most of the block internals will not be reused.
    -Doug
    AZ Content Team Four Rings diagnosticator's Avatar
    Aug 26 2005
    Yeah, you won't be reusing practically anything off the AMU, except the block.
    Feb 17 2005
    Sarasota, FL
    Those pistons can be sold or possibly even be bartered for some OEM parts I have a parts list for you, shoot me your email and Ill send it over
    Senior Member Four Rings mtbrider's Avatar
    Oct 31 2005
    A4 GT2871R
    Virginia
    Nice!! Shawn I sent you a PM
    BetaAlphaTau member #5
    Meth Injected Built Bottom Fun
    ~Josh~
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by mtbrider View Post
    Back at ya, just an FYI, I know it would require some machine work but I will have my head core sitting around within the next month. I would be happy to let you use it and trade for yours when you swap or whatever, just think about it and let me know
    Oct 31 2005
    A4 GT2871R
    Virginia
    ^^^Pm returned. That may be an option. Are you going with an AEB?
    ~Josh~
    Feb 17 2005
    Sarasota, FL
    Yes it is AEB and is already built and ready, just needs cams
    Oct 31 2005
    A4 GT2871R
    Virginia
    Interested to see if the AEB will cause a MIL, I'll wait and see, otherwise I may have to take you up on your offer.
    ~Josh~
    Stage 2 Banner Advertiser Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Super fast Avants FTW!
    iPhone 4/4S Vapor aluminum case sale! $40 shipped! -> click here for details
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    The snub mount is on the oilpan, just transfer it over.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Nice!
    Finally some action in the B6 forums! Not just shit-chat, lol
    I wish I had the space and second car to do something like this with my car!
    -Sami-
    Nov 02 2007
    03 B6 1.8T TIP
    Richmond
    Nothing to say but WOW!!
    "When you love somone, you let her sleep well"
    My...2005
    Coiming this Summer: VIS Carbon Trunk w/carbon lip spoiler. CF splitter...
    "The fastest B6 TIP in Richmond BC"
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    2004 A4 1.8TQ M6 Ultrasport
    MA / NYC / FL
    I love all these 2.0 builds popping up. you'll probably be seeing another one this summer..
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | Apikol Snub Mount | Blacked-out Grilles | 35% Tint | Ipod Ice Link Interface | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Sep 14 2006
    MA / NYC / FL
    dougyfresh you live pretty close to me, i'd like to check out the car when its finished if you're okay with that.
    -Max
    Senior Member Four Rings 317ssayzarc's Avatar
    Oct 27 2007
    98.5 A4 2.0T 2001 Golf 1.8T
    Westerly RI
    btw, you KNOW whos doing the machine work
    also, get that block looking nice, like this:
    -Jake and my shop is DoWerk Garage
    01' Golf 1.8T - The daily, GT2871R .64 externally gated, Tapp 630cc mafless tune, SB stage 3, Brute rods, ported AEB, 1mm over valves, CAT gold springs, Vmaxx, and countless other tidbits
    Send
    me a pm if you need work done in New England... Fabrication, engine builds, timing belts, brakes, ect
    Senior Member Two Rings apexslider's Avatar
    Jan 09 2008
    Oregon
    your thread couldn't have come at a better time!! I'm excited to see how this progresses, I'm really wanting to find out what/if they have to do in machining to get the rods to clear the cylinders.
    Awesome project
    Senior Member Two Rings keithla4's Avatar
    Oct 31 2007
    02 audi a4 quattro man
    oregon
    hey my buddy has an AEG crank sitting in his shop came out of a golf nothing wrong internally with the engine but it broke off an ear for the front mount if your interested in it shoot me a PM. just trying to help out if i can.
    Dec 03 2005
    connecticut
    Quote Originally Posted by A4ringedONE8T View Post
    I am most likely going to sell/barter the stuff I'm not using. Pistons & rods, oil pan, intake and maybe even the complete head (and use my AMB head). Sent you a PM with my email. Please shoot me over that estimate.
    Quote Originally Posted by dirtybrd View Post
    I am fairly sure, yes. I'm going to put together a photo comparison with my AMU and Clint's AMB in the next few days.
    Quote Originally Posted by A4TUNE View Post
    Certainly! And if you are around when I swap engines you're welcome to come by and help out.
    Quote Originally Posted by 317ssayzarc View Post
    I'm fairly sure its going to RI for the machine work . I'm just waiting for a response from South Jersey first (gotta call and harrass). Think I'm going to have some one assemble the bottom end (pistons, rods, crank, crank bearings, etc..) and then I can do the rest of the assembly. Want someone that knows what they are doing to get the tolerances and torques correct. Who do you recommend? Or would you be willing to do it?
    Quote Originally Posted by keithla4 View Post
    Sent you a PM
    -Doug
    Oct 27 2007
    Westerly RI
    Russ is the man, I didnt even ask him to check that stuff, i just asked for him to do machine work and I come to get it one day and its all done... Rings gapped, tolerances all checked and were spot on, pistons/rods assembled, ect... I would love to do it for you but unfortunetly I have school and work, took me a week just to get time to do mine, and it only took 2 hours to do the bottom end assembly, minus the trips to get the oil shaft machined ... Call up Russ
    Send
    Dec 03 2005
    connecticut
    I called Russ and spoke to him about machine work but not assembly. You are saying he can do the bottom end assy too (crank, main bearings, pistons, rods, etc)?
    I can put the oil pump on and the front&rear seals and everything else to get it back to a long block. I think I want to leave the main bearings, rod bearings and stuff like that to someone that knows what they are doing.
    -Doug
    Oct 27 2007
    Westerly RI
    just have him assemble the bottom end, hes build a 1.8t right now actually, complete long block, just have him do your short block, you wont be dissappionted
    Send
    Oct 27 2007
    Westerly RI
    Oh and btw, he has a blown big block sitting in his office, he built that too
    Send
    Dec 03 2005
    connecticut
    Nice! I should bring some pictures of my friend's S/C'd big block (640cu). It propels his '81 Malibu Wagon down the 1/4 mile in the low 8s [O_O]
    I'll call Russ back on Monday.
    Looks like I'm getting the Jeep Cherokee in the next few weeks. I test drove it today. 1999 with 150k in white. Runs strong and has been well taken care of. Needs some minor maintenance: front shocks, rear main seal, oil pan gasket and a front pinion seal. Cheap parts and easy to repair w/ my buddy's lift .
    So, I think I might sell the AMU head and have the valve seats lapped on my AMB head while the AMU block is machined. Going to stick with an OEM head.
    Still working out the logistics in my head (got way too many things going on between work, relationships and mountain bike race season around the corner).
    -Doug
    Oct 27 2007
    Westerly RI
    your going to want to do a few things with that head, trust me...
    your going to want exhaust valve guides, as those wear out quickly
    your going to want supertech exhuast valves, chances are you may drop an oem one
    your going to want springs since you want to rev it
    and this part is optional but highly reccomended, cams, huge gains for 3071r and up turbos
    Send
    Registered Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    mod disease is growing, lol.
    I love to read thread like this.
    btw, will bob@qed be involved in this?
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth
    E46 M3 TiAg/IR Moton/GC Track Ready
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed
    E39 540iA Aggressor
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package
    Porsche 944 NA
    Jan 09 2008
    Oregon
    I just got my hands on a pristine AMU block...keep us posted on how this goes
    Mar 21 2006
    Lakeland, FL.
    I agree on everything except for the guides. I re-used mine with 98k on them. They were like new. Just inspect them for side to side play.
    I'm back bitches!
    Oct 27 2007
    Westerly RI
    true they can be reused, but .030" is nothing and many figure they are ok by just hand checking them
    Send
    Dec 03 2005
    connecticut
    Agreed on the guides (if worn beyond limits) and valves.
    See no reason for springs and cams.
    Why? Has anyone seen gains with cams on a 20series turbo? Don't the 20series turbos run out of steam beyond 7k on a 2.0L? As a result then its a waste of my money. I understand people around here (the 'new' and upcoming dealio) are going 30series and such but I'm sticking with what I currently have.
    If I do want more, it'll be with a different vehicle (B5 S4 or the like).
    I feel this engine work, coupled with the future diff work and possibly suspension and even bigger brakes will round out this vehicle for what I want. From there, I can move onto something else to add to my collection and build/tune/tweak that vehicle.
    One has to come up with a plan and I have developed such plan for my intentions. 2.0L is just an added benefit since I'm building the motor. Might as well add another $500 for machine work and a new crank to gain some displacement. This was always my long term plan but the engine work has been moved forward for other reasons...
    -Doug
    AZ Content Team Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    You better show us some numbers when this is done. Unlike some of our fellow AZer's. cough*Shawn*cough
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Jun 11 2005
    Vancouver, BC
    I thought you really only needed to upgrade the valves and springs if you planned to run the 8500rpm REVO file.
    Shouldn't the stock componets do fine with the stock rev limiter in place?
    Oct 27 2007
    Westerly RI
    imo, i wouldnt go over 7500 w/o springs...
    and you need cams to make real power up there anyways...
    Send
    Senior Member Two Rings aI_x.8T's Avatar
    Dec 14 2006
    05 Saab 9.2x 5MT
    Mississauga, Ontario, Canada
    Subscribed!
    Alex
    Thought is a key to all treasures; the miser's gains are ours without his cares. Thus I have soared above this world, where my enjoyment have been intellectual joys. - Honore de Balzac
    Veteran Member Four Rings Issam@INA's Avatar
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Quote Originally Posted by k0mpresd View Post
    All the correct mounting boses are there.
    INA Engineering Inc.
    APR distributor FOR OTTAWA | HULL | GATINEAU | HULL | KINGSTON
    THE NEW VR6 B5/B6 FAQ
    Email US | Facebook US | Call US : +1.510.275.4775
