Results 1 to 10 of 10
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    1.8T AMU longblock (EDIT: NO longer for sale)
    I've got a 2001 1.8T complete long-block for sale. It is engine code AMU (TT 225hp model). It includes everything minus fuel injectors, exhaust manifold, turbo, engine mounts and transmission. Basically the entire motor. Mileage is in the 40k region.
    The engine is located in New Jersey.
    Asking $1500 or best offer.
    EDIT:
    This long block is no longer for sale. I've decided to keep it. Thanks for your interest.
    -Doug
    '02 A4 Avant 2.7T 6spd
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    Re: FS: 1.8T AMU longblock
    To the top. I added an asking price.
    -Doug
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    bump
    -Doug
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    can the amu block be paired with aeb head?
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Items for Sale
    Quote Originally Posted by GiacGRs4 View Post
    Yes it can. Be sure to use your OEM AEB head bolts and NOT the shorter AMU/AMB bolts.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    Jeff.
    Question for you.
    Pardon me for asking you this more than once.
    This AMU I have listed is an 06a block, correct? That means it should bolt right up into a longitudinal chassis... ie: B5/B6 A4 chassis.
    -Doug
    Feb 18 2004
    Los Angeles, CA
    Items for Sale
    AMU was made for a Transverse platform, but will bolt up to the motor mount brackets to go in a Longitudenal setup. You will need to do some slight modification on the waterpump area to house your B5/B6 one. This can be used to replace the AMB as well as AWM (2001 B5).
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    What modifications do you speak of to the water pump area? I thought all 06a blocks were identical?
    -Doug
    Feb 18 2004
    Los Angeles, CA
    Items for Sale
    Slight grinding required...nothing major.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Items for Sale
    Okay. Thanks!
    -Doug
