Results 1 to 9 of 9
    Senior Member Two Rings joshd2012's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T Quattro 6MT
    Arlington, VA
    Clean sticker gunk off windows?
    What is the best way to get sticker gunk off windows? It looks like the sales sticker got fried onto my side window, and I need to clean it up before I take her to get some tints.
    The ways I'm accustom to using are:
    1) Razor Blade
    2) Hair Drier
    3) WD-40
    Is one better than the other for my glass? Or is there some better way to get the gunk off safely?
    2006 Audi A4 quattro 2.0T 6MT
    Engine:
    Podi Boost Gauge / Audi Rev 'D' DV / Carbonio CAI / Blinktek Heat Shield / 034 Turbo Inlet Hose
    Exhaust: Stasis Exhaust / LaBree HFC
    Suspension: Vogtland CO / RS4 Rear Sway Bar
    Wheels: 18" Audi USP (Powdercoated Black) / H&R Spacers / Goodyear Eagle F1 A/S
    Exterior: Audi Euro Xenon Retro / Deval Rear Spoiler / Audi Filler Plate / Painted Sidemarkers
    Future: K04
    Veteran Member Four Rings 1SickS5's Avatar
    Jul 18 2004
    Orange County, CA
    Items for Sale
    Re: Clean sticker gunk off windows?
    Goof-Off
    Senior Member Two Rings Dark 'n' Dirty's Avatar
    Sep 16 2006
    Newton, MA
    Quote Originally Posted by joshd2012 View Post
    1) Razor Blade
    2) Hair Drier
    3) WD-40
    I normally use window cleaner and a razor blade. Wipe off with a microfiber.
    Dec 19 2007
    York, PA
    first, razor blade....OR like 1sicka4 said, goof-off, let it sit for a minute and then razor blade it up. Finish up with some stoners invisible glass and an MF
    Established Member Two Rings einstrigger's Avatar
    B7 A4, RL, S2R 800, D675
    Sacramento, CA
    3M adhesive remover and a hair dryer. Warm it up first, spray on the 3M adhesive remover, and then slowly start peeling. Spray more 3M if the stuff is still resisting. Should come right off without worrying about scratching the window with a razor.
    Registered Member One Ring ilagan's Avatar
    Mar 17 2008
    '99.5 A4 2.8 quattro
    Philadelphia, PA
    I'd go with the window cleaner and the razor blade. Make sure you never hold the razor perpendicular to the glass and you should have no worries potentially scratching the glass. In fact, you'd have to intentionally try and etch the glass in order to scratch it. Also, don't do this if you have aftermarket tint.
    Veteran Member Three Rings Alan's Avatar
    Jan 22 2007
    1998 2.8QM 1988 Corvette
    Pittsburgh, PA
    I use Goo-gone and a towel.
    Jun 08 2007
    GLI
    Orlando, Fl
    Items for Sale
    Soak it with a wet sponge and razor blade it. You can follow up with some prepsolve or goo gone to get rid of adhesive reidue and finish with some glass cleaner.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Sep 14 2007
    2004 A4 1.8T, 93 Ford Festiva
    Nazareth, PA
    razor blade should do the job, however if your going to get the windows tinted they should clean the windows completely before they tint them
